root/radiance/ray/src/util/gethelp3.6.tcl
Revision 2.13
Wed Oct 26 20:06:17 2011 UTC (13 years, 9 months ago) by greg
FILE REMOVED
Made a few updates to trad
Sat Feb 22 02:07:30 2003 UTC (22 years, 5 months ago) by greg
CVS Tags: rad3R5, rad3R6, rad3R6P1, rad3R7P1, rad3R7P2, rad3R8, rad3R9, rad4R0
Diff to previous 2.11 , to selected 2.3
Tue Oct 17 21:28:18 1995 UTC (29 years, 9 months ago) by greg
Diff to previous 2.10 , to selected 2.3
Mon Jul 24 13:31:24 1995 UTC (30 years ago) by greg
Diff to previous 2.9 , to selected 2.3
changed -geometry specification to -width -height
Tue Jan 3 16:06:45 1995 UTC (30 years, 7 months ago) by greg
added comment to the head of index files
Mon Dec 5 11:40:50 1994 UTC (30 years, 8 months ago) by greg
Changes since 2.7: +6 -6 lines
changed index to use only "helpindex" variable
Thu Dec 1 12:47:47 1994 UTC (30 years, 8 months ago) by greg
Changes since 2.6: +1 -0 lines
fixed bug caused by incorrect value in curhelp(next)
Sun Oct 30 09:05:09 1994 UTC (30 years, 9 months ago) by greg
Changes since 2.5: +20 -9 lines
added index for faster loading of help files
Fri Oct 28 20:14:44 1994 UTC (30 years, 9 months ago) by greg
added local grab to some getfile procedure
Fri Oct 28 19:12:02 1994 UTC (30 years, 9 months ago) by greg
Changes since 2.3: +19 -33 lines
changed indexing to use associative array (faster)
Revision 2.3 - (view) (download) (as text) (annotate) - [selected]
Fri Oct 28 17:17:20 1994 UTC (30 years, 9 months ago) by greg
Changes since 2.2: +12 -10 lines
fixed problems with size on different screens (sort of)
Fri Oct 28 10:02:17 1994 UTC (30 years, 9 months ago) by greg
Changes since 2.1: +9 -6 lines
improved size and font for smaller displays
Thu Oct 27 15:56:11 1994 UTC (30 years, 9 months ago) by greg
Diff to selected 2.3
Links to HEAD: (view) (download) (as text) (annotate)
