root/radiance/ray/src/util/getfile3.6.tcl
Revision: 2.7
Committed: Wed Nov 30 16:47:00 1994 UTC (29 years, 6 months ago) by greg
Content type: application/x-tcl
Changes since 2.6: +6 -0 lines
fixed directory window view so as to give priority to end of path name
1 # SCCSid "$SunId$ LBL"
2 #
3 # Usage: getfile [-win w] [-grab] [-perm] [-glob pattern] [-view proc] [-send proc]
4 #
5 # Create a dialog box (in window w if given) to get file name.
6 # If -grab option is given, then getfile does a local grab on its window.
7 # Normally, a single file name and return as value.
8 # If perm switch is given, keep window up for multiple file entries.
9 # If pattern is given, start with list of all the specified files,
10 # breaking the string into directory and file match parts.
11 # If a view procedure is given, a separate "View" button appears
12 # for allowing the user to preview a selected file.
13 # If a send procedure is given, a file name is sent upon
14 # each double-click, and no File entry is displayed.
15 #
16
17 proc getfile args { # get filename interactively
18 # Create necessary globals
19 global curdir curfile curpat
20 # Set defaults
21 set w .fpwin
22 set topwin 1
23 set dograb 0
24 set curdir .
25 set curpat *
26 set transient 1
27 # Get options
28 while {[llength $args]} {
29 switch -glob -- [lindex $args 0] {
30 -win* {
31 set w [lindex $args 1]
32 set topwin 0
33 set args [lreplace $args 1 1]
34 }
35 -grab {
36 set dograb 1
37 }
38 -perm* {
39 set transient 0
40 }
41 -glob {
42 set curdir [file dirname [lindex $args 1]]
43 set curpat [file tail [lindex $args 1]]
44 set args [lreplace $args 1 1]
45 }
46 -vi* {
47 set viewproc [lindex $args 1]
48 set args [lreplace $args 1 1]
49 }
50 -send {
51 set sendproc [lindex $args 1]
52 set args [lreplace $args 1 1]
53 }
54 default { error "bad argument to getfile: [lindex $args 0]" }
55 }
56 set args [lreplace $args 0 0]
57 }
58 # Save initial directory
59 set startdir [pwd]
60 # Create widgets
61 catch {destroy $w}
62 if $topwin {
63 toplevel $w -geometry 400x410
64 wm title $w "File Picker"
65 wm iconname $w "Files"
66 wm minsize $w 400 300
67 } else {
68 frame $w -geometry 400x410
69 pack $w
70 }
71 if $dograb { grab $w }
72 $w configure -cursor top_left_arrow
73 label $w.dt -text Directory:
74 place $w.dt -relx .025 -rely .03125
75 helplink $w.dt file directory intro
76 button $w.ls -text List -command "update_dir $w"
77 place $w.ls -relx .025 -rely .125 -relwidth .15 -relheight .0625
78 helplink $w.ls file directory list
79 entry $w.de -textvariable curdir -relief sunken
80 place $w.de -relx .25 -rely .03125 -relwidth .6875 -relheight .0625
81 focus $w.de
82 helplink $w.de file directory intro
83 bind $w.de <Return> "update_dir $w"
84 entry $w.pw -relief sunken -textvariable curpat
85 place $w.pw -relx .25 -rely .125 -relwidth .34375 -relheight .0625
86 bind $w.pw <Return> "update_dir $w"
87 helplink $w.pw file directory match
88 frame $w.fm
89 scrollbar $w.fm.sb -relief sunken -command "$w.fm.fl yview"
90 listbox $w.fm.fl -relief sunken -yscroll "$w.fm.sb set"
91 pack $w.fm.sb -side right -fill y
92 pack $w.fm.fl -side left -expand yes -fill both
93 place $w.fm -relx .25 -rely .21875 -relwidth .6875 -relheight .625
94 tk_listboxSingleSelect $w.fm.fl
95 helplink $w.fm.fl file file intro
96 if [info exists sendproc] {
97 bind $w.fm.fl <Double-Button-1> "set_curfile $w $sendproc"
98 if {$transient} {
99 bind $w.fm.fl <Double-Button-1> \
100 "+if {\$curfile > {}} {destroy $w}"
101 }
102 } else {
103 bind $w.fm.fl <Double-Button-1> "set_curfile $w"
104 label $w.fl -text File:
105 place $w.fl -relx .10625 -rely .875
106 entry $w.fn -relief sunken -textvariable curfile
107 place $w.fn -relx .25 -rely .875 \
108 -relwidth .6875 -relheight .0625
109 focus $w.fn
110 helplink $w.fn file file entry
111 if $transient {
112 bind $w.fn <Return> "destroy $w"
113 } else {
114 bind $w.fn <Return> {}
115 }
116 }
117 if {$transient != [info exists sendproc]} {
118 button $w.ok -text OK -command "destroy $w"
119 place $w.ok -relx .025 -rely .28125 \
120 -relwidth .15 -relheight .0625
121 }
122 if {$transient || [info exists sendproc]} {
123 button $w.cancel -text Cancel \
124 -command "destroy $w; unset curdir"
125 place $w.cancel -relx .025 -rely .375 \
126 -relwidth .15 -relheight .0625
127 }
128 if [info exists viewproc] {
129 button $w.vi -text View -state disabled \
130 -command "$viewproc \[$w.fm.fl get \[$w.fm.fl curselection\]\]"
131 place $w.vi -relx .025 -rely .46875 \
132 -relwidth .15 -relheight .0625
133 bind $w.fm.fl <ButtonRelease-1> "+chk_select $w"
134 helplink $w.vi file file view
135 }
136 # Load current directory
137 update_dir $w
138 if $transient {
139 tkwait window $w
140 cd $startdir
141 if [info exists sendproc] {
142 return [info exists curdir]
143 }
144 if [info exists curdir] {
145 return $curdir/$curfile
146 }
147 return
148 } elseif {[info exists sendproc]} {
149 tkwait window $w
150 cd $startdir
151 if [info exists curdir] {
152 return 1
153 }
154 return 0
155 }
156 # Else return the dialog window
157 return $w
158 }
159
160
161 proc update_dir w { # Update working directory
162 global curdir curpat
163 if {"$curpat" == ""} {
164 set curpat *
165 }
166 if {"$curdir" == {}} {set curdir {~}}
167 if [catch {cd $curdir} curdir] {
168 set oldcol [lindex [$w.de config -foreground] 4]
169 $w.de config -foreground Red
170 update idletasks
171 after 1500
172 $w.de config -foreground $oldcol
173 }
174 set curdir [pwd]
175 set offset [expr [string length $curdir] - 32]
176 if {$offset > 0} {
177 $w.de view [expr $offset + \
178 [string first / [string range $curdir $offset end]] \
179 + 1]
180 }
181 $w.fm.fl delete 0 end
182 set ls ../
183 foreach f [glob -nocomplain *] {
184 if [file isdirectory $f] {
185 lappend ls $f/
186 }
187 }
188 foreach f [eval glob -nocomplain [split $curpat]] {
189 if [file isfile $f] {
190 lappend ls $f
191 }
192 }
193 eval $w.fm.fl insert end [lsort $ls]
194 }
195
196
197 proc set_curfile {w {sp ""}} { # change current file selection
198 global curdir curfile
199 set f [$w.fm.fl get [$w.fm.fl curselection]]
200 if [string match */ $f] {
201 set curdir [string range $f 0 [expr [string length $f]-2]]
202 update_dir $w
203 } else {
204 set curfile $f
205 if {"$sp" > ""} {
206 $sp $curdir/$curfile
207 }
208 }
209 }
210
211
212 proc chk_select w { # check if current selection is file
213 set s [$w.fm.fl curselection]
214 if {"$s" > "" && [file isfile [$w.fm.fl get $s]]} {
215 $w.vi configure -state normal
216 } else {
217 $w.vi configure -state disabled
218 }
219 }
