root/radiance/ray/src/util/gethelp3.6.tcl
Revision: 2.4
Committed: Fri Oct 28 19:12:02 1994 UTC (29 years, 7 months ago) by greg
Content type: application/x-tcl
Changes since 2.3: +19 -33 lines
changed indexing to use associative array (faster)
1 # SCCSid "$SunId$ LBL"
2 #
3 # Get help from a file, formatted like so:
4 #
5 # .category1.topic1
6 #
7 # A bunch of unformatted text...
8 #
9 # .category2.topic2
10 #
11 # etc.
12 #
13
14 # Calling program should define global help file directory as $helplib
15
16 proc helplink {win file cat top} { # Create link for window(s)
17 foreach w $win {
18 bind $w <Control-Button-1> "gethelp $file $cat $top"
19 }
20 }
21
22 set curhelp(file) {}
23
24 proc gethelp {helpfile category topic} { # Open help window
25 global curhelp helpfontwidth
26 if {! [winfo exists .helpwin]} { # Set up window
27 toplevel .helpwin
28 wm minsize .helpwin 500 400
29 wm iconbitmap .helpwin question
30 frame .helpwin.but -geometry 150x400
31 pack .helpwin.but -side right -fill none -expand no
32 label .helpwin.but.lab -textvariable curhelp(title)
33 place .helpwin.but.lab -relx .1667 -rely 0
34 helplink .helpwin.but.lab help help intro
35 menubutton .helpwin.but.catb -relief raised -height 1 \
36 -text Category -menu .helpwin.but.catb.m
37 menu .helpwin.but.catb.m
38 place .helpwin.but.catb -relx .1667 -rely .1100 \
39 -relwidth .5000 -relheight .0600
40 helplink .helpwin.but.catb help help category
41 menubutton .helpwin.but.topb -relief raised -height 1 \
42 -text Topic -menu .helpwin.but.topb.m
43 menu .helpwin.but.topb.m
44 place .helpwin.but.topb -relx .1667 -rely .2200 \
45 -relwidth .5000 -relheight .0600
46 helplink .helpwin.but.topb help help topic
47 button .helpwin.but.srchb -text Grep -relief raised \
48 -height 1 -command {helpsearch $curhelp(search)}
49 place .helpwin.but.srchb -relx .1667 -rely .3500 \
50 -relwidth .5000 -relheight .0600
51 helplink .helpwin.but.srchb help navigate search
52 entry .helpwin.but.srche -relief sunken -insertofftime 0 \
53 -textvariable curhelp(search)
54 place .helpwin.but.srche -relx .1667 -rely .4200 \
55 -relwidth .6667 -relheight .0600
56 bind .helpwin.but.srche <Return> {set curhelp(msg) {}
57 helpupdate}
58 helplink .helpwin.but.srche help navigate search
59 label .helpwin.but.msg -textvariable curhelp(msg)
60 place .helpwin.but.msg -relx .1667 -rely .4800
61 button .helpwin.but.next -text Next -relief raised -height 1 \
62 -command {eval helphist new $curhelp(next)}
63 place .helpwin.but.next -relx .1667 -rely .7500 \
64 -relwidth .5 -relheight .0600
65 helplink .helpwin.but.next help navigate next
66 button .helpwin.but.back -text Back -relief raised -height 1 \
67 -command "helphist back"
68 place .helpwin.but.back -relx .1667 -rely .6500 \
69 -relwidth .5 -relheight .0600
70 helplink .helpwin.but.back help navigate back
71 button .helpwin.but.forw -text Forward -relief raised -height 1\
72 -command "helphist forward"
73 place .helpwin.but.forw -relx .1667 -rely .5500 \
74 -relwidth .5 -relheight .0600
75 helplink .helpwin.but.forw help navigate forward
76 button .helpwin.but.done -text Done -relief raised -height 1 \
77 -command "destroy .helpwin ; helpopen {}"
78 place .helpwin.but.done -relx .1667 -rely .9000 \
79 -relwidth .5 -relheight .0600
80 helplink .helpwin.but.done help help done
81 text .helpwin.txt -wrap word -width 48 -height 20 -bd 2 \
82 -yscrollcommand ".helpwin.sb set" -relief raised \
83 -font -*-courier-medium-r-normal--14-*-*-*-*-*-iso8859-1
84 .helpwin.txt tag configure highlight \
85 -font -*-courier-bold-r-normal--14-*-*-*-*-*-iso8859-1
86 set helpfontwidth 9
87 scrollbar .helpwin.sb -relief flat \
88 -command ".helpwin.txt yview"
89 pack .helpwin.sb -side right -fill y
90 pack .helpwin.txt -expand yes -fill both
91 helplink .helpwin.sb help helpwin scroll
92 helplink .helpwin.txt help helpwin intro
93 tkwait visibility .helpwin
94 } elseif {! [winfo ismapped .helpwin]} { # map window
95 wm deiconify .helpwin
96 } else { # raise window
97 raise .helpwin
98 }
99 focus .helpwin.but.srche
100 helpopen $helpfile
101 helphist new $category $topic
102 }
103
104 proc helpopen fname { # open the named help file
105 global curhelp helpindex helplib
106 if {"$fname" == "$curhelp(file)"} {return}
107 if {"$curhelp(file)" != {}} {
108 close $curhelp(fid)
109 unset curhelp helpindex
110 }
111 if {[set curhelp(file) $fname] == {}} {return}
112 # Complete file name as required
113 if {! [info exists helplib]} {
114 set helplib /usr/local/lib/tk/help
115 }
116 if {"[file rootname $fname]" == "$fname"} {
117 append fname .hlp
118 }
119 if {! [string match {[~/.]*} $fname]} {
120 set fname $helplib/$fname
121 }
122 wm title .helpwin $fname
123 set curhelp(title) "[string toupper\
124 [file rootname [file tail $fname]]] HELP"
125 wm iconname .helpwin [string tolower $curhelp(title)]
126 .helpwin.txt configure -state normal
127 .helpwin.txt delete 1.0 end
128 .helpwin.txt insert end "Loading $fname..."
129 update
130 set curhelp(fid) [open $fname r]
131 set curhelp(catlist) {}
132 while {[gets $curhelp(fid) li] >= 0} {
133 if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
134 $li dummy cat top] {
135 lappend helpindex([string toupper $cat]) $top
136 set helpindex([string toupper $cat,$top]) \
137 [tell $curhelp(fid)]
138 if {[lsearch -exact $curhelp(catlist) $cat] < 0} {
139 lappend curhelp(catlist) $cat
140 }
141 }
142 }
143 .helpwin.but.catb.m delete 0 last
144 foreach cat $curhelp(catlist) {
145 .helpwin.but.catb.m add command -label $cat \
146 -command "helphist new $cat intro"
147 }
148 set curhelp(category) None
149 .helpwin.but.topb.m delete 0 last
150 set curhelp(topic) None
151 set curhelp(next) {}
152 helphist clear
153 }
154
155 proc helpgoto {cat top} { # find selected category and topic
156 global curhelp helpindex
157 # Capitalize "just in case"
158 set cat [string toupper $cat]
159 set top [string toupper $top]
160 # Change topic menu if category is changed
161 set curhelp(topic) $top
162 if {"$cat" != "$curhelp(category)"} {
163 set curhelp(category) $cat
164 .helpwin.but.topb.m delete 0 last
165 foreach top $helpindex($cat) {
166 .helpwin.but.topb.m add command -label $top \
167 -command "helphist new \$curhelp(category) $top"
168 }
169 }
170 helpupdate
171 }
172
173 proc helpupdate {} { # update help text window
174 global curhelp helpindex helpfontwidth
175 # Print category and topic
176 set linelen [expr "[winfo width .helpwin.txt] / $helpfontwidth - 1"]
177 .helpwin.txt configure -state normal
178 .helpwin.txt delete 1.0 end
179 set titlen [expr [string length $curhelp(category)] + \
180 [string length $curhelp(topic)] + 1]
181 for {set i [expr ($linelen - $titlen)/2]} {[incr i -1] >= 0} {} {
182 .helpwin.txt insert end { }
183 }
184 .helpwin.txt insert end "$curhelp(category) $curhelp(topic)\n"
185 .helpwin.txt tag add highlight "1.0 lineend - $titlen c" "1.0 lineend"
186 # Search for it in file
187 if {"$curhelp(category) $curhelp(topic)" !=
188 "[string toupper $curhelp(next)]"} {
189 if [info exists helpindex($curhelp(category),$curhelp(topic))] {
190 seek $curhelp(fid) $helpindex($curhelp(category),$curhelp(topic))
191 } else {
192 .helpwin.txt insert end "\nNo such help topic."
193 .helpwin.txt configure -state disabled
194 return ".$curhelp(category).$curhelp(topic) not found\
195 in $curhelp(file)"
196 }
197 }
198 # Load help text into our window
199 set linepos 0
200 while {[set ll [gets $curhelp(fid) li]] >= 0 && ! [regexp -nocase \
201 {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
202 $li dummy cat top]} {
203 if {$ll == 0} { # paragraph
204 if $linepos {
205 .helpwin.txt insert end "\n\n"
206 set linepos 0
207 } else {
208 .helpwin.txt insert end "\n"
209 }
210 } else { # line
211 .helpwin.txt insert end $li
212 incr linepos $ll
213 .helpwin.txt insert end { }
214 incr linepos
215 # Highlight search string match
216 if {"$curhelp(search)" != {}} {
217 if [regexp -nocase -indices \
218 $curhelp(search) $li mi] {
219 .helpwin.txt tag add highlight\
220 "end - 1 c - $ll c\
221 + [lindex $mi 0] c"\
222 "end - $ll c\
223 + [lindex $mi 1] c"
224 }
225 }
226 # Add extra space at the end of a sentence
227 if [regexp {[.?!:][)"']?$} $li] {
228 .helpwin.txt insert end { }
229 incr linepos
230 }
231 }
232 }
233 # Highlight next category and topic
234 if {$ll > 0} {
235 .helpwin.txt insert end "Next: $cat $top"
236 .helpwin.txt tag add highlight "end linestart" end
237 set curhelp(next) "$cat $top"
238 .helpwin.but.next configure -state normal
239 } else {
240 .helpwin.but.next configure -state disabled
241 }
242 .helpwin.txt configure -state disabled
243 return {}
244 }
245
246 proc helphist {op args} { # access help history list
247 global curhelp
248 switch -exact $op {
249 clear {
250 set curhelp(histlst) {}
251 set curhelp(histpos) 0
252 set gotoit 0
253 }
254 new {
255 set curhelp(histpos) \
256 [expr [llength $curhelp(histlst)] - 1]
257 if {"[string toupper [lindex $curhelp(histlst) \
258 $curhelp(histpos)]]"
259 != "[string toupper $args]"} {
260 lappend curhelp(histlst) $args
261 incr curhelp(histpos)
262 }
263 set gotoit 1
264 }
265 append {
266 lappend curhelp(histlst) $args
267 set gotoit 0
268 }
269 back {
270 incr curhelp(histpos) -1
271 set gotoit 1
272 }
273 forward {
274 incr curhelp(histpos) 1
275 set gotoit 1
276 }
277 }
278 if {$curhelp(histpos) + 1 >= [llength $curhelp(histlst)]} {
279 .helpwin.but.forw configure -state disabled
280 } else {
281 .helpwin.but.forw configure -state normal
282 }
283 if {$curhelp(histpos) <= 0} {
284 .helpwin.but.back configure -state disabled
285 } else {
286 .helpwin.but.back configure -state normal
287 }
288 if $gotoit {
289 eval helpgoto [lindex $curhelp(histlst) $curhelp(histpos)]
290 }
291 }
292
293 proc helpsearch word { # search for occurances of the given word
294 global curhelp helpindex
295 if {"$curhelp(search)" == {}} {
296 set curhelp(msg) "No pattern."
297 return 0
298 }
299 set nmatches 0
300 set cat [lindex $curhelp(catlist) 0]
301 set top [lindex $helpindex([string toupper $cat]) 0]
302 set startpos [tell $curhelp(fid)]
303 seek $curhelp(fid) $helpindex([string toupper $cat,$top])
304 set foundmatch 0
305 while {[gets $curhelp(fid) li] >= 0} {
306 if [regexp -nocase {^\.([A-Z][A-Z0-9]*)\.([A-Z][A-Z0-9]*)$} \
307 $li dummy cat top] {
308 set foundmatch 0
309 } elseif {! $foundmatch && \
310 [regexp -nocase $curhelp(search) $li]} {
311 set foundmatch 1
312 if $nmatches {
313 helphist append $cat $top
314 } else {
315 helphist new $cat $top
316 }
317 incr nmatches
318 }
319 }
320 if $nmatches {
321 set curhelp(msg) "$nmatches topic(s)."
322 } else {
323 set curhelp(msg) "Not found."
324 }
325 seek $curhelp(fid) $startpos
326 return $nmatches
327 }
