root/radiance/ray/src/util/glare.csh
Revision: 1.2
Committed: Mon Apr 29 08:31:21 1991 UTC (33 years, 1 month ago) by greg
Content type: application/x-csh
Changes since 1.1: +6 -1 lines
minor bug fixes
1 #!/bin/csh -f
2 # SCCSid "$SunId$ LBL"
3 #
4 # Interactive program for calculating glare values
5 #
6 set fgargs=(-v)
7 set nofile="none"
8 set octree=$nofile
9 set picture=$nofile
10 if ($#argv >= 1) then
11 set glarefile=$argv[1]
12 else
13 set glarefile=$nofile
14 endif
15 set rtargs=
16 set view=
17 set threshold=300
18 set maxangle=0
19 set stepangle=10
20
21 set gndxfile="glr$$.ndx"
22 set plotfile="glr$$.plt"
23 set tempfiles=($gndxfile $plotfile)
24
25 alias readvar 'echo -n Enter \!:1 "[$\!:1]: ";set ans="$<";if("$ans" != "")set \!:1="$ans"'
26
27 onintr quit
28
29 cat <<_EOF_
30 This script provides a convenient interface to the glare calculation
31 and analysis programs. It works on a single output file from findglare,
32 which you must either create here or have created already before.
33 _EOF_
34 while ( $glarefile == $nofile )
35 echo ""
36 echo "Please specify a glare file, or use ^C to exit."
37 readvar glarefile
38 end
39 if ( ! -f $glarefile ) then
40 echo ""
41 echo -n "The glare file '$glarefile' doesn't exist -- shall we create it? "
42 if ("$<" =~ [nN]*) exit 0
43 cat <<_EOF_
44
45 A glare file can be created from a wide-angle Radiance picture (preferably
46 a fisheye view), an octree, or both. Computing glare source locations
47 from a finished image is faster, but using an octree is more reliable
48 since all of the scene information is there. Whenever it is possible,
49 you should use both a picture and an octree to compute the glare file.
50
51 You must also have a viewpoint and direction for the glare calculation.
52 If the viewpoint is not the same as the picture, an error will result.
53 If no view is specified, the view parameters are taken from the picture,
54 so the view specification is optional unless you are starting from an
55 octree.
56
57 _EOF_
58 readvar picture
59 readvar octree
60 readvar view
61 if ( $picture == $nofile && $octree == $nofile ) then
62 echo "You must specify a picture or an octree"
63 exit 1
64 endif
65 if ( $picture != $nofile ) then
66 if ( ! -r $picture ) then
67 echo "Cannot read $picture"
68 exit 1
69 endif
70 set fgargs=($fgargs -p $picture -vf $picture)
71 endif
72 set fgargs=($fgargs $view)
73 if ( $octree != $nofile ) then
74 if ( ! -r $octree ) then
75 echo "Cannot read $octree"
76 exit 1
77 endif
78 cat <<_EOF_
79
80 With an octree, you should give the same options for -av, -ab and
81 so forth as are used to render the scene. Please enter them below.
82
83 _EOF_
84 readvar rtargs
85 set fgargs=($fgargs $rtargs $octree)
86 endif
87 echo ""
88 echo -n "Do you expect glare sources in the scene to be small? "
89 if ("$<" =~ [yY]) then
90 echo -n "Very small? "
91 if ("$<" =~ [yY]) then
92 set fgargs=(-r 400 $fgargs)
93 else
94 set fgargs=(-r 200 $fgargs)
95 endif
96 echo -n "Are these sources very bright? "
97 if ("$<" =~ [nN]*) then
98 set fgargs=(-c $fgargs)
99 endif
100 endif
101 cat <<_EOF_
102
103 Glare sources are determined by a threshold level. Any part of the
104 view that is above this threshold is considered to be part of a glare
105 source. If you do not choose a threshold value, it will be set auto-
106 matically to 7 times the average field luminance (in candelas/sq.meter).
107
108 _EOF_
109 echo -n "Do you wish to set the glare threshold manually? "
110 if ("$<" =~ [yY]) then
111 readvar threshold
112 set fgargs=(-t $threshold $fgargs)
113 endif
114 cat <<_EOF_
115
116 It is often desirable to know how glare changes as a function of
117 viewing direction. If you like, you can compute glare for up
118 to 180 degrees to the left and right of the view center. Enter
119 the maximum angle that you would like to compute below.
120
121 _EOF_
122 readvar maxangle
123 if ( $maxangle >= $stepangle ) then
124 set fgargs=(-ga $stepangle-$maxangle\:$stepangle $fgargs)
125 endif
126 echo ""
127 echo "Starting calculation..."
128 echo findglare $fgargs
129 findglare $fgargs > $glarefile
130 endif
131 if ($?DISPLAY && $picture != $nofile) then
132 echo ""
133 echo "Displaying glare sources in '$picture'..."
134 xglaresrc $picture $glarefile >& /dev/null
135 if ($status) then
136 x11image =+0+0 -g 2.6 $picture &
137 sleep 40
138 xglaresrc $picture $glarefile
139 endif
140 endif
141 set ndxnam=("Guth Visual Comfort Probability" "Guth Disability Glare Ratio")
142 set ndxcom=(guth_vcp guth_dgr)
143 while ( 1 )
144 echo ""
145 echo " 0. Quit"
146 set i=1
147 while ($i <= $#ndxnam)
148 echo " $i. $ndxnam[$i]"
149 @ i++
150 end
151 echo ""
152 set choice=0
153 readvar choice
154 if ($choice < 1 || $choice > $#ndxcom) goto quit
155 $ndxcom[$choice] $glarefile > $gndxfile
156 echo ""
157 echo $ndxnam[$choice]
158 echo "Angle Value"
159 getinfo - < $gndxfile
160 echo ""
161 set save_file=$nofile
162 readvar save_file
163 if ($save_file != $nofile) then
164 cp -i $gndxfile $save_file
165 endif
166 if ( `getinfo - < $gndxfile | wc -l` > 4 ) then
167 echo ""
168 echo -n "Do you want to plot this data? "
169 if ( "$<" =~ [yY]* ) then
170 set subtitle="$view"
171 if ($picture != $nofile) then
172 set subtitle="$picture $subtitle"
173 else if ($octree != $nofile) then
174 set subtitle="$subtitle $octree"
175 endif
176 if ( "$subtitle" == "" ) then
177 set subtitle="`getinfo < $glarefile | grep findglare`"
178 endif
179 cat <<_EOF_ > $plotfile
180 include=line.plt
181 include=polar.plt
182 title="$ndxnam[$choice]"
183 subtitle="$subtitle"
184 Adata=
185 _EOF_
186 getinfo - < $gndxfile >> $plotfile
187 igraph $plotfile
188 endif
189 endif
190 end
191 quit:
192 rm -f $tempfiles
193 exit 0
