1 |
greg |
1.1 |
#!/bin/csh -f |
2 |
greg |
2.4 |
# RCSid: $Id$ |
3 |
greg |
1.1 |
4 |
# Interactive program for calculating glare values |
5 |
6 |
set fgargs=(-v) |
7 |
set nofile="none" |
8 |
set octree=$nofile |
9 |
set picture=$nofile |
10 |
greg |
2.2 |
set glarefile=$nofile |
11 |
greg |
1.1 |
if ($#argv >= 1) then |
12 |
set glarefile=$argv[1] |
13 |
greg |
2.2 |
if ($#argv >= 2) then |
14 |
set picture=$argv[2] |
15 |
if ($#argv >= 3) then |
16 |
set octree=$argv[3] |
17 |
endif |
18 |
endif |
19 |
greg |
1.1 |
endif |
20 |
set rtargs= |
21 |
set view= |
22 |
set threshold=300 |
23 |
set maxangle=0 |
24 |
set stepangle=10 |
25 |
26 |
set gndxfile="glr$$.ndx" |
27 |
set plotfile="glr$$.plt" |
28 |
set tempfiles=($gndxfile $plotfile) |
29 |
30 |
alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"' |
31 |
32 |
onintr quit |
33 |
34 |
cat <<_EOF_ |
35 |
This script provides a convenient interface to the glare calculation |
36 |
and analysis programs. It works on a single output file from findglare, |
37 |
which you must either create here or have created already before. |
38 |
_EOF_ |
39 |
while ( $glarefile == $nofile ) |
40 |
echo "" |
41 |
echo "Please specify a glare file, or use ^C to exit." |
42 |
readvar glarefile |
43 |
end |
44 |
if ( ! -f $glarefile ) then |
45 |
echo "" |
46 |
echo -n "The glare file '$glarefile' doesn't exist -- shall we create it? " |
47 |
if ("$<" =~ [nN]*) exit 0 |
48 |
cat <<_EOF_ |
49 |
50 |
A glare file can be created from a wide-angle Radiance picture (preferably |
51 |
a fisheye view), an octree, or both. Computing glare source locations |
52 |
from a finished image is faster, but using an octree is more reliable |
53 |
since all of the scene information is there. Whenever it is possible, |
54 |
you should use both a picture and an octree to compute the glare file. |
55 |
56 |
You must also have a viewpoint and direction for the glare calculation. |
57 |
If the viewpoint is not the same as the picture, an error will result. |
58 |
If no view is specified, the view parameters are taken from the picture, |
59 |
so the view specification is optional unless you are starting from an |
60 |
octree. |
61 |
greg |
1.2 |
62 |
greg |
1.1 |
_EOF_ |
63 |
greg |
2.2 |
if ( $picture == $nofile ) then |
64 |
readvar picture |
65 |
endif |
66 |
if ( $octree == $nofile ) then |
67 |
readvar octree |
68 |
endif |
69 |
greg |
1.1 |
readvar view |
70 |
if ( $picture == $nofile && $octree == $nofile ) then |
71 |
echo "You must specify a picture or an octree" |
72 |
exit 1 |
73 |
endif |
74 |
greg |
1.6 |
if ( $picture == $nofile && "$view" == "" ) then |
75 |
echo "You must give a view if there is no picture" |
76 |
exit 1 |
77 |
endif |
78 |
greg |
1.1 |
if ( $picture != $nofile ) then |
79 |
if ( ! -r $picture ) then |
80 |
echo "Cannot read $picture" |
81 |
exit 1 |
82 |
endif |
83 |
greg |
1.11 |
set fgargs=($fgargs -p $picture) |
84 |
if ( "$view" != "" ) then |
85 |
set view=(-vf $picture $view) |
86 |
endif |
87 |
greg |
1.1 |
endif |
88 |
set fgargs=($fgargs $view) |
89 |
if ( $octree != $nofile ) then |
90 |
if ( ! -r $octree ) then |
91 |
echo "Cannot read $octree" |
92 |
exit 1 |
93 |
endif |
94 |
cat <<_EOF_ |
95 |
96 |
With an octree, you should give the same options for -av, -ab and |
97 |
so forth as are used to render the scene. Please enter them below. |
98 |
99 |
_EOF_ |
100 |
greg |
1.10 |
if ($picture != $nofile) then |
101 |
echo "These are the parameters from the picture:" |
102 |
getinfo $picture |
103 |
endif |
104 |
greg |
1.1 |
readvar rtargs |
105 |
set fgargs=($fgargs $rtargs $octree) |
106 |
endif |
107 |
echo "" |
108 |
echo -n "Do you expect glare sources in the scene to be small? " |
109 |
if ("$<" =~ [yY]) then |
110 |
echo -n "Very small? " |
111 |
112 |
set fgargs=(-r 400 $fgargs) |
113 |
else |
114 |
greg |
1.3 |
set fgargs=(-r 250 $fgargs) |
115 |
greg |
1.1 |
endif |
116 |
greg |
1.4 |
echo -n "Are these sources relatively bright? " |
117 |
greg |
1.1 |
if ("$<" =~ [nN]*) then |
118 |
set fgargs=(-c $fgargs) |
119 |
endif |
120 |
endif |
121 |
cat <<_EOF_ |
122 |
123 |
Glare sources are determined by a threshold level. Any part of the |
124 |
view that is above this threshold is considered to be part of a glare |
125 |
source. If you do not choose a threshold value, it will be set auto- |
126 |
matically to 7 times the average field luminance (in candelas/sq.meter). |
127 |
128 |
_EOF_ |
129 |
echo -n "Do you wish to set the glare threshold manually? " |
130 |
131 |
readvar threshold |
132 |
set fgargs=(-t $threshold $fgargs) |
133 |
endif |
134 |
cat <<_EOF_ |
135 |
136 |
It is often desirable to know how glare changes as a function of |
137 |
viewing direction. If you like, you can compute glare for up |
138 |
to 180 degrees to the left and right of the view center. Enter |
139 |
the maximum angle that you would like to compute below. |
140 |
141 |
_EOF_ |
142 |
readvar maxangle |
143 |
if ( $maxangle >= $stepangle ) then |
144 |
set fgargs=(-ga $stepangle-$maxangle\:$stepangle $fgargs) |
145 |
endif |
146 |
echo "" |
147 |
echo "Starting calculation..." |
148 |
echo findglare $fgargs |
149 |
findglare $fgargs > $glarefile |
150 |
greg |
1.11 |
if ($status) then |
151 |
echo "Uh-oh. Something went wrong with findglare\!" |
152 |
rm $glarefile |
153 |
exit 1 |
154 |
endif |
155 |
greg |
1.1 |
endif |
156 |
if ($?DISPLAY && $picture != $nofile) then |
157 |
echo "" |
158 |
echo "Displaying glare sources in '$picture'..." |
159 |
greg |
1.9 |
xglaresrc $picture $glarefile |
160 |
greg |
1.1 |
endif |
161 |
greg |
2.3 |
set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index" "BRS Glare Index" "Unified Glare Rating" "Daylight Glare Index") |
162 |
set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi" "glarendx -t brs_gi" "glarendx -t ugr" "glarendx -t dgi") |
163 |
set bcdlvl=(50 124 18.5 18.5 18.5 21.7) |
164 |
greg |
1.1 |
while ( 1 ) |
165 |
echo "" |
166 |
echo " 0. Quit" |
167 |
set i=1 |
168 |
while ($i <= $#ndxnam) |
169 |
echo " $i. $ndxnam[$i]" |
170 |
@ i++ |
171 |
end |
172 |
echo "" |
173 |
set choice=0 |
174 |
readvar choice |
175 |
if ($choice < 1 || $choice > $#ndxcom) goto quit |
176 |
$ndxcom[$choice] $glarefile > $gndxfile |
177 |
echo "" |
178 |
echo $ndxnam[$choice] |
179 |
echo "Angle Value" |
180 |
getinfo - < $gndxfile |
181 |
echo "" |
182 |
set save_file=$nofile |
183 |
readvar save_file |
184 |
if ($save_file != $nofile) then |
185 |
cp -i $gndxfile $save_file |
186 |
endif |
187 |
if ( `getinfo - < $gndxfile | wc -l` > 4 ) then |
188 |
echo "" |
189 |
echo -n "Do you want to plot this data? " |
190 |
if ( "$<" =~ [yY]* ) then |
191 |
set subtitle="$view" |
192 |
193 |
set subtitle="$picture $subtitle" |
194 |
else if ($octree != $nofile) then |
195 |
set subtitle="$subtitle $octree" |
196 |
endif |
197 |
greg |
1.2 |
if ( "$subtitle" == "" ) then |
198 |
set subtitle="`getinfo < $glarefile | grep findglare`" |
199 |
endif |
200 |
greg |
1.1 |
cat <<_EOF_ > $plotfile |
201 |
greg |
1.2 |
include=line.plt |
202 |
greg |
1.1 |
include=polar.plt |
203 |
title="$ndxnam[$choice]" |
204 |
subtitle="$subtitle" |
205 |
greg |
1.7 |
Bdata= |
206 |
0 $bcdlvl[$choice] |
207 |
360 $bcdlvl[$choice] |
208 |
209 |
Blabel="BCD level" |
210 |
greg |
1.1 |
Adata= |
211 |
_EOF_ |
212 |
getinfo - < $gndxfile >> $plotfile |
213 |
igraph $plotfile |
214 |
endif |
215 |
endif |
216 |
end |
217 |
quit: |
218 |
rm -f $tempfiles |
219 |
exit 0 |
