root/radiance/ray/src/util/glare.csh
Revision: 1.9
Committed: Fri May 3 12:50:42 1991 UTC (34 years, 1 month ago) by greg
Content type: application/x-csh
Changes since 1.8: +1 -9 lines
added call to ximage if xglaresrc can't find window
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive program for calculating glare values
5 #
6 set fgargs=(-v)
7 set nofile="none"
8 set octree=$nofile
9 set picture=$nofile
10 if ($#argv >= 1) then
11 set glarefile=$argv[1]
12 else
13 set glarefile=$nofile
14 endif
15 set rtargs=
16 set view=
17 set threshold=300
18 set maxangle=0
19 set stepangle=10
20
21 set gndxfile="glr$$.ndx"
22 set plotfile="glr$$.plt"
23 set tempfiles=($gndxfile $plotfile)
24
25 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
26
27 onintr quit
28
29 cat <<_EOF_
30 This script provides a convenient interface to the glare calculation
31 and analysis programs. It works on a single output file from findglare,
32 which you must either create here or have created already before.
33 _EOF_
34 while ( $glarefile == $nofile )
35 echo ""
36 echo "Please specify a glare file, or use ^C to exit."
37 readvar glarefile
38 end
39 if ( ! -f $glarefile ) then
40 echo ""
41 echo -n "The glare file '$glarefile' doesn't exist -- shall we create it? "
42 if ("$<" =~ [nN]*) exit 0
43 cat <<_EOF_
44
45 A glare file can be created from a wide-angle Radiance picture (preferably
46 a fisheye view), an octree, or both. Computing glare source locations
47 from a finished image is faster, but using an octree is more reliable
48 since all of the scene information is there. Whenever it is possible,
49 you should use both a picture and an octree to compute the glare file.
50
51 You must also have a viewpoint and direction for the glare calculation.
52 If the viewpoint is not the same as the picture, an error will result.
53 If no view is specified, the view parameters are taken from the picture,
54 so the view specification is optional unless you are starting from an
55 octree.
56
57 _EOF_
58 readvar picture
59 readvar octree
60 readvar view
61 if ( $picture == $nofile && $octree == $nofile ) then
62 echo "You must specify a picture or an octree"
63 exit 1
64 endif
65 if ( $picture == $nofile && "$view" == "" ) then
66 echo "You must give a view if there is no picture"
67 exit 1
68 endif
69 if ( $picture != $nofile ) then
70 if ( ! -r $picture ) then
71 echo "Cannot read $picture"
72 exit 1
73 endif
74 set fgargs=($fgargs -p $picture -vf $picture)
75 endif
76 set fgargs=($fgargs $view)
77 if ( $octree != $nofile ) then
78 if ( ! -r $octree ) then
79 echo "Cannot read $octree"
80 exit 1
81 endif
82 cat <<_EOF_
83
84 With an octree, you should give the same options for -av, -ab and
85 so forth as are used to render the scene. Please enter them below.
86
87 _EOF_
88 readvar rtargs
89 set fgargs=($fgargs $rtargs $octree)
90 endif
91 echo ""
92 echo -n "Do you expect glare sources in the scene to be small? "
93 if ("$<" =~ [yY]) then
94 echo -n "Very small? "
95 if ("$<" =~ [yY]) then
96 set fgargs=(-r 400 $fgargs)
97 else
98 set fgargs=(-r 250 $fgargs)
99 endif
100 echo -n "Are these sources relatively bright? "
101 if ("$<" =~ [nN]*) then
102 set fgargs=(-c $fgargs)
103 endif
104 endif
105 cat <<_EOF_
106
107 Glare sources are determined by a threshold level. Any part of the
108 view that is above this threshold is considered to be part of a glare
109 source. If you do not choose a threshold value, it will be set auto-
110 matically to 7 times the average field luminance (in candelas/sq.meter).
111
112 _EOF_
113 echo -n "Do you wish to set the glare threshold manually? "
114 if ("$<" =~ [yY]) then
115 readvar threshold
116 set fgargs=(-t $threshold $fgargs)
117 endif
118 cat <<_EOF_
119
120 It is often desirable to know how glare changes as a function of
121 viewing direction. If you like, you can compute glare for up
122 to 180 degrees to the left and right of the view center. Enter
123 the maximum angle that you would like to compute below.
124
125 _EOF_
126 readvar maxangle
127 if ( $maxangle >= $stepangle ) then
128 set fgargs=(-ga $stepangle-$maxangle\:$stepangle $fgargs)
129 endif
130 echo ""
131 echo "Starting calculation..."
132 echo findglare $fgargs
133 findglare $fgargs > $glarefile
134 endif
135 if ($?DISPLAY && $picture != $nofile) then
136 echo ""
137 echo "Displaying glare sources in '$picture'..."
138 xglaresrc $picture $glarefile
139 endif
140 set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index")
141 set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi")
142 set bcdlvl=(50 124 18.5)
143 while ( 1 )
144 echo ""
145 echo " 0. Quit"
146 set i=1
147 while ($i <= $#ndxnam)
148 echo " $i. $ndxnam[$i]"
149 @ i++
150 end
151 echo ""
152 set choice=0
153 readvar choice
154 if ($choice < 1 || $choice > $#ndxcom) goto quit
155 $ndxcom[$choice] $glarefile > $gndxfile
156 echo ""
157 echo $ndxnam[$choice]
158 echo "Angle Value"
159 getinfo - < $gndxfile
160 echo ""
161 set save_file=$nofile
162 readvar save_file
163 if ($save_file != $nofile) then
164 cp -i $gndxfile $save_file
165 endif
166 if ( `getinfo - < $gndxfile | wc -l` > 4 ) then
167 echo ""
168 echo -n "Do you want to plot this data? "
169 if ( "$<" =~ [yY]* ) then
170 set subtitle="$view"
171 if ($picture != $nofile) then
172 set subtitle="$picture $subtitle"
173 else if ($octree != $nofile) then
174 set subtitle="$subtitle $octree"
175 endif
176 if ( "$subtitle" == "" ) then
177 set subtitle="`getinfo < $glarefile | grep findglare`"
178 endif
179 cat <<_EOF_ > $plotfile
180 include=line.plt
181 include=polar.plt
182 title="$ndxnam[$choice]"
183 subtitle="$subtitle"
184 Bdata=
185 0 $bcdlvl[$choice]
186 360 $bcdlvl[$choice]
187 ;
188 Blabel="BCD level"
189 Adata=
190 _EOF_
191 getinfo - < $gndxfile >> $plotfile
192 igraph $plotfile
193 endif
194 endif
195 end
196 quit:
197 rm -f $tempfiles
198 exit 0
