root/radiance/ray/src/util/glare.csh
CVS Tags: HEAD, rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Diff to previous 2.3 , to selected 1.11
Fri Sep 8 11:07:46 1995 UTC (28 years, 8 months ago) by greg
Diff to previous 2.2 , to selected 1.11
added menu entries for new glare indices
Tue May 2 10:23:42 1995 UTC (29 years ago) by greg
Changes since 2.1: +13 -4 lines
Diff to previous 2.1 , to selected 1.11
made glare take second and third argument (picture and octree)
Tue Nov 12 17:19:24 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.11
Revision 1.11 - (view) (download) (as text) (annotate) - [selected]
Tue Nov 12 12:07:24 1991 UTC (32 years, 5 months ago) by greg
Changes since 1.10: +9 -1 lines
Diff to previous 1.10
added findglare error trap and modified view parameter setting
Revision 1.10 - (view) (download) (as text) (annotate) - [select for diffs]
Wed May 8 11:08:01 1991 UTC (33 years ago) by greg
Changes since 1.9: +4 -0 lines
Diff to previous 1.9 , to selected 1.11
added getinfo call to print parameters of picture
Revision 1.9 - (view) (download) (as text) (annotate) - [select for diffs]
Fri May 3 12:50:42 1991 UTC (33 years ago) by greg
Changes since 1.8: +1 -9 lines
Diff to previous 1.8 , to selected 1.11
added call to ximage if xglaresrc can't find window
Fri May 3 10:06:06 1991 UTC (33 years ago) by greg
Changes since 1.7: +7 -4 lines
Diff to previous 1.7 , to selected 1.11
made xglaresrc work better with glare
Revision 1.7 - (view) (download) (as text) (annotate) - [select for diffs]
Thu May 2 16:07:22 1991 UTC (33 years ago) by greg
Changes since 1.6: +6 -0 lines
Diff to previous 1.6 , to selected 1.11
added BCD level to plots
Thu May 2 15:32:06 1991 UTC (33 years ago) by greg
Changes since 1.5: +4 -0 lines
Diff to previous 1.5 , to selected 1.11
added missing error message
Thu May 2 13:21:02 1991 UTC (33 years ago) by greg
Diff to previous 1.4 , to selected 1.11
added CIE CGI (Einhorn) glare calculation
Wed May 1 12:17:57 1991 UTC (33 years ago) by greg
Diff to previous 1.3 , to selected 1.11
changed wording
Tue Apr 30 16:26:11 1991 UTC (33 years ago) by greg
Diff to previous 1.2 , to selected 1.11
changed resolution parameters for small sources
Revision 1.2 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Apr 29 08:31:21 1991 UTC (33 years ago) by greg
Changes since 1.1: +6 -1 lines
Diff to previous 1.1 , to selected 1.11
minor bug fixes
Wed Apr 24 18:27:08 1991 UTC (33 years ago) by greg
Diff to selected 1.11
Links to HEAD: (view) (download) (as text) (annotate) Links to rad3R6P1: (view) (download) (as text) (annotate)
