root/radiance/ray/src/util/glare.csh
Revision: 2.4
Committed: Sat Feb 22 02:07:30 2003 UTC (21 years, 1 month ago) by greg
Content type: application/x-csh
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
1 #!/bin/csh -f
2 # RCSid: $Id$
3 #
4 # Interactive program for calculating glare values
5 #
6 set fgargs=(-v)
7 set nofile="none"
8 set octree=$nofile
9 set picture=$nofile
10 set glarefile=$nofile
11 if ($#argv >= 1) then
12 set glarefile=$argv[1]
13 if ($#argv >= 2) then
14 set picture=$argv[2]
15 if ($#argv >= 3) then
16 set octree=$argv[3]
17 endif
18 endif
19 endif
20 set rtargs=
21 set view=
22 set threshold=300
23 set maxangle=0
24 set stepangle=10
25
26 set gndxfile="glr$$.ndx"
27 set plotfile="glr$$.plt"
28 set tempfiles=($gndxfile $plotfile)
29
30 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
31
32 onintr quit
33
34 cat <<_EOF_
35 This script provides a convenient interface to the glare calculation
36 and analysis programs. It works on a single output file from findglare,
37 which you must either create here or have created already before.
38 _EOF_
39 while ( $glarefile == $nofile )
40 echo ""
41 echo "Please specify a glare file, or use ^C to exit."
42 readvar glarefile
43 end
44 if ( ! -f $glarefile ) then
45 echo ""
46 echo -n "The glare file '$glarefile' doesn't exist -- shall we create it? "
47 if ("$<" =~ [nN]*) exit 0
48 cat <<_EOF_
49
50 A glare file can be created from a wide-angle Radiance picture (preferably
51 a fisheye view), an octree, or both. Computing glare source locations
52 from a finished image is faster, but using an octree is more reliable
53 since all of the scene information is there. Whenever it is possible,
54 you should use both a picture and an octree to compute the glare file.
55
56 You must also have a viewpoint and direction for the glare calculation.
57 If the viewpoint is not the same as the picture, an error will result.
58 If no view is specified, the view parameters are taken from the picture,
59 so the view specification is optional unless you are starting from an
60 octree.
61
62 _EOF_
63 if ( $picture == $nofile ) then
64 readvar picture
65 endif
66 if ( $octree == $nofile ) then
67 readvar octree
68 endif
69 readvar view
70 if ( $picture == $nofile && $octree == $nofile ) then
71 echo "You must specify a picture or an octree"
72 exit 1
73 endif
74 if ( $picture == $nofile && "$view" == "" ) then
75 echo "You must give a view if there is no picture"
76 exit 1
77 endif
78 if ( $picture != $nofile ) then
79 if ( ! -r $picture ) then
80 echo "Cannot read $picture"
81 exit 1
82 endif
83 set fgargs=($fgargs -p $picture)
84 if ( "$view" != "" ) then
85 set view=(-vf $picture $view)
86 endif
87 endif
88 set fgargs=($fgargs $view)
89 if ( $octree != $nofile ) then
90 if ( ! -r $octree ) then
91 echo "Cannot read $octree"
92 exit 1
93 endif
94 cat <<_EOF_
95
96 With an octree, you should give the same options for -av, -ab and
97 so forth as are used to render the scene. Please enter them below.
98
99 _EOF_
100 if ($picture != $nofile) then
101 echo "These are the parameters from the picture:"
102 getinfo $picture
103 endif
104 readvar rtargs
105 set fgargs=($fgargs $rtargs $octree)
106 endif
107 echo ""
108 echo -n "Do you expect glare sources in the scene to be small? "
109 if ("$<" =~ [yY]) then
110 echo -n "Very small? "
111 if ("$<" =~ [yY]) then
112 set fgargs=(-r 400 $fgargs)
113 else
114 set fgargs=(-r 250 $fgargs)
115 endif
116 echo -n "Are these sources relatively bright? "
117 if ("$<" =~ [nN]*) then
118 set fgargs=(-c $fgargs)
119 endif
120 endif
121 cat <<_EOF_
122
123 Glare sources are determined by a threshold level. Any part of the
124 view that is above this threshold is considered to be part of a glare
125 source. If you do not choose a threshold value, it will be set auto-
126 matically to 7 times the average field luminance (in candelas/sq.meter).
127
128 _EOF_
129 echo -n "Do you wish to set the glare threshold manually? "
130 if ("$<" =~ [yY]) then
131 readvar threshold
132 set fgargs=(-t $threshold $fgargs)
133 endif
134 cat <<_EOF_
135
136 It is often desirable to know how glare changes as a function of
137 viewing direction. If you like, you can compute glare for up
138 to 180 degrees to the left and right of the view center. Enter
139 the maximum angle that you would like to compute below.
140
141 _EOF_
142 readvar maxangle
143 if ( $maxangle >= $stepangle ) then
144 set fgargs=(-ga $stepangle-$maxangle\:$stepangle $fgargs)
145 endif
146 echo ""
147 echo "Starting calculation..."
148 echo findglare $fgargs
149 findglare $fgargs > $glarefile
150 if ($status) then
151 echo "Uh-oh. Something went wrong with findglare\!"
152 rm $glarefile
153 exit 1
154 endif
155 endif
156 if ($?DISPLAY && $picture != $nofile) then
157 echo ""
158 echo "Displaying glare sources in '$picture'..."
159 xglaresrc $picture $glarefile
160 endif
161 set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index" "BRS Glare Index" "Unified Glare Rating" "Daylight Glare Index")
162 set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi" "glarendx -t brs_gi" "glarendx -t ugr" "glarendx -t dgi")
163 set bcdlvl=(50 124 18.5 18.5 18.5 21.7)
164 while ( 1 )
165 echo ""
166 echo " 0. Quit"
167 set i=1
168 while ($i <= $#ndxnam)
169 echo " $i. $ndxnam[$i]"
170 @ i++
171 end
172 echo ""
173 set choice=0
174 readvar choice
175 if ($choice < 1 || $choice > $#ndxcom) goto quit
176 $ndxcom[$choice] $glarefile > $gndxfile
177 echo ""
178 echo $ndxnam[$choice]
179 echo "Angle Value"
180 getinfo - < $gndxfile
181 echo ""
182 set save_file=$nofile
183 readvar save_file
184 if ($save_file != $nofile) then
185 cp -i $gndxfile $save_file
186 endif
187 if ( `getinfo - < $gndxfile | wc -l` > 4 ) then
188 echo ""
189 echo -n "Do you want to plot this data? "
190 if ( "$<" =~ [yY]* ) then
191 set subtitle="$view"
192 if ($picture != $nofile) then
193 set subtitle="$picture $subtitle"
194 else if ($octree != $nofile) then
195 set subtitle="$subtitle $octree"
196 endif
197 if ( "$subtitle" == "" ) then
198 set subtitle="`getinfo < $glarefile | grep findglare`"
199 endif
200 cat <<_EOF_ > $plotfile
201 include=line.plt
202 include=polar.plt
203 title="$ndxnam[$choice]"
204 subtitle="$subtitle"
205 Bdata=
206 0 $bcdlvl[$choice]
207 360 $bcdlvl[$choice]
208 ;
209 Blabel="BCD level"
210 Adata=
211 _EOF_
212 getinfo - < $gndxfile >> $plotfile
213 igraph $plotfile
214 endif
215 endif
216 end
217 quit:
218 rm -f $tempfiles
219 exit 0
