root/Development/ray/src/util/getinfo.c
Revision: 2.23
Committed: Mon Mar 21 00:21:13 2022 UTC (3 years, 10 months ago) by greg
Changes since 2.22: +120 -66 lines
feat(getinfo): Added getinfo -r option (similar to -a but with remove/replace)
2 static const char RCSid[] = "$Id: getinfo.c,v 2.22 2022/03/03 22:54:49 greg Exp $";
5 * getinfo.c - program to read info. header from file.
6 *
7 * 1/3/86
8 */
9
10 #include <ctype.h>
11 #include "rtio.h"
12 #include "platform.h"
13 #include "rtprocess.h"
14 #include "resolu.h"
15
16 static char fmt[MAXFMTLEN] = "*";
17
18
19 static int
20 tabstr( /* put out line followed by tab */
21 char *s,
22 void *p
23 )
24 {
25 while (*s) {
26 putchar(*s);
27 s++;
28 }
29 if (*--s == '\n')
30 fputc('\t', stdout);
31 return(0);
32 }
33
34
35 static int
36 adjheadline( /* check for lines to remove */
37 char *s,
38 void *p
39 )
40 {
41 char **av;
42
43 if (formatval(fmt, s))
44 return(0); /* don't echo format */
45
46 /* check for match to skip */
47 for (av = (char **)p; *av; av++) {
48 char *s1 = s;
49 char *s2 = *av;
50 if (isspace(*s2)) {
51 if (!isspace(*s1))
52 continue;
53 while (isspace(*++s1)) ;
54 while (isspace(*++s2)) ;
55 }
56 while (*s2 && *s1 == *s2) {
57 if ((*s1 == '=') & (s1 > s))
58 return(0);
59 if (isspace(*s2))
60 break;
61 s1++; s2++;
62 }
63 if (s1 == s)
64 continue;
65 if (isspace(*s1) && !*s2 | isspace(*s2))
66 return(0); /* skip */
67 }
68 fputs(s, stdout); /* copy if no match */
69 return(0);
70 }
71
72
73 static void
74 getdim( /* get dimensions from file */
75 FILE *fp
76 )
77 {
78 int j;
79 int c;
80
81 switch (c = getc(fp)) {
82 case '+': /* picture */
83 case '-':
84 do
85 putchar(c);
86 while (c != '\n' && (c = getc(fp)) != EOF);
87 break;
88 case 1: /* octree */
89 getc(fp);
90 j = 0;
91 while ((c = getc(fp)) != EOF)
92 if (c == 0) {
93 if (++j >= 4)
94 break;
95 fputc(' ', stdout);
96 } else {
97 putchar(c);
98 }
99 fputc('\n', stdout);
100 break;
101 default: /* ??? */
102 fputs("unknown file type\n", stdout);
103 break;
104 }
105 }
106
107
108 static void
109 copycat(void) /* copy input to output */
110 {
111 char buf[8192];
112 int n;
113
114 fflush(stdout);
115 while ((n = fread(buf, 1, sizeof(buf), stdin)) > 0)
116 if (writebuf(fileno(stdout), buf, n) != n)
117 break;
118 }
119
120
121 int
122 main(
123 int argc,
124 char **argv
125 )
126 {
127 int dim = 0;
128 FILE *fp;
129 int i;
130
131 if (argc > 1 && (argv[1][0] == '-') | (argv[1][0] == '+') &&
132 argv[1][1] == 'd') {
133 dim = 1 - 2*(argv[1][0] == '-');
134 argc--; argv++;
135 }
136 #ifdef getc_unlocked /* avoid lock/unlock overhead */
137 flockfile(stdin);
138 #endif
139 SET_FILE_BINARY(stdin);
140 if (argc > 2 && !strcmp(argv[1], "-c")) {
141 SET_FILE_BINARY(stdout);
142 setvbuf(stdin, NULL, _IONBF, 2);
143 if (checkheader(stdin, fmt, stdout) < 0) {
144 fputs("Bad header!\n", stderr);
145 return 1;
146 }
147 printargs(argc-2, argv+2, stdout);
148 if (fmt[0] != '*') /* better be the same! */
149 fputformat(fmt, stdout);
150 fputc('\n', stdout);
151 if (dim) { /* copy resolution string? */
152 RESOLU rs;
153 if (!fgetsresolu(&rs, stdin)) {
154 fputs("No resolution string!\n", stderr);
155 return 1;
156 }
157 if (dim > 0)
158 fputsresolu(&rs, stdout);
159 }
160 fflush(stdout);
161 execvp(argv[2], argv+2);
162 perror(argv[2]);
163 return 1;
164 }
165 if (argc > 2 && !strcmp(argv[1], "-a")) {
166 SET_FILE_BINARY(stdout);
167 if (checkheader(stdin, fmt, stdout) < 0) {
168 fputs("Bad header!\n", stderr);
169 return 1;
170 }
171 for (i = 2; i < argc; i++) {
172 int len = strlen(argv[i]);
173 if (!len) continue;
174 fputs(argv[i], stdout);
175 if (argv[i][len-1] != '\n')
176 fputc('\n', stdout);
177 }
178 if (fmt[0] != '*')
179 fputformat(fmt, stdout);
180 fputc('\n', stdout);
181 copycat();
182 return 0;
183 }
184 if (argc > 2 && !strcmp(argv[1], "-r")) {
185 SET_FILE_BINARY(stdout);
186 if (getheader(stdin, adjheadline, argv+2) < 0) {
187 fputs("Bad header!\n", stderr);
188 return 1;
189 }
190 for (i = 2; i < argc; i++) { /* add lines w/ var[= ]value */
191 int len = strlen(argv[i]);
192 int strt = 0, j;
193 while(isspace(argv[i][strt])) strt++;
194 if (strt == len) continue;
195 while (isspace(argv[i][len-1])) len--;
196 for (j = strt+1; j < len-1; j++)
197 if (argv[i][j] == '=' || isspace(argv[i][j])) {
198 for (j = 0; j < len; j++)
199 putchar(argv[i][j]);
200 fputc('\n', stdout);
201 break;
202 }
203 }
204 if (fmt[0] != '*')
205 fputformat(fmt, stdout);
206 fputc('\n', stdout);
207 copycat();
208 return 0;
209 }
210 if (argc == 2 && !strcmp(argv[1], "-")) {
211 SET_FILE_BINARY(stdout);
212 if (getheader(stdin, NULL, NULL) < 0) {
213 fputs("Bad header!\n", stderr);
214 return 1;
215 }
216 if (dim < 0) { /* skip resolution string? */
217 RESOLU rs;
218 if (!fgetsresolu(&rs, stdin)) {
219 fputs("No resolution string!\n", stderr);
220 return 1;
221 }
222 }
223 copycat();
224 return 0;
225 }
226 for (i = 1; i < argc; i++) {
227 fputs(argv[i], stdout);
228 if ((fp = fopen(argv[i], "r")) == NULL)
229 fputs(": cannot open\n", stdout);
230 else {
231 if (dim < 0) { /* dimensions only */
232 if (getheader(fp, NULL, NULL) < 0) {
233 fputs("bad header!\n", stdout);
234 continue;
235 }
236 fputs(": ", stdout);
237 getdim(fp);
238 } else {
239 tabstr(":\n", NULL);
240 if (getheader(fp, tabstr, NULL) < 0) {
241 fputs(argv[i], stderr);
242 fputs(": bad header!\n", stderr);
243 return 1;
244 }
245 fputc('\n', stdout);
246 if (dim > 0) {
247 fputc('\t', stdout);
248 getdim(fp);
249 }
250 }
251 fclose(fp);
252 }
253 }
254 if (argc == 1) {
255 if (dim < 0) {
256 if (getheader(stdin, NULL, NULL) < 0) {
257 fputs("Bad header!\n", stderr);
258 return 1;
259 }
260 getdim(stdin);
261 } else {
262 if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) {
263 fputs("Bad header!\n", stderr);
264 return 1;
265 }
266 fputc('\n', stdout);
267 if (dim > 0)
268 getdim(stdin);
269 }
270 }
271 return 0;
272 }
