--- ray/src/util/gethelp3.6.tcl 1994/10/28 17:17:20 2.3 +++ ray/src/util/gethelp3.6.tcl 1994/10/30 09:05:09 2.6 @@ -24,7 +24,7 @@ set curhelp(file) {} proc gethelp {helpfile category topic} { # Open help window global curhelp helpfontwidth if {! [winfo exists .helpwin]} { # Set up window - toplevel .helpwin + toplevel .helpwin -cursor top_left_arrow wm minsize .helpwin 500 400 wm iconbitmap .helpwin question frame .helpwin.but -geometry 150x400 @@ -102,11 +102,11 @@ proc gethelp {helpfile category topic} { # Open help w } proc helpopen fname { # open the named help file - global curhelp helplib + global curhelp helpindex helplib if {"$fname" == "$curhelp(file)"} {return} if {"$curhelp(file)" != {}} { close $curhelp(fid) - unset curhelp + unset curhelp helpindex } if {[set curhelp(file) $fname] == {}} {return} # Complete file name as required @@ -122,25 +122,37 @@ proc helpopen fname { # open the named help file wm title .helpwin $fname set curhelp(title) "[string toupper\ [file rootname [file tail $fname]]] HELP" + set ifile [file rootname $fname].ndx wm iconname .helpwin [string tolower $curhelp(title)] .helpwin.txt configure -state normal .helpwin.txt delete 1.0 end .helpwin.txt insert end "Loading $fname..." update set curhelp(fid) [open $fname r] - set curhelp(index) {} - set catlist {} - while {[gets $curhelp(fid) li] >= 0} { - if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \ - $li dummy cat top] { - lappend curhelp(index) "$cat $top [tell $curhelp(fid)]" - if {[lsearch -exact $catlist $cat] < 0} { - lappend catlist $cat + if {! [file exists $ifile] || + [file mtime $fname] > [file mtime $ifile]} { + set curhelp(catlist) {} + while {[gets $curhelp(fid) li] >= 0} { + if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \ + $li dummy cat top] { + lappend helpindex([string toupper $cat]) $top + set helpindex([string toupper $cat,$top]) \ + [tell $curhelp(fid)] + if {[lsearch -exact $curhelp(catlist) $cat] < 0} { + lappend curhelp(catlist) $cat + } } } + if {! [catch {set fi [open $ifile w]}]} { + writevars $fi {curhelp(catlist) helpindex} + close $fi + catch {exec chmod 666 $ifile} + } + } else { + source $ifile } .helpwin.but.catb.m delete 0 last - foreach cat $catlist { + foreach cat $curhelp(catlist) { .helpwin.but.catb.m add command -label $cat \ -command "helphist new $cat intro" } @@ -152,7 +164,7 @@ proc helpopen fname { # open the named help file } proc helpgoto {cat top} { # find selected category and topic - global curhelp + global curhelp helpindex # Capitalize "just in case" set cat [string toupper $cat] set top [string toupper $top] @@ -160,17 +172,8 @@ proc helpgoto {cat top} { # find selected category an set curhelp(topic) $top if {"$cat" != "$curhelp(category)"} { set curhelp(category) $cat - set toplist {} - set n [llength $curhelp(index)] - for {set i 0} {$i < $n} {incr i} { - if {"[string toupper [lindex [lindex \ - $curhelp(index) $i] 0]]" == "$cat"} { - lappend toplist [lindex [lindex \ - $curhelp(index) $i] 1] - } - } .helpwin.but.topb.m delete 0 last - foreach top $toplist { + foreach top $helpindex($cat) { .helpwin.but.topb.m add command -label $top \ -command "helphist new \$curhelp(category) $top" } @@ -179,7 +182,7 @@ proc helpgoto {cat top} { # find selected category an } proc helpupdate {} { # update help text window - global curhelp helpfontwidth + global curhelp helpindex helpfontwidth # Print category and topic set linelen [expr "[winfo width .helpwin.txt] / $helpfontwidth - 1"] .helpwin.txt configure -state normal @@ -194,20 +197,14 @@ proc helpupdate {} { # update help text window # Search for it in file if {"$curhelp(category) $curhelp(topic)" != "[string toupper $curhelp(next)]"} { - for {set i [llength $curhelp(index)]} {[incr i -1] >= 0} {} { - if {"$curhelp(category) $curhelp(topic)" == - [lrange [string toupper [lindex \ - $curhelp(index) $i]] 0 1]} { - break - } - } - if {$i < 0} { + if [info exists helpindex($curhelp(category),$curhelp(topic))] { + seek $curhelp(fid) $helpindex($curhelp(category),$curhelp(topic)) + } else { .helpwin.txt insert end "\nNo such help topic." .helpwin.txt configure -state disabled return ".$curhelp(category).$curhelp(topic) not found\ in $curhelp(file)" } - seek $curhelp(fid) [lindex [lindex $curhelp(index) $i] 2] } # Load help text into our window set linepos 0 @@ -305,16 +302,16 @@ proc helphist {op args} { # access help history list } proc helpsearch word { # search for occurances of the given word - global curhelp + global curhelp helpindex if {"$curhelp(search)" == {}} { set curhelp(msg) "No pattern." return 0 } set nmatches 0 - set cat [lindex [lindex $curhelp(index) 0] 0] - set top [lindex [lindex $curhelp(index) 0] 1] + set cat [lindex $curhelp(catlist) 0] + set top [lindex $helpindex([string toupper $cat]) 0] set startpos [tell $curhelp(fid)] - seek $curhelp(fid) [lindex [lindex $curhelp(index) 0] 2] + seek $curhelp(fid) $helpindex([string toupper $cat,$top]) set foundmatch 0 while {[gets $curhelp(fid) li] >= 0} { if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
