root/radiance/ray/src/util/glare.h
Revision: 2.7
Committed: Thu May 1 16:42:06 2008 UTC (17 years, 2 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R1, rad4R0, rad4R2P1, rad5R3
# User Rev Content
1 greg 2.7 /* RCSid: $Id: glare.h,v 2.6 2004/01/02 12:51:54 schorsch Exp $ */
2 greg 1.1 /*
3     * Common data structures for glare source finding routines
4     */
5 schorsch 2.4 #ifndef _RAD_GLARE_H_
6     #define _RAD_GLARE_H_
7 greg 1.1
8     #include "standard.h"
9     #include "view.h"
10     #include "color.h"
11     #include "setscan.h"
12 schorsch 2.5
13     #ifdef __cplusplus
14     extern "C" {
15     #endif
16 greg 1.1
17 greg 1.14 #define GLAREBR 7.0 /* glare source is this * avg. lum. */
18 greg 1.1
19 greg 1.17 #define SAMPDENS 75 /* default samples per unit in image */
20 greg 1.1 #define TSAMPSTEP 10 /* sample step to compute threshold */
21
22 greg 1.13 #define SEPS 1 /* sources this close ==> contig. */
23 greg 1.1
24 greg 1.8 #define SAMIN .005 /* minimum solid angle for source */
25     #define MAXBUDDY (4.*sqrt(SAMIN/PI)) /* max separation for pairing */
26
27     #define TOOSMALL(s) ((s)->brt*(s)->dom < threshold*SAMIN)
28 greg 1.17
29     #define SABIG .025 /* solid angle of splittable source */
30 greg 2.2 #define LCORR .12 /* linearity of splittable source */
31 greg 1.8
32 greg 1.1 extern VIEW ourview; /* our view */
33     extern VIEW pictview; /* picture view */
34     extern VIEW leftview, rightview; /* leftmost and rightmost views */
35
36     extern int verbose; /* verbose reporting */
37     extern char *progname; /* global argv[0] */
38
39 greg 1.7 extern double threshold; /* threshold value for glare sources */
40
41 greg 1.4 extern int sampdens; /* sample density */
42 greg 1.1 extern ANGLE glarang[]; /* glare calculation angles */
43     extern int nglarangs;
44 greg 1.2 extern double maxtheta; /* maximum glare angle (in radians) */
45 greg 1.1 extern int hsize; /* horizontal size */
46
47     #define nglardirs (2*nglarangs+1)
48 greg 1.5 #define vsize (sampdens-1)
49 greg 1.16 #define hscale(v) sqrt((double)(sampdens*sampdens - (v)*(v)))
50     #define hlim(v) (int)(maxtheta*hscale(v))
51     #define h_theta(h,v) (-(h)/hscale(v))
52 greg 1.1
53     extern struct illum {
54     float theta; /* glare direction */
55     float lcos, lsin; /* cosine and sine to left view */
56     float rcos, rsin; /* cosine and sine to right view */
57     double sum; /* sum of indirect luminances */
58 greg 1.10 double n; /* number of values in sum */
59 greg 1.1 } *indirect; /* array of indirect illuminances */
60
61     struct srcspan {
62     short v; /* vertical position */
63     short l, r; /* left and right horizontal limits */
64     float brsum; /* sum of brightnesses for this span */
65     struct srcspan *next; /* next source span in list */
66     };
67
68     extern struct source {
69     FVECT dir; /* source direction */
70 greg 1.6 double dom; /* solid angle of source */
71     double brt; /* average source brightness */
72 greg 1.1 struct srcspan *first; /* first span for this source */
73     struct source *next; /* next source in list */
74     } *donelist; /* finished sources */
75 greg 1.14
76 greg 1.11
77     extern long npixinvw; /* number of samples in view */
78     extern long npixmiss; /* number of samples missing */
79 schorsch 2.4
80 greg 2.7 /* defined in findglare.c */
81 schorsch 2.6 extern void memerr(char *s);
82     extern int compdir(FVECT vd, int x, int y);
83     extern double pixsize(int x, int y);
84     /* defined in glaresrc.c */
85     extern void comp_thresh(void);
86     extern void analyze(void);
87     extern void absorb_specks(void);
88     /* defined in glareval.c */
89     extern void open_pict(char *fn);
90     extern void fork_rtrace(char *av[]);
91     extern void close_pict(void);
92     extern void done_rtrace(void);
93     extern void getviewspan(int vv, float *vb);
94     extern double getviewpix(int vh, int vv);
95 schorsch 2.4
96     #ifdef __cplusplus
97     }
98     #endif
99     #endif /* _RAD_GLARE_H_ */
100
