root/radiance/ray/src/util/gethelp3.6.tcl
Revision: 2.7
Committed: Thu Dec 1 12:47:47 1994 UTC (29 years, 4 months ago) by greg
Content type: application/x-tcl
Changes since 2.6: +1 -0 lines
fixed bug caused by incorrect value in curhelp(next)
1 # SCCSid "$SunId$ LBL"
2 #
3 # Get help from a file, formatted like so:
4 #
5 # .category1.topic1
6 #
7 # A bunch of unformatted text...
8 #
9 # .category2.topic2
10 #
11 # etc.
12 #
13
14 # Calling program should define global help file directory as $helplib
15
16 proc helplink {win file cat top} { # Create link for window(s)
17 foreach w $win {
18 bind $w <Control-Button-1> "gethelp $file $cat $top"
19 }
20 }
21
22 set curhelp(file) {}
23
24 proc gethelp {helpfile category topic} { # Open help window
25 global curhelp helpfontwidth
26 if {! [winfo exists .helpwin]} { # Set up window
27 toplevel .helpwin -cursor top_left_arrow
28 wm minsize .helpwin 500 400
29 wm iconbitmap .helpwin question
30 frame .helpwin.but -geometry 150x400
31 pack .helpwin.but -side right -fill none -expand no
32 label .helpwin.but.lab -textvariable curhelp(title)
33 place .helpwin.but.lab -relx .1667 -rely 0
34 helplink .helpwin.but.lab help help intro
35 menubutton .helpwin.but.catb -relief raised -height 1 \
36 -text Category -menu .helpwin.but.catb.m
37 menu .helpwin.but.catb.m
38 place .helpwin.but.catb -relx .1667 -rely .1100 \
39 -relwidth .5000 -relheight .0600
40 helplink .helpwin.but.catb help help category
41 menubutton .helpwin.but.topb -relief raised -height 1 \
42 -text Topic -menu .helpwin.but.topb.m
43 menu .helpwin.but.topb.m
44 place .helpwin.but.topb -relx .1667 -rely .2200 \
45 -relwidth .5000 -relheight .0600
46 helplink .helpwin.but.topb help help topic
47 button .helpwin.but.srchb -text Grep -relief raised \
48 -height 1 -command {helpsearch $curhelp(search)}
49 place .helpwin.but.srchb -relx .1667 -rely .3500 \
50 -relwidth .5000 -relheight .0600
51 helplink .helpwin.but.srchb help navigate search
52 entry .helpwin.but.srche -relief sunken -insertofftime 0 \
53 -textvariable curhelp(search)
54 place .helpwin.but.srche -relx .1667 -rely .4200 \
55 -relwidth .6667 -relheight .0600
56 bind .helpwin.but.srche <Return> {set curhelp(msg) {}
57 helpupdate}
58 helplink .helpwin.but.srche help navigate search
59 label .helpwin.but.msg -textvariable curhelp(msg)
60 place .helpwin.but.msg -relx .1667 -rely .4800
61 button .helpwin.but.next -text Next -relief raised -height 1 \
62 -command {eval helphist new $curhelp(next)}
63 place .helpwin.but.next -relx .1667 -rely .7500 \
64 -relwidth .5 -relheight .0600
65 helplink .helpwin.but.next help navigate next
66 button .helpwin.but.back -text Back -relief raised -height 1 \
67 -command "helphist back"
68 place .helpwin.but.back -relx .1667 -rely .6500 \
69 -relwidth .5 -relheight .0600
70 helplink .helpwin.but.back help navigate back
71 button .helpwin.but.forw -text Forward -relief raised -height 1\
72 -command "helphist forward"
73 place .helpwin.but.forw -relx .1667 -rely .5500 \
74 -relwidth .5 -relheight .0600
75 helplink .helpwin.but.forw help navigate forward
76 button .helpwin.but.done -text Done -relief raised -height 1 \
77 -command "destroy .helpwin ; helpopen {}"
78 place .helpwin.but.done -relx .1667 -rely .9000 \
79 -relwidth .5 -relheight .0600
80 helplink .helpwin.but.done help help done
81 text .helpwin.txt -wrap word -width 48 -height 20 -bd 2 \
82 -yscrollcommand ".helpwin.sb set" -relief raised \
83 -font -*-courier-medium-r-normal--14-*-*-*-*-*-iso8859-1
84 .helpwin.txt tag configure highlight \
85 -font -*-courier-bold-r-normal--14-*-*-*-*-*-iso8859-1
86 set helpfontwidth 9
87 scrollbar .helpwin.sb -relief flat \
88 -command ".helpwin.txt yview"
89 pack .helpwin.sb -side right -fill y
90 pack .helpwin.txt -expand yes -fill both
91 helplink .helpwin.sb help helpwin scroll
92 helplink .helpwin.txt help helpwin intro
93 tkwait visibility .helpwin
94 } elseif {! [winfo ismapped .helpwin]} { # map window
95 wm deiconify .helpwin
96 } else { # raise window
97 raise .helpwin
98 }
99 focus .helpwin.but.srche
100 helpopen $helpfile
101 helphist new $category $topic
102 }
103
104 proc helpopen fname { # open the named help file
105 global curhelp helpindex helplib
106 if {"$fname" == "$curhelp(file)"} {return}
107 if {"$curhelp(file)" != {}} {
108 close $curhelp(fid)
109 unset curhelp helpindex
110 }
111 if {[set curhelp(file) $fname] == {}} {return}
112 # Complete file name as required
113 if {! [info exists helplib]} {
114 set helplib /usr/local/lib/tk/help
115 }
116 if {"[file rootname $fname]" == "$fname"} {
117 append fname .hlp
118 }
119 if {! [string match {[~/.]*} $fname]} {
120 set fname $helplib/$fname
121 }
122 wm title .helpwin $fname
123 set curhelp(title) "[string toupper\
124 [file rootname [file tail $fname]]] HELP"
125 set ifile [file rootname $fname].ndx
126 wm iconname .helpwin [string tolower $curhelp(title)]
127 .helpwin.txt configure -state normal
128 .helpwin.txt delete 1.0 end
129 .helpwin.txt insert end "Loading $fname..."
130 update
131 set curhelp(fid) [open $fname r]
132 if {! [file exists $ifile] ||
133 [file mtime $fname] > [file mtime $ifile]} {
134 set curhelp(catlist) {}
135 while {[gets $curhelp(fid) li] >= 0} {
136 if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
137 $li dummy cat top] {
138 lappend helpindex([string toupper $cat]) $top
139 set helpindex([string toupper $cat,$top]) \
140 [tell $curhelp(fid)]
141 if {[lsearch -exact $curhelp(catlist) $cat] < 0} {
142 lappend curhelp(catlist) $cat
143 }
144 }
145 }
146 if {! [catch {set fi [open $ifile w]}]} {
147 writevars $fi {curhelp(catlist) helpindex}
148 close $fi
149 catch {exec chmod 666 $ifile}
150 }
151 } else {
152 source $ifile
153 }
154 .helpwin.but.catb.m delete 0 last
155 foreach cat $curhelp(catlist) {
156 .helpwin.but.catb.m add command -label $cat \
157 -command "helphist new $cat intro"
158 }
159 set curhelp(category) None
160 .helpwin.but.topb.m delete 0 last
161 set curhelp(topic) None
162 set curhelp(next) {}
163 helphist clear
164 }
165
166 proc helpgoto {cat top} { # find selected category and topic
167 global curhelp helpindex
168 # Capitalize "just in case"
169 set cat [string toupper $cat]
170 set top [string toupper $top]
171 # Change topic menu if category is changed
172 set curhelp(topic) $top
173 if {"$cat" != "$curhelp(category)"} {
174 set curhelp(category) $cat
175 .helpwin.but.topb.m delete 0 last
176 foreach top $helpindex($cat) {
177 .helpwin.but.topb.m add command -label $top \
178 -command "helphist new \$curhelp(category) $top"
179 }
180 }
181 helpupdate
182 }
183
184 proc helpupdate {} { # update help text window
185 global curhelp helpindex helpfontwidth
186 # Print category and topic
187 set linelen [expr "[winfo width .helpwin.txt] / $helpfontwidth - 1"]
188 .helpwin.txt configure -state normal
189 .helpwin.txt delete 1.0 end
190 set titlen [expr [string length $curhelp(category)] + \
191 [string length $curhelp(topic)] + 1]
192 for {set i [expr ($linelen - $titlen)/2]} {[incr i -1] >= 0} {} {
193 .helpwin.txt insert end { }
194 }
195 .helpwin.txt insert end "$curhelp(category) $curhelp(topic)\n"
196 .helpwin.txt tag add highlight "1.0 lineend - $titlen c" "1.0 lineend"
197 # Search for it in file
198 if {"$curhelp(category) $curhelp(topic)" !=
199 "[string toupper $curhelp(next)]"} {
200 if [info exists helpindex($curhelp(category),$curhelp(topic))] {
201 seek $curhelp(fid) $helpindex($curhelp(category),$curhelp(topic))
202 } else {
203 .helpwin.txt insert end "\nNo such help topic."
204 .helpwin.txt configure -state disabled
205 return ".$curhelp(category).$curhelp(topic) not found\
206 in $curhelp(file)"
207 }
208 }
209 # Load help text into our window
210 set linepos 0
211 while {[set ll [gets $curhelp(fid) li]] >= 0 && ! [regexp -nocase \
212 {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
213 $li dummy cat top]} {
214 if {$ll == 0} { # paragraph
215 if $linepos {
216 .helpwin.txt insert end "\n\n"
217 set linepos 0
218 } else {
219 .helpwin.txt insert end "\n"
220 }
221 } else { # line
222 .helpwin.txt insert end $li
223 incr linepos $ll
224 .helpwin.txt insert end { }
225 incr linepos
226 # Highlight search string match
227 if {"$curhelp(search)" != {}} {
228 if [regexp -nocase -indices \
229 $curhelp(search) $li mi] {
230 .helpwin.txt tag add highlight\
231 "end - 1 c - $ll c\
232 + [lindex $mi 0] c"\
233 "end - $ll c\
234 + [lindex $mi 1] c"
235 }
236 }
237 # Add extra space at the end of a sentence
238 if [regexp {[.?!:][)"']?$} $li] {
239 .helpwin.txt insert end { }
240 incr linepos
241 }
242 }
243 }
244 # Highlight next category and topic
245 if {$ll > 0} {
246 .helpwin.txt insert end "Next: $cat $top"
247 .helpwin.txt tag add highlight "end linestart" end
248 set curhelp(next) "$cat $top"
249 .helpwin.but.next configure -state normal
250 } else {
251 set curhelp(next) {}
252 .helpwin.but.next configure -state disabled
253 }
254 .helpwin.txt configure -state disabled
255 return {}
256 }
257
258 proc helphist {op args} { # access help history list
259 global curhelp
260 switch -exact $op {
261 clear {
262 set curhelp(histlst) {}
263 set curhelp(histpos) 0
264 set gotoit 0
265 }
266 new {
267 set curhelp(histpos) \
268 [expr [llength $curhelp(histlst)] - 1]
269 if {"[string toupper [lindex $curhelp(histlst) \
270 $curhelp(histpos)]]"
271 != "[string toupper $args]"} {
272 lappend curhelp(histlst) $args
273 incr curhelp(histpos)
274 }
275 set gotoit 1
276 }
277 append {
278 lappend curhelp(histlst) $args
279 set gotoit 0
280 }
281 back {
282 incr curhelp(histpos) -1
283 set gotoit 1
284 }
285 forward {
286 incr curhelp(histpos) 1
287 set gotoit 1
288 }
289 }
290 if {$curhelp(histpos) + 1 >= [llength $curhelp(histlst)]} {
291 .helpwin.but.forw configure -state disabled
292 } else {
293 .helpwin.but.forw configure -state normal
294 }
295 if {$curhelp(histpos) <= 0} {
296 .helpwin.but.back configure -state disabled
297 } else {
298 .helpwin.but.back configure -state normal
299 }
300 if $gotoit {
301 eval helpgoto [lindex $curhelp(histlst) $curhelp(histpos)]
302 }
303 }
304
305 proc helpsearch word { # search for occurances of the given word
306 global curhelp helpindex
307 if {"$curhelp(search)" == {}} {
308 set curhelp(msg) "No pattern."
309 return 0
310 }
311 set nmatches 0
312 set cat [lindex $curhelp(catlist) 0]
313 set top [lindex $helpindex([string toupper $cat]) 0]
314 set startpos [tell $curhelp(fid)]
315 seek $curhelp(fid) $helpindex([string toupper $cat,$top])
316 set foundmatch 0
317 while {[gets $curhelp(fid) li] >= 0} {
318 if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
319 $li dummy cat top] {
320 set foundmatch 0
321 } elseif {! $foundmatch && \
322 [regexp -nocase $curhelp(search) $li]} {
323 set foundmatch 1
324 if $nmatches {
325 helphist append $cat $top
326 } else {
327 helphist new $cat $top
328 }
329 incr nmatches
330 }
331 }
332 if $nmatches {
333 set curhelp(msg) "$nmatches topic(s)."
334 } else {
335 set curhelp(msg) "Not found."
336 }
337 seek $curhelp(fid) $startpos
338 return $nmatches
339 }
