root/radiance/ray/src/util/getfile.tcl
Revision: 2.2
Committed: Sat Feb 22 02:07:30 2003 UTC (21 years, 3 months ago) by greg
Content type: application/x-tcl
CVS Tags: rad3R7P2, rad3R7P1, rad4R1, rad4R0, rad3R5, rad3R6, rad3R6P1, rad3R8, rad3R9
1 # RCSid: $Id$
2 #
3 # Usage: getfile [-win w] [-grab] [-perm] [-glob pattern] [-view proc] [-send proc]
4 #
5 # Create a dialog box (in window w if given) to get file name.
6 # If -grab option is given, then getfile does a local grab on its window.
7 # Normally, a single file name and return as value.
8 # If perm switch is given, keep window up for multiple file entries.
9 # If pattern is given, start with list of all the specified files,
10 # breaking the string into directory and file match parts.
11 # If a view procedure is given, a separate "View" button appears
12 # for allowing the user to preview a selected file.
13 # If a send procedure is given, a file name is sent upon
14 # each double-click, and no File entry is displayed.
15 #
16
17 proc getfile args { # get filename interactively
18 # Create necessary globals
19 global curdir curfile curpat
20 # Set defaults
21 set w .fpwin
22 set topwin 1
23 set dograb 0
24 set curdir .
25 set curpat *
26 set curfile {}
27 set transient 1
28 # Get options
29 while {[llength $args]} {
30 switch -glob -- [lindex $args 0] {
31 -win* {
32 set w [lindex $args 1]
33 set topwin 0
34 set args [lreplace $args 1 1]
35 }
36 -grab {
37 set dograb 1
38 }
39 -perm* {
40 set transient 0
41 }
42 -glob {
43 set curdir [file dirname [lindex $args 1]]
44 set curpat [file tail [lindex $args 1]]
45 set args [lreplace $args 1 1]
46 }
47 -vi* {
48 set viewproc [lindex $args 1]
49 set args [lreplace $args 1 1]
50 }
51 -send {
52 set sendproc [lindex $args 1]
53 set args [lreplace $args 1 1]
54 }
55 default { error "bad argument to getfile: [lindex $args 0]" }
56 }
57 set args [lreplace $args 0 0]
58 }
59 # Save initial directory
60 set startdir [pwd]
61 # Create widgets
62 catch {destroy $w}
63 if $topwin {
64 toplevel $w -width 400 -height 410
65 wm title $w "File Picker"
66 wm iconname $w "Files"
67 wm minsize $w 400 300
68 } else {
69 frame $w -width 400 -height 410
70 pack $w
71 }
72 if $dograb { grab $w }
73 $w configure -cursor top_left_arrow
74 label $w.dt -text Directory:
75 place $w.dt -relx .025 -rely .03125
76 helplink $w.dt file directory intro
77 button $w.ls -text List -command "update_dir $w"
78 place $w.ls -relx .025 -rely .125 -relwidth .15 -relheight .0625
79 helplink $w.ls file directory list
80 entry $w.de -textvariable curdir -relief sunken
81 place $w.de -relx .25 -rely .03125 -relwidth .6875 -relheight .0625
82 focus $w.de
83 helplink $w.de file directory intro
84 bind $w.de <Return> "update_dir $w"
85 entry $w.pw -relief sunken -textvariable curpat
86 place $w.pw -relx .25 -rely .125 -relwidth .34375 -relheight .0625
87 bind $w.pw <Return> "update_dir $w"
88 helplink $w.pw file directory match
89 frame $w.fm
90 scrollbar $w.fm.sb -relief sunken -command "$w.fm.fl yview"
91 listbox $w.fm.fl -relief sunken -yscroll "$w.fm.sb set" \
92 -selectmode browse
93 pack $w.fm.sb -side right -fill y
94 pack $w.fm.fl -side left -expand yes -fill both
95 place $w.fm -relx .25 -rely .21875 -relwidth .6875 -relheight .625
96 helplink $w.fm.fl file file intro
97 if [info exists sendproc] {
98 bind $w.fm.fl <Double-Button-1> "set_curfile $w $sendproc"
99 if {$transient} {
100 bind $w.fm.fl <Double-Button-1> \
101 "+if {\$curfile > {}} {destroy $w}"
102 }
103 } else {
104 bind $w.fm.fl <Double-Button-1> "set_curfile $w"
105 label $w.fl -text File:
106 place $w.fl -relx .10625 -rely .875
107 entry $w.fn -relief sunken -textvariable curfile
108 place $w.fn -relx .25 -rely .875 \
109 -relwidth .6875 -relheight .0625
110 focus $w.fn
111 helplink $w.fn file file entry
112 if $transient {
113 bind $w.fn <Return> "destroy $w"
114 } else {
115 bind $w.fn <Return> {}
116 }
117 }
118 if {$transient != [info exists sendproc]} {
119 button $w.ok -text OK -command "destroy $w"
120 place $w.ok -relx .025 -rely .28125 \
121 -relwidth .15 -relheight .0625
122 }
123 if {$transient || [info exists sendproc]} {
124 button $w.cancel -text Cancel \
125 -command "destroy $w; unset curdir"
126 place $w.cancel -relx .025 -rely .375 \
127 -relwidth .15 -relheight .0625
128 }
129 if [info exists viewproc] {
130 button $w.vi -text View -state disabled \
131 -command "$viewproc \[$w.fm.fl get \[$w.fm.fl curselection\]\]"
132 place $w.vi -relx .025 -rely .46875 \
133 -relwidth .15 -relheight .0625
134 bind $w.fm.fl <ButtonRelease-1> "+chk_select $w"
135 helplink $w.vi file file view
136 }
137 # Load current directory
138 update_dir $w
139 if $transient {
140 tkwait window $w
141 cd $startdir
142 if [info exists sendproc] {
143 return [info exists curdir]
144 }
145 if [info exists curdir] {
146 return $curdir/$curfile
147 }
148 return
149 } elseif {[info exists sendproc]} {
150 tkwait window $w
151 cd $startdir
152 if [info exists curdir] {
153 return 1
154 }
155 return 0
156 }
157 # Else return the dialog window
158 return $w
159 }
160
161
162 proc update_dir w { # Update working directory
163 global curdir curpat
164 if {"$curpat" == {}} {
165 set curpat *
166 }
167 if {"$curdir" == {}} {set curdir {~}}
168 if [catch {cd $curdir} curdir] {
169 set oldcol [lindex [$w.de config -foreground] 4]
170 $w.de config -foreground Red
171 update idletasks
172 after 1500
173 $w.de config -foreground $oldcol
174 }
175 set curdir [pwd]
176 set offset [expr [string length $curdir] - 32]
177 if {$offset > 0} {
178 $w.de xview [expr $offset + \
179 [string first / [string range $curdir $offset end]] \
180 + 1]
181 }
182 $w.fm.fl delete 0 end
183 set ls ../
184 foreach f [glob -nocomplain *] {
185 if [file isdirectory $f] {
186 lappend ls $f/
187 }
188 }
189 foreach f [eval glob -nocomplain [split $curpat]] {
190 if [file isfile $f] {
191 lappend ls $f
192 }
193 }
194 eval $w.fm.fl insert end [lsort $ls]
195 }
196
197
198 proc set_curfile {w {sp {}}} { # change current file selection
199 global curdir curfile
200 set f [$w.fm.fl get [$w.fm.fl curselection]]
201 if [string match */ $f] {
202 set curdir [string range $f 0 [expr [string length $f]-2]]
203 update_dir $w
204 } else {
205 set curfile $f
206 if {"$sp" != {}} {
207 $sp $curdir/$curfile
208 }
209 }
210 }
211
212
213 proc chk_select w { # check if current selection is file
214 set s [$w.fm.fl curselection]
215 if {"$s" != {} && [file isfile [$w.fm.fl get $s]]} {
216 $w.vi configure -state normal
217 } else {
218 $w.vi configure -state disabled
219 }
220 }
