--- ray/src/util/gethelp3.6.tcl 1994/10/27 15:56:11 2.1 +++ ray/src/util/gethelp3.6.tcl 1995/01/03 16:06:45 2.9 @@ -24,10 +24,10 @@ set curhelp(file) {} proc gethelp {helpfile category topic} { # Open help window global curhelp helpfontwidth if {! [winfo exists .helpwin]} { # Set up window - toplevel .helpwin - wm minsize .helpwin 400 400 + toplevel .helpwin -cursor top_left_arrow + wm minsize .helpwin 500 400 wm iconbitmap .helpwin question - frame .helpwin.but -geometry 200x500 + frame .helpwin.but -geometry 150x400 pack .helpwin.but -side right -fill none -expand no label .helpwin.but.lab -textvariable curhelp(title) place .helpwin.but.lab -relx .1667 -rely 0 @@ -36,23 +36,23 @@ proc gethelp {helpfile category topic} { # Open help w -text Category -menu .helpwin.but.catb.m menu .helpwin.but.catb.m place .helpwin.but.catb -relx .1667 -rely .1100 \ - -relwidth .5000 -relheight .0500 + -relwidth .5000 -relheight .0600 helplink .helpwin.but.catb help help category menubutton .helpwin.but.topb -relief raised -height 1 \ -text Topic -menu .helpwin.but.topb.m menu .helpwin.but.topb.m place .helpwin.but.topb -relx .1667 -rely .2200 \ - -relwidth .5000 -relheight .0500 + -relwidth .5000 -relheight .0600 helplink .helpwin.but.topb help help topic button .helpwin.but.srchb -text Grep -relief raised \ -height 1 -command {helpsearch $curhelp(search)} place .helpwin.but.srchb -relx .1667 -rely .3500 \ - -relwidth .5000 -relheight .0500 + -relwidth .5000 -relheight .0600 helplink .helpwin.but.srchb help navigate search entry .helpwin.but.srche -relief sunken -insertofftime 0 \ -textvariable curhelp(search) place .helpwin.but.srche -relx .1667 -rely .4200 \ - -relwidth .6667 -relheight .0500 + -relwidth .6667 -relheight .0600 bind .helpwin.but.srche {set curhelp(msg) {} helpupdate} helplink .helpwin.but.srche help navigate search @@ -61,29 +61,29 @@ proc gethelp {helpfile category topic} { # Open help w button .helpwin.but.next -text Next -relief raised -height 1 \ -command {eval helphist new $curhelp(next)} place .helpwin.but.next -relx .1667 -rely .7500 \ - -relwidth .5 -relheight .0500 + -relwidth .5 -relheight .0600 helplink .helpwin.but.next help navigate next button .helpwin.but.back -text Back -relief raised -height 1 \ -command "helphist back" place .helpwin.but.back -relx .1667 -rely .6500 \ - -relwidth .5 -relheight .0500 + -relwidth .5 -relheight .0600 helplink .helpwin.but.back help navigate back button .helpwin.but.forw -text Forward -relief raised -height 1\ -command "helphist forward" place .helpwin.but.forw -relx .1667 -rely .5500 \ - -relwidth .5 -relheight .0500 + -relwidth .5 -relheight .0600 helplink .helpwin.but.forw help navigate forward button .helpwin.but.done -text Done -relief raised -height 1 \ -command "destroy .helpwin ; helpopen {}" place .helpwin.but.done -relx .1667 -rely .9000 \ - -relwidth .5 -relheight .0500 + -relwidth .5 -relheight .0600 helplink .helpwin.but.done help help done text .helpwin.txt -wrap word -width 48 -height 20 -bd 2 \ -yscrollcommand ".helpwin.sb set" -relief raised \ - -font -*-courier-medium-r-normal--18-*-*-*-*-*-iso8859-1 + -font -*-courier-medium-r-normal--14-*-*-*-*-*-iso8859-1 .helpwin.txt tag configure highlight \ - -font -*-courier-bold-r-normal--18-*-*-*-*-*-iso8859-1 - set helpfontwidth 11 + -font -*-courier-bold-r-normal--14-*-*-*-*-*-iso8859-1 + set helpfontwidth 9 scrollbar .helpwin.sb -relief flat \ -command ".helpwin.txt yview" pack .helpwin.sb -side right -fill y @@ -91,7 +91,6 @@ proc gethelp {helpfile category topic} { # Open help w helplink .helpwin.sb help helpwin scroll helplink .helpwin.txt help helpwin intro tkwait visibility .helpwin - update } elseif {! [winfo ismapped .helpwin]} { # map window wm deiconify .helpwin } else { # raise window @@ -103,11 +102,11 @@ proc gethelp {helpfile category topic} { # Open help w } proc helpopen fname { # open the named help file - global curhelp helplib + global curhelp helpindex helplib if {"$fname" == "$curhelp(file)"} {return} if {"$curhelp(file)" != {}} { close $curhelp(fid) - unset curhelp + unset curhelp helpindex } if {[set curhelp(file) $fname] == {}} {return} # Complete file name as required @@ -123,21 +122,39 @@ proc helpopen fname { # open the named help file wm title .helpwin $fname set curhelp(title) "[string toupper\ [file rootname [file tail $fname]]] HELP" + set ifile [file rootname $fname].ndx wm iconname .helpwin [string tolower $curhelp(title)] + .helpwin.txt configure -state normal + .helpwin.txt delete 1.0 end + .helpwin.txt insert end "Loading $fname..." + update set curhelp(fid) [open $fname r] - set curhelp(index) {} - set catlist {} - while {[gets $curhelp(fid) li] >= 0} { - if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \ - $li dummy cat top] { - lappend curhelp(index) "$cat $top [tell $curhelp(fid)]" - if {[lsearch -exact $catlist $cat] < 0} { - lappend catlist $cat + if {! [file exists $ifile] || + [file mtime $fname] > [file mtime $ifile]} { + set helpindex(catlist) {} + while {[gets $curhelp(fid) li] >= 0} { + if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \ + $li dummy cat top] { + lappend helpindex([string toupper $cat]) $top + set helpindex([string toupper $cat,$top]) \ + [tell $curhelp(fid)] + if {[lsearch -exact $helpindex(catlist) $cat] < 0} { + lappend helpindex(catlist) $cat + } } } + if {! [catch {set fi [open $ifile w]}]} { + puts $fi "# This is an automatically created index\ + file -- DO NOT EDIT!" + writevars $fi helpindex + close $fi + catch {exec chmod 666 $ifile} + } + } else { + source $ifile } .helpwin.but.catb.m delete 0 last - foreach cat $catlist { + foreach cat $helpindex(catlist) { .helpwin.but.catb.m add command -label $cat \ -command "helphist new $cat intro" } @@ -149,7 +166,7 @@ proc helpopen fname { # open the named help file } proc helpgoto {cat top} { # find selected category and topic - global curhelp + global curhelp helpindex # Capitalize "just in case" set cat [string toupper $cat] set top [string toupper $top] @@ -157,17 +174,8 @@ proc helpgoto {cat top} { # find selected category an set curhelp(topic) $top if {"$cat" != "$curhelp(category)"} { set curhelp(category) $cat - set toplist {} - set n [llength $curhelp(index)] - for {set i 0} {$i < $n} {incr i} { - if {"[string toupper [lindex [lindex \ - $curhelp(index) $i] 0]]" == "$cat"} { - lappend toplist [lindex [lindex \ - $curhelp(index) $i] 1] - } - } .helpwin.but.topb.m delete 0 last - foreach top $toplist { + foreach top $helpindex($cat) { .helpwin.but.topb.m add command -label $top \ -command "helphist new \$curhelp(category) $top" } @@ -176,7 +184,7 @@ proc helpgoto {cat top} { # find selected category an } proc helpupdate {} { # update help text window - global curhelp helpfontwidth + global curhelp helpindex helpfontwidth # Print category and topic set linelen [expr "[winfo width .helpwin.txt] / $helpfontwidth - 1"] .helpwin.txt configure -state normal @@ -191,20 +199,14 @@ proc helpupdate {} { # update help text window # Search for it in file if {"$curhelp(category) $curhelp(topic)" != "[string toupper $curhelp(next)]"} { - for {set i [llength $curhelp(index)]} {[incr i -1] >= 0} {} { - if {"$curhelp(category) $curhelp(topic)" == - [lrange [string toupper [lindex \ - $curhelp(index) $i]] 0 1]} { - break - } - } - if {$i < 0} { + if [info exists helpindex($curhelp(category),$curhelp(topic))] { + seek $curhelp(fid) $helpindex($curhelp(category),$curhelp(topic)) + } else { .helpwin.txt insert end "\nNo such help topic." .helpwin.txt configure -state disabled return ".$curhelp(category).$curhelp(topic) not found\ in $curhelp(file)" } - seek $curhelp(fid) [lindex [lindex $curhelp(index) $i] 2] } # Load help text into our window set linepos 0 @@ -248,6 +250,7 @@ proc helpupdate {} { # update help text window set curhelp(next) "$cat $top" .helpwin.but.next configure -state normal } else { + set curhelp(next) {} .helpwin.but.next configure -state disabled } .helpwin.txt configure -state disabled @@ -302,15 +305,16 @@ proc helphist {op args} { # access help history list } proc helpsearch word { # search for occurances of the given word - global curhelp + global curhelp helpindex if {"$curhelp(search)" == {}} { set curhelp(msg) "No pattern." return 0 } set nmatches 0 - set cat [lindex [lindex $curhelp(index) 0] 0] - set top [lindex [lindex $curhelp(index) 0] 1] - seek $curhelp(fid) [lindex [lindex $curhelp(index) 0] 2] + set cat [lindex $helpindex(catlist) 0] + set top [lindex $helpindex([string toupper $cat]) 0] + set startpos [tell $curhelp(fid)] + seek $curhelp(fid) $helpindex([string toupper $cat,$top]) set foundmatch 0 while {[gets $curhelp(fid) li] >= 0} { if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \ @@ -332,5 +336,6 @@ proc helpsearch word { # search for occurances of the } else { set curhelp(msg) "Not found." } + seek $curhelp(fid) $startpos return $nmatches }
