root/radiance/ray/src/util/glare.h
Fri Jan 2 12:51:54 2004 UTC (21 years, 5 months ago) by schorsch
Changes since 2.5: +16 -4 lines
Ansification.
Mon Jul 14 22:24:00 2003 UTC (21 years, 10 months ago) by schorsch
Changes since 2.4: +5 -5 lines
Fri Jun 27 11:32:12 2003 UTC (21 years, 11 months ago) by schorsch
Changes since 2.3: +17 -3 lines
Continued ANSIfication.
Sat Feb 22 02:07:30 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.2: +1 -4 lines
Tue May 25 14:54:05 1993 UTC (32 years ago) by greg
Diff to previous 2.1
reduced linearity of splittable source
Tue Nov 12 17:19:16 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 1.17
Tue Apr 30 16:24:08 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.16: +4 -1 lines
Diff to previous 1.16
Mon Apr 22 10:28:10 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.15
changed definition of hscale() macro
Fri Apr 19 17:41:02 1991 UTC (34 years, 1 month ago) by greg
Changes since 1.14: +4 -7 lines
Diff to previous 1.14
Fri Apr 12 10:28:39 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.13: +6 -1 lines
Diff to previous 1.13
minor changes and bug fixes
Wed Apr 10 15:59:04 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.12
Wed Apr 3 15:43:53 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.11: +0 -2 lines
Diff to previous 1.11
removed DEBUG flag
Thu Mar 28 16:27:23 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.10: +3 -0 lines
Diff to previous 1.10
added warning message for insufficient data
Thu Mar 21 17:11:48 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.9
Wed Mar 20 13:47:38 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.8
switched on DEBUG
Wed Mar 20 11:56:42 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.7: +5 -0 lines
Diff to previous 1.7
added routines to absorb too-small glare sources
Tue Mar 19 17:31:35 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.6: +2 -0 lines
Diff to previous 1.6
added -t option for setting glare threshold
Tue Mar 19 11:11:18 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.5
increased accuracy of source values
Tue Mar 19 09:08:17 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.4
changed resolution
Mon Mar 18 16:06:51 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.3: +4 -3 lines
Diff to previous 1.3
Mon Mar 18 15:06:30 1991 UTC (34 years, 2 months ago) by greg
Diff to previous 1.2
fixed orientation of theta
Mon Mar 18 14:32:15 1991 UTC (34 years, 2 months ago) by greg
bug fixes and enhancements
Mon Mar 18 12:15:39 1991 UTC (34 years, 2 months ago) by greg
