root/radiance/ray/src/util/glare.h
Revision: 1.6
Committed: Tue Mar 19 11:11:18 1991 UTC (33 years, 3 months ago) by greg
increased accuracy of source values
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * Common data structures for glare source finding routines
7 */
8
9 #include "standard.h"
10 #include "view.h"
11 #include "color.h"
12 #include "setscan.h"
13
14 #define GLAREBR 10.0 /* glare source is this * avg. lum. */
15
16 #define SAMPDENS 50 /* default samples per unit in image */
17 #define TSAMPSTEP 10 /* sample step to compute threshold */
18
19 #define SEPS 2 /* sources this close ==> contig. */
20
21 extern VIEW ourview; /* our view */
22 extern VIEW pictview; /* picture view */
23 extern VIEW leftview, rightview; /* leftmost and rightmost views */
24
25 extern int verbose; /* verbose reporting */
26 extern char *progname; /* global argv[0] */
27
28 extern int sampdens; /* sample density */
29 extern ANGLE glarang[]; /* glare calculation angles */
30 extern int nglarangs;
31 extern double maxtheta; /* maximum glare angle (in radians) */
32 extern int hsize; /* horizontal size */
33 extern int hlim; /* horizontal limit of central view */
34
35 #define nglardirs (2*nglarangs+1)
36 #define vsize (sampdens-1)
37 #define h_theta(h) (-(double)(h)/(double)sampdens)
38
39 extern struct illum {
40 float theta; /* glare direction */
41 float lcos, lsin; /* cosine and sine to left view */
42 float rcos, rsin; /* cosine and sine to right view */
43 double sum; /* sum of indirect luminances */
44 int n; /* number of values in sum */
45 } *indirect; /* array of indirect illuminances */
46
47 struct srcspan {
48 short v; /* vertical position */
49 short l, r; /* left and right horizontal limits */
50 float brsum; /* sum of brightnesses for this span */
51 struct srcspan *next; /* next source span in list */
52 };
53
54 extern struct source {
55 FVECT dir; /* source direction */
56 double dom; /* solid angle of source */
57 double brt; /* average source brightness */
58 struct srcspan *first; /* first span for this source */
59 struct source *next; /* next source in list */
60 } *donelist; /* finished sources */
61
62 extern double getviewpix();
