fix(getinfo): More consistent behavior using -r option
perf(getinfo): Added a couple of missing calls to flockfile()
feat(getinfo): Added getinfo -r option (similar to -a but with remove/replace)
feat(getinfo): Now preserves byte alignment with -a and -c options
Improved error reporting for bad/illegal headers
Created getinfo +d option for additional flexibility
Made getinfo -d option useful for header-skip ('-') and command ('-c') options
Added error-checking
Added redefine of getc()
Replaced write() call with writebuf()
Added -a option to getinfo for adding lines to header
Turned off input buffering for -c option to avoid issues with lost data
Fixes for Windows
Changed character i/o calls to unlocked versions
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
Changes for 32-bit PC port
Changes for PC port
added - option to elide header
