--- ray/src/util/glare.csh 1991/04/24 18:27:08 1.1 +++ ray/src/util/glare.csh 1991/05/02 15:32:06 1.6 @@ -53,6 +53,7 @@ If the viewpoint is not the same as the picture, an er If no view is specified, the view parameters are taken from the picture, so the view specification is optional unless you are starting from an octree. + _EOF_ readvar picture readvar octree @@ -61,6 +62,10 @@ _EOF_ echo "You must specify a picture or an octree" exit 1 endif + if ( $picture == $nofile && "$view" == "" ) then + echo "You must give a view if there is no picture" + exit 1 + endif if ( $picture != $nofile ) then if ( ! -r $picture ) then echo "Cannot read $picture" @@ -90,9 +95,9 @@ _EOF_ if ("$<" =~ [yY]) then set fgargs=(-r 400 $fgargs) else - set fgargs=(-r 200 $fgargs) + set fgargs=(-r 250 $fgargs) endif - echo -n "Are these sources very bright? " + echo -n "Are these sources relatively bright? " if ("$<" =~ [nN]*) then set fgargs=(-c $fgargs) endif @@ -130,15 +135,15 @@ endif if ($?DISPLAY && $picture != $nofile) then echo "" echo "Displaying glare sources in '$picture'..." - xglaresrc $picture $glarefile + xglaresrc $picture $glarefile >& /dev/null if ($status) then x11image =+0+0 -g 2.6 $picture & sleep 40 xglaresrc $picture $glarefile endif endif -set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio") -set ndxcom=(guth_vcp guth_dgr) +set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index") +set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi") while ( 1 ) echo "" echo " 0. Quit" @@ -172,7 +177,11 @@ while ( 1 ) else if ($octree != $nofile) then set subtitle="$subtitle $octree" endif + if ( "$subtitle" == "" ) then + set subtitle="`getinfo < $glarefile | grep findglare`" + endif cat <<_EOF_ > $plotfile +include=line.plt include=polar.plt title="$ndxnam[$choice]" subtitle="$subtitle"
