root/Development/ray/src/util/getinfo.c
Revision: 2.27
Committed: Wed Jun 5 21:56:53 2024 UTC (18 months, 3 weeks ago) by greg
CVS Tags: rad6R0, HEAD
perf(getinfo,rcollate): Removed unnecessary call to fileno() that used semaphore
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.27 static const char RCSid[] = "$Id: getinfo.c,v 2.26 2023/03/16 17:16:05 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * getinfo.c - program to read info. header from file.
6     *
7     * 1/3/86
8     */
9
10 greg 2.23 #include <ctype.h>
11 greg 2.20 #include "rtio.h"
12 schorsch 2.6 #include "platform.h"
13 greg 2.15 #include "rtprocess.h"
14 schorsch 2.8 #include "resolu.h"
15 greg 2.2
16 greg 2.23 static char fmt[MAXFMTLEN] = "*";
17 greg 1.1
18 greg 1.3
19 schorsch 2.8 static int
20     tabstr( /* put out line followed by tab */
21 greg 2.10 char *s,
22 schorsch 2.8 void *p
23     )
24 greg 1.1 {
25     while (*s) {
26     putchar(*s);
27     s++;
28     }
29     if (*--s == '\n')
30 greg 2.23 fputc('\t', stdout);
31     return(0);
32     }
33
34
35     static int
36     adjheadline( /* check for lines to remove */
37     char *s,
38     void *p
39     )
40     {
41     char **av;
42
43     if (formatval(fmt, s))
44     return(0); /* don't echo format */
45
46     /* check for match to skip */
47     for (av = (char **)p; *av; av++) {
48     char *s1 = s;
49     char *s2 = *av;
50     if (isspace(*s2)) {
51     if (!isspace(*s1))
52     continue;
53     while (isspace(*++s1)) ;
54     while (isspace(*++s2)) ;
55     }
56     while (*s2 && *s1 == *s2) {
57     if ((*s1 == '=') & (s1 > s))
58     return(0);
59     if (isspace(*s2))
60     break;
61     s1++; s2++;
62     }
63     if (s1 == s)
64     continue;
65 greg 2.25 if ((*s1 == '=') & !*s2)
66     return(0);
67     if (isspace(*s1) & isspace(*s2))
68     return(0);
69 greg 2.23 }
70     fputs(s, stdout); /* copy if no match */
71 gwlarson 2.4 return(0);
72 greg 1.1 }
73
74
75 greg 2.23 static void
76     getdim( /* get dimensions from file */
77     FILE *fp
78     )
79     {
80     int j;
81     int c;
82
83     switch (c = getc(fp)) {
84     case '+': /* picture */
85     case '-':
86     do
87     putchar(c);
88     while (c != '\n' && (c = getc(fp)) != EOF);
89     break;
90     case 1: /* octree */
91     getc(fp);
92     j = 0;
93     while ((c = getc(fp)) != EOF)
94     if (c == 0) {
95     if (++j >= 4)
96     break;
97     fputc(' ', stdout);
98     } else {
99     putchar(c);
100     }
101     fputc('\n', stdout);
102     break;
103     default: /* ??? */
104     fputs("unknown file type\n", stdout);
105     break;
106     }
107     }
108
109
110     static void
111     copycat(void) /* copy input to output */
112     {
113     char buf[8192];
114     int n;
115
116     fflush(stdout);
117     while ((n = fread(buf, 1, sizeof(buf), stdin)) > 0)
118 greg 2.27 if (writebuf(1, buf, n) != n)
119 greg 2.23 break;
120     }
121
122
123 schorsch 2.8 int
124     main(
125     int argc,
126     char **argv
127     )
128 greg 1.1 {
129     int dim = 0;
130     FILE *fp;
131     int i;
132
133 greg 2.19 if (argc > 1 && (argv[1][0] == '-') | (argv[1][0] == '+') &&
134     argv[1][1] == 'd') {
135     dim = 1 - 2*(argv[1][0] == '-');
136 greg 1.1 argc--; argv++;
137 greg 2.18 }
138     #ifdef getc_unlocked /* avoid lock/unlock overhead */
139     flockfile(stdin);
140 greg 2.24 flockfile(stdout);
141 greg 2.18 #endif
142     SET_FILE_BINARY(stdin);
143     if (argc > 2 && !strcmp(argv[1], "-c")) {
144 greg 2.10 SET_FILE_BINARY(stdout);
145 greg 2.12 setvbuf(stdin, NULL, _IONBF, 2);
146 greg 2.22 if (checkheader(stdin, fmt, stdout) < 0) {
147 greg 2.21 fputs("Bad header!\n", stderr);
148 greg 2.17 return 1;
149 greg 2.21 }
150 greg 2.10 printargs(argc-2, argv+2, stdout);
151 greg 2.22 if (fmt[0] != '*') /* better be the same! */
152     fputformat(fmt, stdout);
153 greg 2.10 fputc('\n', stdout);
154 greg 2.18 if (dim) { /* copy resolution string? */
155     RESOLU rs;
156     if (!fgetsresolu(&rs, stdin)) {
157 greg 2.21 fputs("No resolution string!\n", stderr);
158 greg 2.18 return 1;
159     }
160 greg 2.19 if (dim > 0)
161     fputsresolu(&rs, stdout);
162 greg 2.18 }
163 greg 2.10 fflush(stdout);
164     execvp(argv[2], argv+2);
165     perror(argv[2]);
166     return 1;
167 greg 2.23 }
168     if (argc > 2 && !strcmp(argv[1], "-a")) {
169 greg 2.14 SET_FILE_BINARY(stdout);
170 greg 2.22 if (checkheader(stdin, fmt, stdout) < 0) {
171 greg 2.21 fputs("Bad header!\n", stderr);
172 greg 2.17 return 1;
173 greg 2.21 }
174 greg 2.14 for (i = 2; i < argc; i++) {
175     int len = strlen(argv[i]);
176     if (!len) continue;
177     fputs(argv[i], stdout);
178     if (argv[i][len-1] != '\n')
179     fputc('\n', stdout);
180     }
181 greg 2.22 if (fmt[0] != '*')
182     fputformat(fmt, stdout);
183 greg 2.14 fputc('\n', stdout);
184     copycat();
185     return 0;
186 greg 2.23 }
187     if (argc > 2 && !strcmp(argv[1], "-r")) {
188     SET_FILE_BINARY(stdout);
189     if (getheader(stdin, adjheadline, argv+2) < 0) {
190     fputs("Bad header!\n", stderr);
191     return 1;
192     }
193     for (i = 2; i < argc; i++) { /* add lines w/ var[= ]value */
194     int len = strlen(argv[i]);
195     int strt = 0, j;
196     while(isspace(argv[i][strt])) strt++;
197     if (strt == len) continue;
198     while (isspace(argv[i][len-1])) len--;
199     for (j = strt+1; j < len-1; j++)
200     if (argv[i][j] == '=' || isspace(argv[i][j])) {
201     for (j = 0; j < len; j++)
202     putchar(argv[i][j]);
203     fputc('\n', stdout);
204     break;
205     }
206     }
207     if (fmt[0] != '*')
208     fputformat(fmt, stdout);
209     fputc('\n', stdout);
210     copycat();
211     return 0;
212     }
213     if (argc == 2 && !strcmp(argv[1], "-")) {
214 schorsch 2.6 SET_FILE_BINARY(stdout);
215 greg 2.21 if (getheader(stdin, NULL, NULL) < 0) {
216     fputs("Bad header!\n", stderr);
217 greg 2.17 return 1;
218 greg 2.21 }
219 greg 2.19 if (dim < 0) { /* skip resolution string? */
220 greg 2.18 RESOLU rs;
221     if (!fgetsresolu(&rs, stdin)) {
222 greg 2.21 fputs("No resolution string!\n", stderr);
223 greg 2.18 return 1;
224     }
225     }
226 greg 1.2 copycat();
227 schorsch 2.8 return 0;
228 greg 1.1 }
229     for (i = 1; i < argc; i++) {
230     fputs(argv[i], stdout);
231     if ((fp = fopen(argv[i], "r")) == NULL)
232     fputs(": cannot open\n", stdout);
233     else {
234 greg 2.24 #ifdef getc_unlocked /* avoid lock/unlock overhead */
235     flockfile(fp);
236     #endif
237 greg 2.19 if (dim < 0) { /* dimensions only */
238     if (getheader(fp, NULL, NULL) < 0) {
239 greg 2.26 fputs(": bad header!\n", stdout);
240 greg 2.19 continue;
241     }
242 greg 1.1 fputs(": ", stdout);
243     getdim(fp);
244     } else {
245 schorsch 2.8 tabstr(":\n", NULL);
246 greg 2.21 if (getheader(fp, tabstr, NULL) < 0) {
247     fputs(argv[i], stderr);
248     fputs(": bad header!\n", stderr);
249 greg 2.19 return 1;
250 greg 2.21 }
251 greg 2.10 fputc('\n', stdout);
252 greg 2.19 if (dim > 0) {
253     fputc('\t', stdout);
254     getdim(fp);
255     }
256 greg 1.1 }
257     fclose(fp);
258     }
259     }
260 schorsch 2.7 if (argc == 1) {
261 greg 2.19 if (dim < 0) {
262 greg 2.21 if (getheader(stdin, NULL, NULL) < 0) {
263     fputs("Bad header!\n", stderr);
264 greg 2.19 return 1;
265 greg 2.21 }
266 greg 1.1 getdim(stdin);
267     } else {
268 greg 2.21 if (getheader(stdin, (gethfunc *)fputs, stdout) < 0) {
269     fputs("Bad header!\n", stderr);
270 greg 2.17 return 1;
271 greg 2.21 }
272 greg 2.10 fputc('\n', stdout);
273 greg 2.19 if (dim > 0)
274     getdim(stdin);
275 greg 1.1 }
276 schorsch 2.7 }
277 schorsch 2.8 return 0;
278 greg 1.1 }
