--- ray/src/util/glare.csh 1991/04/24 18:27:08 1.1 +++ ray/src/util/glare.csh 1991/05/01 12:17:57 1.4 @@ -53,6 +53,7 @@ If the viewpoint is not the same as the picture, an er If no view is specified, the view parameters are taken from the picture, so the view specification is optional unless you are starting from an octree. + _EOF_ readvar picture readvar octree @@ -90,9 +91,9 @@ _EOF_ if ("$<" =~ [yY]) then set fgargs=(-r 400 $fgargs) else - set fgargs=(-r 200 $fgargs) + set fgargs=(-r 250 $fgargs) endif - echo -n "Are these sources very bright? " + echo -n "Are these sources relatively bright? " if ("$<" =~ [nN]*) then set fgargs=(-c $fgargs) endif @@ -130,7 +131,7 @@ endif if ($?DISPLAY && $picture != $nofile) then echo "" echo "Displaying glare sources in '$picture'..." - xglaresrc $picture $glarefile + xglaresrc $picture $glarefile >& /dev/null if ($status) then x11image =+0+0 -g 2.6 $picture & sleep 40 @@ -172,7 +173,11 @@ while ( 1 ) else if ($octree != $nofile) then set subtitle="$subtitle $octree" endif + if ( "$subtitle" == "" ) then + set subtitle="`getinfo < $glarefile | grep findglare`" + endif cat <<_EOF_ > $plotfile +include=line.plt include=polar.plt title="$ndxnam[$choice]" subtitle="$subtitle"
