--- ray/src/util/getinfo.c 2019/07/16 17:07:35 2.19 +++ ray/src/util/getinfo.c 2022/04/13 15:43:06 2.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: getinfo.c,v 2.19 2019/07/16 17:07:35 greg Exp $"; +static const char RCSid[] = "$Id: getinfo.c,v 2.25 2022/04/13 15:43:06 greg Exp $"; #endif /* * getinfo.c - program to read info. header from file. @@ -7,27 +7,15 @@ static const char RCSid[] = "$Id: getinfo.c,v 2.19 201 * 1/3/86 */ -#include -#include - +#include +#include "rtio.h" #include "platform.h" #include "rtprocess.h" #include "resolu.h" -#ifdef getc_unlocked /* avoid nasty file-locking overhead */ -#undef getc -#undef getchar -#undef putchar -#define getc getc_unlocked -#define getchar getchar_unlocked -#define putchar putchar_unlocked -#endif +static char fmt[MAXFMTLEN] = "*"; -static gethfunc tabstr; -static void getdim(FILE *fp); -static void copycat(void); - static int tabstr( /* put out line followed by tab */ char *s, @@ -39,11 +27,99 @@ tabstr( /* put out line followed by tab */ s++; } if (*--s == '\n') - putchar('\t'); + fputc('\t', stdout); return(0); } +static int +adjheadline( /* check for lines to remove */ + char *s, + void *p +) +{ + char **av; + + if (formatval(fmt, s)) + return(0); /* don't echo format */ + + /* check for match to skip */ + for (av = (char **)p; *av; av++) { + char *s1 = s; + char *s2 = *av; + if (isspace(*s2)) { + if (!isspace(*s1)) + continue; + while (isspace(*++s1)) ; + while (isspace(*++s2)) ; + } + while (*s2 && *s1 == *s2) { + if ((*s1 == '=') & (s1 > s)) + return(0); + if (isspace(*s2)) + break; + s1++; s2++; + } + if (s1 == s) + continue; + if ((*s1 == '=') & !*s2) + return(0); + if (isspace(*s1) & isspace(*s2)) + return(0); + } + fputs(s, stdout); /* copy if no match */ + return(0); +} + + +static void +getdim( /* get dimensions from file */ + FILE *fp +) +{ + int j; + int c; + + switch (c = getc(fp)) { + case '+': /* picture */ + case '-': + do + putchar(c); + while (c != '\n' && (c = getc(fp)) != EOF); + break; + case 1: /* octree */ + getc(fp); + j = 0; + while ((c = getc(fp)) != EOF) + if (c == 0) { + if (++j >= 4) + break; + fputc(' ', stdout); + } else { + putchar(c); + } + fputc('\n', stdout); + break; + default: /* ??? */ + fputs("unknown file type\n", stdout); + break; + } +} + + +static void +copycat(void) /* copy input to output */ +{ + char buf[8192]; + int n; + + fflush(stdout); + while ((n = fread(buf, 1, sizeof(buf), stdin)) > 0) + if (writebuf(fileno(stdout), buf, n) != n) + break; +} + + int main( int argc, @@ -61,19 +137,24 @@ main( } #ifdef getc_unlocked /* avoid lock/unlock overhead */ flockfile(stdin); + flockfile(stdout); #endif SET_FILE_BINARY(stdin); if (argc > 2 && !strcmp(argv[1], "-c")) { SET_FILE_BINARY(stdout); setvbuf(stdin, NULL, _IONBF, 2); - if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) + if (checkheader(stdin, fmt, stdout) < 0) { + fputs("Bad header!\n", stderr); return 1; + } printargs(argc-2, argv+2, stdout); + if (fmt[0] != '*') /* better be the same! */ + fputformat(fmt, stdout); fputc('\n', stdout); if (dim) { /* copy resolution string? */ RESOLU rs; if (!fgetsresolu(&rs, stdin)) { - fputs("No resolution string\n", stderr); + fputs("No resolution string!\n", stderr); return 1; } if (dim > 0) @@ -83,10 +164,13 @@ main( execvp(argv[2], argv+2); perror(argv[2]); return 1; - } else if (argc > 2 && !strcmp(argv[1], "-a")) { + } + if (argc > 2 && !strcmp(argv[1], "-a")) { SET_FILE_BINARY(stdout); - if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) + if (checkheader(stdin, fmt, stdout) < 0) { + fputs("Bad header!\n", stderr); return 1; + } for (i = 2; i < argc; i++) { int len = strlen(argv[i]); if (!len) continue; @@ -94,17 +178,48 @@ main( if (argv[i][len-1] != '\n') fputc('\n', stdout); } + if (fmt[0] != '*') + fputformat(fmt, stdout); fputc('\n', stdout); copycat(); return 0; - } else if (argc == 2 && !strcmp(argv[1], "-")) { + } + if (argc > 2 && !strcmp(argv[1], "-r")) { SET_FILE_BINARY(stdout); - if (getheader(stdin, NULL, NULL) < 0) + if (getheader(stdin, adjheadline, argv+2) < 0) { + fputs("Bad header!\n", stderr); return 1; + } + for (i = 2; i < argc; i++) { /* add lines w/ var[= ]value */ + int len = strlen(argv[i]); + int strt = 0, j; + while(isspace(argv[i][strt])) strt++; + if (strt == len) continue; + while (isspace(argv[i][len-1])) len--; + for (j = strt+1; j < len-1; j++) + if (argv[i][j] == '=' || isspace(argv[i][j])) { + for (j = 0; j < len; j++) + putchar(argv[i][j]); + fputc('\n', stdout); + break; + } + } + if (fmt[0] != '*') + fputformat(fmt, stdout); + fputc('\n', stdout); + copycat(); + return 0; + } + if (argc == 2 && !strcmp(argv[1], "-")) { + SET_FILE_BINARY(stdout); + if (getheader(stdin, NULL, NULL) < 0) { + fputs("Bad header!\n", stderr); + return 1; + } if (dim < 0) { /* skip resolution string? */ RESOLU rs; if (!fgetsresolu(&rs, stdin)) { - fputs("No resolution string\n", stderr); + fputs("No resolution string!\n", stderr); return 1; } } @@ -116,17 +231,23 @@ main( if ((fp = fopen(argv[i], "r")) == NULL) fputs(": cannot open\n", stdout); else { +#ifdef getc_unlocked /* avoid lock/unlock overhead */ + flockfile(fp); +#endif if (dim < 0) { /* dimensions only */ if (getheader(fp, NULL, NULL) < 0) { - fputs("bad header\n", stdout); + fputs("bad header!\n", stdout); continue; } fputs(": ", stdout); getdim(fp); } else { tabstr(":\n", NULL); - if (getheader(fp, tabstr, NULL) < 0) + if (getheader(fp, tabstr, NULL) < 0) { + fputs(argv[i], stderr); + fputs(": bad header!\n", stderr); return 1; + } fputc('\n', stdout); if (dim > 0) { fputc('\t', stdout); @@ -138,64 +259,20 @@ main( } if (argc == 1) { if (dim < 0) { - if (getheader(stdin, NULL, NULL) < 0) + if (getheader(stdin, NULL, NULL) < 0) { + fputs("Bad header!\n", stderr); return 1; + } getdim(stdin); } else { - if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) + if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) { + fputs("Bad header!\n", stderr); return 1; + } fputc('\n', stdout); if (dim > 0) getdim(stdin); } } return 0; -} - - -static void -getdim( /* get dimensions from file */ - FILE *fp -) -{ - int j; - int c; - - switch (c = getc(fp)) { - case '+': /* picture */ - case '-': - do - putchar(c); - while (c != '\n' && (c = getc(fp)) != EOF); - break; - case 1: /* octree */ - getc(fp); - j = 0; - while ((c = getc(fp)) != EOF) - if (c == 0) { - if (++j >= 4) - break; - putchar(' '); - } else { - putchar(c); - } - putchar('\n'); - break; - default: /* ??? */ - fputs("unknown file type\n", stdout); - break; - } -} - - -static void -copycat(void) /* copy input to output */ -{ - char buf[8192]; - int n; - - fflush(stdout); - while ((n = fread(buf, 1, sizeof(buf), stdin)) > 0) - if (writebuf(fileno(stdout), buf, n) != n) - break; }
