root/Development/ray/src/util/getinfo.c
Revision 2.16 - (view) (download) (annotate) - [selected]
Tue Mar 20 18:18:39 2018 UTC (7 years, 6 months ago) by greg
Diff to previous 2.15
Added redefine of getc()
Tue Mar 20 17:48:16 2018 UTC (7 years, 6 months ago) by greg
Changes since 2.14: +3 -7 lines
Diff to previous 2.14 , to selected 2.16
Replaced write() call with writebuf()
Tue Aug 30 06:10:12 2016 UTC (9 years ago) by greg
Changes since 2.13: +15 -1 lines
Diff to previous 2.13 , to selected 2.16
Added -a option to getinfo for adding lines to header
Sun Mar 6 01:13:18 2016 UTC (9 years, 6 months ago) by schorsch
Diff to previous 2.12 , to selected 2.16
Mon Sep 8 18:21:39 2014 UTC (11 years ago) by greg
Diff to previous 2.11 , to selected 2.16
Turned off input buffering for -c option to avoid issues with lost data
Mon Jul 28 20:12:20 2014 UTC (11 years, 1 month ago) by greg
CVS Tags: rad4R2
Changes since 2.10: +3 -2 lines
Diff to previous 2.10 , to selected 2.16
Fixes for Windows
Mon Jul 28 17:25:03 2014 UTC (11 years, 1 month ago) by greg
Changes since 2.9: +31 -16 lines
Diff to previous 2.9 , to selected 2.16
Sat Jun 9 04:24:16 2012 UTC (13 years, 3 months ago) by greg
Changes since 2.8: +9 -1 lines
Diff to previous 2.8 , to selected 2.16
Changed character i/o calls to unlocked versions
Fri Jan 2 11:44:24 2004 UTC (21 years, 8 months ago) by schorsch
Changes since 2.7: +26 -14 lines
Diff to previous 2.7 , to selected 2.16
Mon Jul 21 22:30:19 2003 UTC (22 years, 2 months ago) by schorsch
Diff to previous 2.6 , to selected 2.16
Thu Jun 5 19:29:35 2003 UTC (22 years, 3 months ago) by schorsch
Changes since 2.5: +6 -13 lines
Diff to previous 2.5 , to selected 2.16
Sat Feb 22 02:07:30 2003 UTC (22 years, 7 months ago) by greg
Changes since 2.4: +1 -4 lines
Diff to previous 2.4 , to selected 2.16
Tue Oct 27 08:47:17 1998 UTC (26 years, 10 months ago) by gwlarson
Diff to previous 2.3 , to selected 2.16
Thu Nov 12 10:06:11 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.2: +8 -4 lines
Diff to previous 2.2 , to selected 2.16
Changes for 32-bit PC port
Mon Sep 21 12:13:25 1992 UTC (33 years ago) by greg
Changes since 2.1: +10 -2 lines
Diff to previous 2.1 , to selected 2.16
Changes for PC port
Tue Nov 12 16:05:05 1991 UTC (33 years, 10 months ago) by greg
Diff to previous 1.3 , to selected 2.16
Thu Apr 18 14:35:06 1991 UTC (34 years, 5 months ago) by greg
Diff to previous 1.2 , to selected 2.16
Thu Jun 28 16:39:32 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +13 -0 lines
Diff to previous 1.1 , to selected 2.16
added - option to elide header
Thu Feb 2 10:49:19 1989 UTC (36 years, 7 months ago) by greg
Diff to selected 2.16
