--- ray/src/util/glare.csh 1991/11/12 12:07:24 1.11 +++ ray/src/util/glare.csh 1995/09/08 11:07:46 2.3 @@ -7,10 +7,15 @@ set fgargs=(-v) set nofile="none" set octree=$nofile set picture=$nofile +set glarefile=$nofile if ($#argv >= 1) then set glarefile=$argv[1] -else - set glarefile=$nofile + if ($#argv >= 2) then + set picture=$argv[2] + if ($#argv >= 3) then + set octree=$argv[3] + endif + endif endif set rtargs= set view= @@ -55,8 +60,12 @@ so the view specification is optional unless you are s octree. _EOF_ - readvar picture - readvar octree + if ( $picture == $nofile ) then + readvar picture + endif + if ( $octree == $nofile ) then + readvar octree + endif readvar view if ( $picture == $nofile && $octree == $nofile ) then echo "You must specify a picture or an octree" @@ -149,9 +158,9 @@ if ($?DISPLAY && $picture != $nofile) then echo "Displaying glare sources in '$picture'..." xglaresrc $picture $glarefile endif -set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index") -set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi") -set bcdlvl=(50 124 18.5) +set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index" "BRS Glare Index" "Unified Glare Rating" "Daylight Glare Index") +set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi" "glarendx -t brs_gi" "glarendx -t ugr" "glarendx -t dgi") +set bcdlvl=(50 124 18.5 18.5 18.5 21.7) while ( 1 ) echo "" echo " 0. Quit"
