root/radiance/ray/src/util/glare.h
Revision: 2.7
Committed: Thu May 1 16:42:06 2008 UTC (16 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3, HEAD
1 /* RCSid: $Id: glare.h,v 2.6 2004/01/02 12:51:54 schorsch Exp $ */
2 /*
3 * Common data structures for glare source finding routines
4 */
5 #ifndef _RAD_GLARE_H_
6 #define _RAD_GLARE_H_
7
8 #include "standard.h"
9 #include "view.h"
10 #include "color.h"
11 #include "setscan.h"
12
13 #ifdef __cplusplus
14 extern "C" {
15 #endif
16
17 #define GLAREBR 7.0 /* glare source is this * avg. lum. */
18
19 #define SAMPDENS 75 /* default samples per unit in image */
20 #define TSAMPSTEP 10 /* sample step to compute threshold */
21
22 #define SEPS 1 /* sources this close ==> contig. */
23
24 #define SAMIN .005 /* minimum solid angle for source */
25 #define MAXBUDDY (4.*sqrt(SAMIN/PI)) /* max separation for pairing */
26
27 #define TOOSMALL(s) ((s)->brt*(s)->dom < threshold*SAMIN)
28
29 #define SABIG .025 /* solid angle of splittable source */
30 #define LCORR .12 /* linearity of splittable source */
31
32 extern VIEW ourview; /* our view */
33 extern VIEW pictview; /* picture view */
34 extern VIEW leftview, rightview; /* leftmost and rightmost views */
35
36 extern int verbose; /* verbose reporting */
37 extern char *progname; /* global argv[0] */
38
39 extern double threshold; /* threshold value for glare sources */
40
41 extern int sampdens; /* sample density */
42 extern ANGLE glarang[]; /* glare calculation angles */
43 extern int nglarangs;
44 extern double maxtheta; /* maximum glare angle (in radians) */
45 extern int hsize; /* horizontal size */
46
47 #define nglardirs (2*nglarangs+1)
48 #define vsize (sampdens-1)
49 #define hscale(v) sqrt((double)(sampdens*sampdens - (v)*(v)))
50 #define hlim(v) (int)(maxtheta*hscale(v))
51 #define h_theta(h,v) (-(h)/hscale(v))
52
53 extern struct illum {
54 float theta; /* glare direction */
55 float lcos, lsin; /* cosine and sine to left view */
56 float rcos, rsin; /* cosine and sine to right view */
57 double sum; /* sum of indirect luminances */
58 double n; /* number of values in sum */
59 } *indirect; /* array of indirect illuminances */
60
61 struct srcspan {
62 short v; /* vertical position */
63 short l, r; /* left and right horizontal limits */
64 float brsum; /* sum of brightnesses for this span */
65 struct srcspan *next; /* next source span in list */
66 };
67
68 extern struct source {
69 FVECT dir; /* source direction */
70 double dom; /* solid angle of source */
71 double brt; /* average source brightness */
72 struct srcspan *first; /* first span for this source */
73 struct source *next; /* next source in list */
74 } *donelist; /* finished sources */
75
76
77 extern long npixinvw; /* number of samples in view */
78 extern long npixmiss; /* number of samples missing */
79
80 /* defined in findglare.c */
81 extern void memerr(char *s);
82 extern int compdir(FVECT vd, int x, int y);
83 extern double pixsize(int x, int y);
84 /* defined in glaresrc.c */
85 extern void comp_thresh(void);
86 extern void analyze(void);
87 extern void absorb_specks(void);
88 /* defined in glareval.c */
89 extern void open_pict(char *fn);
90 extern void fork_rtrace(char *av[]);
91 extern void close_pict(void);
92 extern void done_rtrace(void);
93 extern void getviewspan(int vv, float *vb);
94 extern double getviewpix(int vh, int vv);
95
96 #ifdef __cplusplus
97 }
98 #endif
99 #endif /* _RAD_GLARE_H_ */
100
