--- ray/src/util/glare.h 1991/04/30 16:24:08 1.17 +++ ray/src/util/glare.h 2004/01/02 12:51:54 2.6 @@ -1,16 +1,19 @@ -/* Copyright (c) 1991 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid: $Id: glare.h,v 2.6 2004/01/02 12:51:54 schorsch Exp $ */ /* * Common data structures for glare source finding routines */ +#ifndef _RAD_GLARE_H_ +#define _RAD_GLARE_H_ #include "standard.h" #include "view.h" #include "color.h" #include "setscan.h" +#ifdef __cplusplus +extern "C" { +#endif + #define GLAREBR 7.0 /* glare source is this * avg. lum. */ #define SAMPDENS 75 /* default samples per unit in image */ @@ -24,7 +27,7 @@ #define TOOSMALL(s) ((s)->brt*(s)->dom < threshold*SAMIN) #define SABIG .025 /* solid angle of splittable source */ -#define LCORR .8 /* linearity of splittable source */ +#define LCORR .12 /* linearity of splittable source */ extern VIEW ourview; /* our view */ extern VIEW pictview; /* picture view */ @@ -70,8 +73,28 @@ extern struct source { struct source *next; /* next source in list */ } *donelist; /* finished sources */ -extern double getviewpix(); -extern double pixsize(); extern long npixinvw; /* number of samples in view */ extern long npixmiss; /* number of samples missing */ + + /* defined in findglare.c */; +extern void memerr(char *s); +extern int compdir(FVECT vd, int x, int y); +extern double pixsize(int x, int y); + /* defined in glaresrc.c */ +extern void comp_thresh(void); +extern void analyze(void); +extern void absorb_specks(void); + /* defined in glareval.c */ +extern void open_pict(char *fn); +extern void fork_rtrace(char *av[]); +extern void close_pict(void); +extern void done_rtrace(void); +extern void getviewspan(int vv, float *vb); +extern double getviewpix(int vh, int vv); + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_GLARE_H_ */ +
