root/radiance/ray/src/util/getfile3.6.tcl
Revision: 2.11
Committed: Wed Oct 26 20:06:17 2011 UTC (12 years, 7 months ago) by greg
Content type: application/x-tcl
State: FILE REMOVED
Made a few updates to trad
# User Rev Content
1 greg 2.11 # RCSid: $Id: getfile3.6.tcl,v 2.10 2003/02/22 02:07:30 greg Exp $
2 greg 2.1 #
3 greg 2.5 # Usage: getfile [-win w] [-grab] [-perm] [-glob pattern] [-view proc] [-send proc]
4 greg 2.1 #
5     # Create a dialog box (in window w if given) to get file name.
6 greg 2.5 # If -grab option is given, then getfile does a local grab on its window.
7 greg 2.1 # Normally, a single file name and return as value.
8     # If perm switch is given, keep window up for multiple file entries.
9     # If pattern is given, start with list of all the specified files,
10     # breaking the string into directory and file match parts.
11     # If a view procedure is given, a separate "View" button appears
12     # for allowing the user to preview a selected file.
13     # If a send procedure is given, a file name is sent upon
14     # each double-click, and no File entry is displayed.
15     #
16
17     proc getfile args { # get filename interactively
18     # Create necessary globals
19     global curdir curfile curpat
20     # Set defaults
21     set w .fpwin
22     set topwin 1
23 greg 2.5 set dograb 0
24 greg 2.1 set curdir .
25     set curpat *
26 greg 2.8 set curfile {}
27 greg 2.1 set transient 1
28     # Get options
29     while {[llength $args]} {
30     switch -glob -- [lindex $args 0] {
31     -win* {
32     set w [lindex $args 1]
33     set topwin 0
34     set args [lreplace $args 1 1]
35     }
36 greg 2.5 -grab {
37     set dograb 1
38     }
39 greg 2.1 -perm* {
40     set transient 0
41     }
42     -glob {
43     set curdir [file dirname [lindex $args 1]]
44     set curpat [file tail [lindex $args 1]]
45     set args [lreplace $args 1 1]
46     }
47     -vi* {
48     set viewproc [lindex $args 1]
49     set args [lreplace $args 1 1]
50     }
51     -send {
52     set sendproc [lindex $args 1]
53     set args [lreplace $args 1 1]
54     }
55     default { error "bad argument to getfile: [lindex $args 0]" }
56     }
57     set args [lreplace $args 0 0]
58     }
59     # Save initial directory
60     set startdir [pwd]
61     # Create widgets
62     catch {destroy $w}
63     if $topwin {
64 greg 2.9 toplevel $w -width 400 -height 410
65 greg 2.1 wm title $w "File Picker"
66     wm iconname $w "Files"
67 greg 2.2 wm minsize $w 400 300
68 greg 2.1 } else {
69 greg 2.9 frame $w -width 400 -height 410
70 greg 2.1 pack $w
71     }
72 greg 2.5 if $dograb { grab $w }
73     $w configure -cursor top_left_arrow
74 greg 2.1 label $w.dt -text Directory:
75 greg 2.4 place $w.dt -relx .025 -rely .03125
76 greg 2.1 helplink $w.dt file directory intro
77     button $w.ls -text List -command "update_dir $w"
78 greg 2.4 place $w.ls -relx .025 -rely .125 -relwidth .15 -relheight .0625
79 greg 2.1 helplink $w.ls file directory list
80     entry $w.de -textvariable curdir -relief sunken
81     place $w.de -relx .25 -rely .03125 -relwidth .6875 -relheight .0625
82     focus $w.de
83     helplink $w.de file directory intro
84     bind $w.de <Return> "update_dir $w"
85     entry $w.pw -relief sunken -textvariable curpat
86     place $w.pw -relx .25 -rely .125 -relwidth .34375 -relheight .0625
87     bind $w.pw <Return> "update_dir $w"
88     helplink $w.pw file directory match
89     frame $w.fm
90     scrollbar $w.fm.sb -relief sunken -command "$w.fm.fl yview"
91     listbox $w.fm.fl -relief sunken -yscroll "$w.fm.sb set"
92     pack $w.fm.sb -side right -fill y
93     pack $w.fm.fl -side left -expand yes -fill both
94     place $w.fm -relx .25 -rely .21875 -relwidth .6875 -relheight .625
95     tk_listboxSingleSelect $w.fm.fl
96     helplink $w.fm.fl file file intro
97     if [info exists sendproc] {
98     bind $w.fm.fl <Double-Button-1> "set_curfile $w $sendproc"
99     if {$transient} {
100     bind $w.fm.fl <Double-Button-1> \
101     "+if {\$curfile > {}} {destroy $w}"
102     }
103     } else {
104     bind $w.fm.fl <Double-Button-1> "set_curfile $w"
105     label $w.fl -text File:
106 greg 2.4 place $w.fl -relx .10625 -rely .875
107 greg 2.1 entry $w.fn -relief sunken -textvariable curfile
108     place $w.fn -relx .25 -rely .875 \
109     -relwidth .6875 -relheight .0625
110     focus $w.fn
111     helplink $w.fn file file entry
112     if $transient {
113     bind $w.fn <Return> "destroy $w"
114     } else {
115     bind $w.fn <Return> {}
116     }
117     }
118     if {$transient != [info exists sendproc]} {
119     button $w.ok -text OK -command "destroy $w"
120 greg 2.4 place $w.ok -relx .025 -rely .28125 \
121     -relwidth .15 -relheight .0625
122 greg 2.1 }
123     if {$transient || [info exists sendproc]} {
124     button $w.cancel -text Cancel \
125     -command "destroy $w; unset curdir"
126 greg 2.4 place $w.cancel -relx .025 -rely .375 \
127     -relwidth .15 -relheight .0625
128 greg 2.1 }
129     if [info exists viewproc] {
130     button $w.vi -text View -state disabled \
131     -command "$viewproc \[$w.fm.fl get \[$w.fm.fl curselection\]\]"
132 greg 2.4 place $w.vi -relx .025 -rely .46875 \
133     -relwidth .15 -relheight .0625
134 greg 2.1 bind $w.fm.fl <ButtonRelease-1> "+chk_select $w"
135     helplink $w.vi file file view
136     }
137     # Load current directory
138     update_dir $w
139     if $transient {
140     tkwait window $w
141     cd $startdir
142     if [info exists sendproc] {
143     return [info exists curdir]
144     }
145     if [info exists curdir] {
146     return $curdir/$curfile
147     }
148     return
149     } elseif {[info exists sendproc]} {
150     tkwait window $w
151     cd $startdir
152     if [info exists curdir] {
153     return 1
154     }
155     return 0
156     }
157     # Else return the dialog window
158     return $w
159     }
160
161
162     proc update_dir w { # Update working directory
163     global curdir curpat
164 greg 2.8 if {"$curpat" == {}} {
165 greg 2.1 set curpat *
166     }
167 greg 2.3 if {"$curdir" == {}} {set curdir {~}}
168 greg 2.1 if [catch {cd $curdir} curdir] {
169     set oldcol [lindex [$w.de config -foreground] 4]
170     $w.de config -foreground Red
171     update idletasks
172     after 1500
173     $w.de config -foreground $oldcol
174     }
175     set curdir [pwd]
176 greg 2.7 set offset [expr [string length $curdir] - 32]
177     if {$offset > 0} {
178     $w.de view [expr $offset + \
179     [string first / [string range $curdir $offset end]] \
180     + 1]
181     }
182 greg 2.1 $w.fm.fl delete 0 end
183     set ls ../
184 greg 2.6 foreach f [glob -nocomplain *] {
185 greg 2.1 if [file isdirectory $f] {
186     lappend ls $f/
187     }
188     }
189     foreach f [eval glob -nocomplain [split $curpat]] {
190     if [file isfile $f] {
191     lappend ls $f
192     }
193     }
194     eval $w.fm.fl insert end [lsort $ls]
195     }
196
197
198 greg 2.8 proc set_curfile {w {sp {}}} { # change current file selection
199 greg 2.1 global curdir curfile
200     set f [$w.fm.fl get [$w.fm.fl curselection]]
201     if [string match */ $f] {
202     set curdir [string range $f 0 [expr [string length $f]-2]]
203     update_dir $w
204     } else {
205     set curfile $f
206 greg 2.8 if {"$sp" != {}} {
207 greg 2.1 $sp $curdir/$curfile
208     }
209     }
210     }
211
212
213     proc chk_select w { # check if current selection is file
214     set s [$w.fm.fl curselection]
215 greg 2.8 if {"$s" != {} && [file isfile [$w.fm.fl get $s]]} {
216 greg 2.1 $w.vi configure -state normal
217     } else {
218     $w.vi configure -state disabled
219     }
220     }
