--- ray/src/util/getfile3.6.tcl 1994/11/30 16:47:00 2.7 +++ ray/src/util/getfile3.6.tcl 1995/07/24 13:31:22 2.9 @@ -23,6 +23,7 @@ proc getfile args { # get filename interactively set dograb 0 set curdir . set curpat * + set curfile {} set transient 1 # Get options while {[llength $args]} { @@ -60,12 +61,12 @@ proc getfile args { # get filename interactively # Create widgets catch {destroy $w} if $topwin { - toplevel $w -geometry 400x410 + toplevel $w -width 400 -height 410 wm title $w "File Picker" wm iconname $w "Files" wm minsize $w 400 300 } else { - frame $w -geometry 400x410 + frame $w -width 400 -height 410 pack $w } if $dograb { grab $w } @@ -160,7 +161,7 @@ proc getfile args { # get filename interactively proc update_dir w { # Update working directory global curdir curpat - if {"$curpat" == ""} { + if {"$curpat" == {}} { set curpat * } if {"$curdir" == {}} {set curdir {~}} @@ -194,7 +195,7 @@ proc update_dir w { # Update working directory } -proc set_curfile {w {sp ""}} { # change current file selection +proc set_curfile {w {sp {}}} { # change current file selection global curdir curfile set f [$w.fm.fl get [$w.fm.fl curselection]] if [string match */ $f] { @@ -202,7 +203,7 @@ proc set_curfile {w {sp ""}} { # change current file update_dir $w } else { set curfile $f - if {"$sp" > ""} { + if {"$sp" != {}} { $sp $curdir/$curfile } } @@ -211,7 +212,7 @@ proc set_curfile {w {sp ""}} { # change current file proc chk_select w { # check if current selection is file set s [$w.fm.fl curselection] - if {"$s" > "" && [file isfile [$w.fm.fl get $s]]} { + if {"$s" != {} && [file isfile [$w.fm.fl get $s]]} { $w.vi configure -state normal } else { $w.vi configure -state disabled
