--- ray/src/util/getinfo.c 2003/06/05 19:29:35 2.6 +++ ray/src/util/getinfo.c 2022/03/03 22:54:49 2.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: getinfo.c,v 2.6 2003/06/05 19:29:35 schorsch Exp $"; +static const char RCSid[] = "$Id: getinfo.c,v 2.22 2022/03/03 22:54:49 greg Exp $"; #endif /* * getinfo.c - program to read info. header from file. @@ -7,15 +7,30 @@ static const char RCSid[] = "$Id: getinfo.c,v 2.6 2003 * 1/3/86 */ -#include - +#include "rtio.h" #include "platform.h" +#include "rtprocess.h" +#include "resolu.h" +#ifdef getc_unlocked /* avoid nasty file-locking overhead */ +#undef getc +#undef getchar +#undef putchar +#define getc getc_unlocked +#define getchar getchar_unlocked +#define putchar putchar_unlocked +#endif +static gethfunc tabstr; +static void getdim(FILE *fp); +static void copycat(void); -int -tabstr(s) /* put out line followed by tab */ -register char *s; + +static int +tabstr( /* put out line followed by tab */ + char *s, + void *p +) { while (*s) { putchar(*s); @@ -27,61 +42,142 @@ register char *s; } -main(argc, argv) -int argc; -char **argv; +int +main( + int argc, + char **argv +) { int dim = 0; + char fmt[MAXFMTLEN]; FILE *fp; int i; - if (argc > 1 && !strcmp(argv[1], "-d")) { + if (argc > 1 && (argv[1][0] == '-') | (argv[1][0] == '+') && + argv[1][1] == 'd') { + dim = 1 - 2*(argv[1][0] == '-'); argc--; argv++; - dim = 1; - SET_DEFAULT_BINARY(); /* for output file */ - SET_FILE_BINARY(stdin); + } +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(stdin); +#endif + SET_FILE_BINARY(stdin); + fmt[0] = '*'; fmt[1] = '\0'; + if (argc > 2 && !strcmp(argv[1], "-c")) { + SET_FILE_BINARY(stdout); + setvbuf(stdin, NULL, _IONBF, 2); + if (checkheader(stdin, fmt, stdout) < 0) { + fputs("Bad header!\n", stderr); + return 1; + } + printargs(argc-2, argv+2, stdout); + if (fmt[0] != '*') /* better be the same! */ + fputformat(fmt, stdout); + fputc('\n', stdout); + if (dim) { /* copy resolution string? */ + RESOLU rs; + if (!fgetsresolu(&rs, stdin)) { + fputs("No resolution string!\n", stderr); + return 1; + } + if (dim > 0) + fputsresolu(&rs, stdout); + } + fflush(stdout); + execvp(argv[2], argv+2); + perror(argv[2]); + return 1; + } else if (argc > 2 && !strcmp(argv[1], "-a")) { + SET_FILE_BINARY(stdout); + if (checkheader(stdin, fmt, stdout) < 0) { + fputs("Bad header!\n", stderr); + return 1; + } + for (i = 2; i < argc; i++) { + int len = strlen(argv[i]); + if (!len) continue; + fputs(argv[i], stdout); + if (argv[i][len-1] != '\n') + fputc('\n', stdout); + } + if (fmt[0] != '*') + fputformat(fmt, stdout); + fputc('\n', stdout); + copycat(); + return 0; } else if (argc == 2 && !strcmp(argv[1], "-")) { - SET_FILE_BINARY(stdin); SET_FILE_BINARY(stdout); - getheader(stdin, NULL, NULL); + if (getheader(stdin, NULL, NULL) < 0) { + fputs("Bad header!\n", stderr); + return 1; + } + if (dim < 0) { /* skip resolution string? */ + RESOLU rs; + if (!fgetsresolu(&rs, stdin)) { + fputs("No resolution string!\n", stderr); + return 1; + } + } copycat(); - exit(0); + return 0; } for (i = 1; i < argc; i++) { fputs(argv[i], stdout); if ((fp = fopen(argv[i], "r")) == NULL) fputs(": cannot open\n", stdout); else { - if (dim) { + if (dim < 0) { /* dimensions only */ + if (getheader(fp, NULL, NULL) < 0) { + fputs("bad header!\n", stdout); + continue; + } fputs(": ", stdout); getdim(fp); } else { - tabstr(":\n"); - getheader(fp, tabstr, NULL); - putchar('\n'); + tabstr(":\n", NULL); + if (getheader(fp, tabstr, NULL) < 0) { + fputs(argv[i], stderr); + fputs(": bad header!\n", stderr); + return 1; + } + fputc('\n', stdout); + if (dim > 0) { + fputc('\t', stdout); + getdim(fp); + } } fclose(fp); } } - if (argc == 1) - if (dim) { + if (argc == 1) { + if (dim < 0) { + if (getheader(stdin, NULL, NULL) < 0) { + fputs("Bad header!\n", stderr); + return 1; + } getdim(stdin); } else { - getheader(stdin, fputs, stdout); - putchar('\n'); + if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) { + fputs("Bad header!\n", stderr); + return 1; + } + fputc('\n', stdout); + if (dim > 0) + getdim(stdin); } - exit(0); + } + return 0; } -getdim(fp) /* get dimensions from file */ -register FILE *fp; +static void +getdim( /* get dimensions from file */ + FILE *fp +) { int j; - register int c; + int c; - getheader(fp, NULL, NULL); /* skip header */ - switch (c = getc(fp)) { case '+': /* picture */ case '-': @@ -93,13 +189,13 @@ register FILE *fp; getc(fp); j = 0; while ((c = getc(fp)) != EOF) - if (c == 0) + if (c == 0) { if (++j >= 4) break; - else - putchar(' '); - else + putchar(' '); + } else { putchar(c); + } putchar('\n'); break; default: /* ??? */ @@ -109,10 +205,14 @@ register FILE *fp; } -copycat() /* copy input to output */ +static void +copycat(void) /* copy input to output */ { - register int c; + char buf[8192]; + int n; - while ((c = getchar()) != EOF) - putchar(c); + fflush(stdout); + while ((n = fread(buf, 1, sizeof(buf), stdin)) > 0) + if (writebuf(fileno(stdout), buf, n) != n) + break; }
