--- ray/src/util/glare.csh 1991/05/02 13:21:02 1.5 +++ ray/src/util/glare.csh 1991/11/12 17:19:24 2.1 @@ -62,12 +62,19 @@ _EOF_ echo "You must specify a picture or an octree" exit 1 endif + if ( $picture == $nofile && "$view" == "" ) then + echo "You must give a view if there is no picture" + exit 1 + endif if ( $picture != $nofile ) then if ( ! -r $picture ) then echo "Cannot read $picture" exit 1 endif - set fgargs=($fgargs -p $picture -vf $picture) + set fgargs=($fgargs -p $picture) + if ( "$view" != "" ) then + set view=(-vf $picture $view) + endif endif set fgargs=($fgargs $view) if ( $octree != $nofile ) then @@ -81,6 +88,10 @@ With an octree, you should give the same options for - so forth as are used to render the scene. Please enter them below. _EOF_ + if ($picture != $nofile) then + echo "These are the parameters from the picture:" + getinfo $picture + endif readvar rtargs set fgargs=($fgargs $rtargs $octree) endif @@ -127,19 +138,20 @@ _EOF_ echo "Starting calculation..." echo findglare $fgargs findglare $fgargs > $glarefile + if ($status) then + echo "Uh-oh. Something went wrong with findglare\!" + rm $glarefile + exit 1 + endif endif if ($?DISPLAY && $picture != $nofile) then echo "" echo "Displaying glare sources in '$picture'..." - xglaresrc $picture $glarefile >& /dev/null - if ($status) then - x11image =+0+0 -g 2.6 $picture & - sleep 40 - xglaresrc $picture $glarefile - endif + xglaresrc $picture $glarefile endif set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index") set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi") +set bcdlvl=(50 124 18.5) while ( 1 ) echo "" echo " 0. Quit" @@ -181,6 +193,11 @@ include=line.plt include=polar.plt title="$ndxnam[$choice]" subtitle="$subtitle" +Bdata= + 0 $bcdlvl[$choice] + 360 $bcdlvl[$choice] +; +Blabel="BCD level" Adata= _EOF_ getinfo - < $gndxfile >> $plotfile
