root/radiance/ray/src/util/glare.h
Revision: 2.8
Committed: Sat Jun 7 05:09:46 2025 UTC (18 hours, 59 minutes ago) by greg
# User Rev Content
1 greg 2.8 /* RCSid: $Id: glare.h,v 2.7 2008/05/01 16:42:06 greg Exp $ */
2 greg 1.1 /*
3     * Common data structures for glare source finding routines
4     */
5 schorsch 2.4 #ifndef _RAD_GLARE_H_
6     #define _RAD_GLARE_H_
7 greg 1.1
8     #include "standard.h"
9 greg 2.8 #include "paths.h"
10 greg 1.1 #include "view.h"
11     #include "color.h"
12     #include "setscan.h"
13 schorsch 2.5
14     #ifdef __cplusplus
15     extern "C" {
16     #endif
17 greg 1.1
18 greg 1.14 #define GLAREBR 7.0 /* glare source is this * avg. lum. */
19 greg 1.1
20 greg 1.17 #define SAMPDENS 75 /* default samples per unit in image */
21 greg 1.1 #define TSAMPSTEP 10 /* sample step to compute threshold */
22
23 greg 1.13 #define SEPS 1 /* sources this close ==> contig. */
24 greg 1.1
25 greg 1.8 #define SAMIN .005 /* minimum solid angle for source */
26     #define MAXBUDDY (4.*sqrt(SAMIN/PI)) /* max separation for pairing */
27
28     #define TOOSMALL(s) ((s)->brt*(s)->dom < threshold*SAMIN)
29 greg 1.17
30     #define SABIG .025 /* solid angle of splittable source */
31 greg 2.2 #define LCORR .12 /* linearity of splittable source */
32 greg 1.8
33 greg 1.1 extern VIEW ourview; /* our view */
34     extern VIEW pictview; /* picture view */
35     extern VIEW leftview, rightview; /* leftmost and rightmost views */
36
37     extern int verbose; /* verbose reporting */
38     extern char *progname; /* global argv[0] */
39
40 greg 1.7 extern double threshold; /* threshold value for glare sources */
41
42 greg 1.4 extern int sampdens; /* sample density */
43 greg 1.1 extern ANGLE glarang[]; /* glare calculation angles */
44     extern int nglarangs;
45 greg 1.2 extern double maxtheta; /* maximum glare angle (in radians) */
46 greg 1.1 extern int hsize; /* horizontal size */
47
48     #define nglardirs (2*nglarangs+1)
49 greg 1.5 #define vsize (sampdens-1)
50 greg 1.16 #define hscale(v) sqrt((double)(sampdens*sampdens - (v)*(v)))
51     #define hlim(v) (int)(maxtheta*hscale(v))
52     #define h_theta(h,v) (-(h)/hscale(v))
53 greg 1.1
54     extern struct illum {
55     float theta; /* glare direction */
56     float lcos, lsin; /* cosine and sine to left view */
57     float rcos, rsin; /* cosine and sine to right view */
58     double sum; /* sum of indirect luminances */
59 greg 1.10 double n; /* number of values in sum */
60 greg 1.1 } *indirect; /* array of indirect illuminances */
61
62     struct srcspan {
63     short v; /* vertical position */
64     short l, r; /* left and right horizontal limits */
65     float brsum; /* sum of brightnesses for this span */
66     struct srcspan *next; /* next source span in list */
67     };
68
69     extern struct source {
70     FVECT dir; /* source direction */
71 greg 1.6 double dom; /* solid angle of source */
72     double brt; /* average source brightness */
73 greg 1.1 struct srcspan *first; /* first span for this source */
74     struct source *next; /* next source in list */
75     } *donelist; /* finished sources */
76 greg 1.14
77 greg 1.11
78     extern long npixinvw; /* number of samples in view */
79     extern long npixmiss; /* number of samples missing */
80 schorsch 2.4
81 greg 2.7 /* defined in findglare.c */
82 schorsch 2.6 extern void memerr(char *s);
83     extern int compdir(FVECT vd, int x, int y);
84     extern double pixsize(int x, int y);
85     /* defined in glaresrc.c */
86     extern void comp_thresh(void);
87     extern void analyze(void);
88     extern void absorb_specks(void);
89     /* defined in glareval.c */
90     extern void open_pict(char *fn);
91     extern void fork_rtrace(char *av[]);
92     extern void close_pict(void);
93     extern void done_rtrace(void);
94     extern void getviewspan(int vv, float *vb);
95     extern double getviewpix(int vh, int vv);
96 schorsch 2.4
97     #ifdef __cplusplus
98     }
99     #endif
100     #endif /* _RAD_GLARE_H_ */
101
