--- ray/src/util/glare.csh 1991/05/03 12:50:42 1.9 +++ ray/src/util/glare.csh 1995/05/02 10:23:42 2.2 @@ -7,10 +7,15 @@ set fgargs=(-v) set nofile="none" set octree=$nofile set picture=$nofile +set glarefile=$nofile if ($#argv >= 1) then set glarefile=$argv[1] -else - set glarefile=$nofile + if ($#argv >= 2) then + set picture=$argv[2] + if ($#argv >= 3) then + set octree=$argv[3] + endif + endif endif set rtargs= set view= @@ -55,8 +60,12 @@ so the view specification is optional unless you are s octree. _EOF_ - readvar picture - readvar octree + if ( $picture == $nofile ) then + readvar picture + endif + if ( $octree == $nofile ) then + readvar octree + endif readvar view if ( $picture == $nofile && $octree == $nofile ) then echo "You must specify a picture or an octree" @@ -71,7 +80,10 @@ _EOF_ echo "Cannot read $picture" exit 1 endif - set fgargs=($fgargs -p $picture -vf $picture) + set fgargs=($fgargs -p $picture) + if ( "$view" != "" ) then + set view=(-vf $picture $view) + endif endif set fgargs=($fgargs $view) if ( $octree != $nofile ) then @@ -85,6 +97,10 @@ With an octree, you should give the same options for - so forth as are used to render the scene. Please enter them below. _EOF_ + if ($picture != $nofile) then + echo "These are the parameters from the picture:" + getinfo $picture + endif readvar rtargs set fgargs=($fgargs $rtargs $octree) endif @@ -131,6 +147,11 @@ _EOF_ echo "Starting calculation..." echo findglare $fgargs findglare $fgargs > $glarefile + if ($status) then + echo "Uh-oh. Something went wrong with findglare\!" + rm $glarefile + exit 1 + endif endif if ($?DISPLAY && $picture != $nofile) then echo ""
