--- ray/src/util/glare.h 2003/02/22 02:07:30 2.3 +++ ray/src/util/glare.h 2004/01/02 12:51:54 2.6 @@ -1,13 +1,19 @@ -/* RCSid: $Id: glare.h,v 2.3 2003/02/22 02:07:30 greg Exp $ */ +/* RCSid: $Id: glare.h,v 2.6 2004/01/02 12:51:54 schorsch Exp $ */ /* * Common data structures for glare source finding routines */ +#ifndef _RAD_GLARE_H_ +#define _RAD_GLARE_H_ #include "standard.h" #include "view.h" #include "color.h" #include "setscan.h" +#ifdef __cplusplus +extern "C" { +#endif + #define GLAREBR 7.0 /* glare source is this * avg. lum. */ #define SAMPDENS 75 /* default samples per unit in image */ @@ -67,8 +73,28 @@ extern struct source { struct source *next; /* next source in list */ } *donelist; /* finished sources */ -extern double getviewpix(); -extern double pixsize(); extern long npixinvw; /* number of samples in view */ extern long npixmiss; /* number of samples missing */ + + /* defined in findglare.c */; +extern void memerr(char *s); +extern int compdir(FVECT vd, int x, int y); +extern double pixsize(int x, int y); + /* defined in glaresrc.c */ +extern void comp_thresh(void); +extern void analyze(void); +extern void absorb_specks(void); + /* defined in glareval.c */ +extern void open_pict(char *fn); +extern void fork_rtrace(char *av[]); +extern void close_pict(void); +extern void done_rtrace(void); +extern void getviewspan(int vv, float *vb); +extern double getviewpix(int vh, int vv); + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_GLARE_H_ */ +
