root/radiance/ray/src/util/glare.csh
Revision: 1.11
Committed: Tue Nov 12 12:07:24 1991 UTC (33 years, 7 months ago) by greg
Content type: application/x-csh
Changes since 1.10: +9 -1 lines
added findglare error trap and modified view parameter setting
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive program for calculating glare values
5 #
6 set fgargs=(-v)
7 set nofile="none"
8 set octree=$nofile
9 set picture=$nofile
10 if ($#argv >= 1) then
11 set glarefile=$argv[1]
12 else
13 set glarefile=$nofile
14 endif
15 set rtargs=
16 set view=
17 set threshold=300
18 set maxangle=0
19 set stepangle=10
20
21 set gndxfile="glr$$.ndx"
22 set plotfile="glr$$.plt"
23 set tempfiles=($gndxfile $plotfile)
24
25 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
26
27 onintr quit
28
29 cat <<_EOF_
30 This script provides a convenient interface to the glare calculation
31 and analysis programs. It works on a single output file from findglare,
32 which you must either create here or have created already before.
33 _EOF_
34 while ( $glarefile == $nofile )
35 echo ""
36 echo "Please specify a glare file, or use ^C to exit."
37 readvar glarefile
38 end
39 if ( ! -f $glarefile ) then
40 echo ""
41 echo -n "The glare file '$glarefile' doesn't exist -- shall we create it? "
42 if ("$<" =~ [nN]*) exit 0
43 cat <<_EOF_
44
45 A glare file can be created from a wide-angle Radiance picture (preferably
46 a fisheye view), an octree, or both. Computing glare source locations
47 from a finished image is faster, but using an octree is more reliable
48 since all of the scene information is there. Whenever it is possible,
49 you should use both a picture and an octree to compute the glare file.
50
51 You must also have a viewpoint and direction for the glare calculation.
52 If the viewpoint is not the same as the picture, an error will result.
53 If no view is specified, the view parameters are taken from the picture,
54 so the view specification is optional unless you are starting from an
55 octree.
56
57 _EOF_
58 readvar picture
59 readvar octree
60 readvar view
61 if ( $picture == $nofile && $octree == $nofile ) then
62 echo "You must specify a picture or an octree"
63 exit 1
64 endif
65 if ( $picture == $nofile && "$view" == "" ) then
66 echo "You must give a view if there is no picture"
67 exit 1
68 endif
69 if ( $picture != $nofile ) then
70 if ( ! -r $picture ) then
71 echo "Cannot read $picture"
72 exit 1
73 endif
74 set fgargs=($fgargs -p $picture)
75 if ( "$view" != "" ) then
76 set view=(-vf $picture $view)
77 endif
78 endif
79 set fgargs=($fgargs $view)
80 if ( $octree != $nofile ) then
81 if ( ! -r $octree ) then
82 echo "Cannot read $octree"
83 exit 1
84 endif
85 cat <<_EOF_
86
87 With an octree, you should give the same options for -av, -ab and
88 so forth as are used to render the scene. Please enter them below.
89
90 _EOF_
91 if ($picture != $nofile) then
92 echo "These are the parameters from the picture:"
93 getinfo $picture
94 endif
95 readvar rtargs
96 set fgargs=($fgargs $rtargs $octree)
97 endif
98 echo ""
99 echo -n "Do you expect glare sources in the scene to be small? "
100 if ("$<" =~ [yY]) then
101 echo -n "Very small? "
102 if ("$<" =~ [yY]) then
103 set fgargs=(-r 400 $fgargs)
104 else
105 set fgargs=(-r 250 $fgargs)
106 endif
107 echo -n "Are these sources relatively bright? "
108 if ("$<" =~ [nN]*) then
109 set fgargs=(-c $fgargs)
110 endif
111 endif
112 cat <<_EOF_
113
114 Glare sources are determined by a threshold level. Any part of the
115 view that is above this threshold is considered to be part of a glare
116 source. If you do not choose a threshold value, it will be set auto-
117 matically to 7 times the average field luminance (in candelas/sq.meter).
118
119 _EOF_
120 echo -n "Do you wish to set the glare threshold manually? "
121 if ("$<" =~ [yY]) then
122 readvar threshold
123 set fgargs=(-t $threshold $fgargs)
124 endif
125 cat <<_EOF_
126
127 It is often desirable to know how glare changes as a function of
128 viewing direction. If you like, you can compute glare for up
129 to 180 degrees to the left and right of the view center. Enter
130 the maximum angle that you would like to compute below.
131
132 _EOF_
133 readvar maxangle
134 if ( $maxangle >= $stepangle ) then
135 set fgargs=(-ga $stepangle-$maxangle\:$stepangle $fgargs)
136 endif
137 echo ""
138 echo "Starting calculation..."
139 echo findglare $fgargs
140 findglare $fgargs > $glarefile
141 if ($status) then
142 echo "Uh-oh. Something went wrong with findglare\!"
143 rm $glarefile
144 exit 1
145 endif
146 endif
147 if ($?DISPLAY && $picture != $nofile) then
148 echo ""
149 echo "Displaying glare sources in '$picture'..."
150 xglaresrc $picture $glarefile
151 endif
152 set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio" "CIE Glare Index")
153 set ndxcom=("glarendx -t guth_vcp" "glarendx -t guth_dgr" "glarendx -t cie_cgi")
154 set bcdlvl=(50 124 18.5)
155 while ( 1 )
156 echo ""
157 echo " 0. Quit"
158 set i=1
159 while ($i <= $#ndxnam)
160 echo " $i. $ndxnam[$i]"
161 @ i++
162 end
163 echo ""
164 set choice=0
165 readvar choice
166 if ($choice < 1 || $choice > $#ndxcom) goto quit
167 $ndxcom[$choice] $glarefile > $gndxfile
168 echo ""
169 echo $ndxnam[$choice]
170 echo "Angle Value"
171 getinfo - < $gndxfile
172 echo ""
173 set save_file=$nofile
174 readvar save_file
175 if ($save_file != $nofile) then
176 cp -i $gndxfile $save_file
177 endif
178 if ( `getinfo - < $gndxfile | wc -l` > 4 ) then
179 echo ""
180 echo -n "Do you want to plot this data? "
181 if ( "$<" =~ [yY]* ) then
182 set subtitle="$view"
183 if ($picture != $nofile) then
184 set subtitle="$picture $subtitle"
185 else if ($octree != $nofile) then
186 set subtitle="$subtitle $octree"
187 endif
188 if ( "$subtitle" == "" ) then
189 set subtitle="`getinfo < $glarefile | grep findglare`"
190 endif
191 cat <<_EOF_ > $plotfile
192 include=line.plt
193 include=polar.plt
194 title="$ndxnam[$choice]"
195 subtitle="$subtitle"
196 Bdata=
197 0 $bcdlvl[$choice]
198 360 $bcdlvl[$choice]
199 ;
200 Blabel="BCD level"
201 Adata=
202 _EOF_
203 getinfo - < $gndxfile >> $plotfile
204 igraph $plotfile
205 endif
206 endif
207 end
208 quit:
209 rm -f $tempfiles
210 exit 0
