root/radiance/ray/src/util/gentregvec.pl
Revision: 2.5
Committed: Wed Dec 9 21:31:44 2009 UTC (15 years, 6 months ago) by greg
State: FILE REMOVED
Removed gentregvec, which is now the same as genskyvec -m 1
1 #!/usr/bin/perl -w
2 # RCSid $Id: gentregvec.pl,v 2.4 2009/06/24 19:19:38 greg Exp $
3 #
4 # Generate Tregenza vector for a given sky description
5 #
6 # G. Ward
7 #
8 use strict;
9 $ENV{RAYPATH} = ':/usr/local/lib/ray' if (! $ENV{RAYPATH});
10 my $tregsamp = "tregsamp.dat";
11 my @skycolor = (0.960, 1.004, 1.118);
12 while ($#ARGV >= 0) {
13 if ("$ARGV[0]" eq "-c") {
14 @skycolor = @ARGV[1..3];
15 shift @ARGV; shift @ARGV; shift @ARGV;
16 }
17 shift @ARGV;
18 }
19 # Load sky description into line array, separating sun if one
20 my @skydesc;
21 my $lightline;
22 my @sunval;
23 my $sunline;
24 my $skyOK = 0;
25 my $srcmod; # putting this inside loop breaks code(?!)
26 while (<>) {
27 push @skydesc, $_;
28 if (/^\w+\s+light\s+/) {
29 s/\s*$//; s/^.*\s//;
30 $srcmod = $_;
31 $lightline = $#skydesc;
32 } elsif (defined($srcmod) && /^($srcmod)\s+source\s/) {
33 @sunval = split(/\s+/, $skydesc[$lightline + 3]);
34 shift @sunval;
35 $sunline = $#skydesc;
36 } elsif (/\sskyfunc\s*$/) {
37 $skyOK = 1;
38 }
39 }
40 die "Bad sky description!\n" if (! $skyOK);
41 # Strip out the solar source if present
42 my @sundir;
43 if (defined $sunline) {
44 @sundir = split(/\s+/, $skydesc[$sunline + 3]);
45 shift @sundir;
46 undef @sundir if ($sundir[2] <= 0);
47 splice(@skydesc, $sunline, 5);
48 }
49 # Get Tregenza sample file
50 my $found;
51 foreach my $dir (split /:/, $ENV{RAYPATH}) {
52 if (-r "$dir/$tregsamp") {
53 $found = "$dir/$tregsamp";
54 last;
55 }
56 }
57 if (! $found) {
58 print STDERR "Cannot find file '$tregsamp'\n";
59 exit 1;
60 }
61 $tregsamp = $found;
62 # Create octree for rtrace
63 my $octree = "/tmp/gtv$$.oct";
64 open OCONV, "| oconv - > $octree";
65 print OCONV @skydesc;
66 print OCONV "skyfunc glow skyglow 0 0 4 @skycolor 0\n";
67 print OCONV "skyglow source sky 0 0 4 0 0 1 360\n";
68 close OCONV;
69 # Run rtrace and average output for every 64 samples
70 my @tregval = `rtrace -h -faf -ab 0 -w < $tregsamp $octree | total -if3 -m -64`;
71 if ($#tregval != 145) {
72 print STDERR "Expected 9344 samples in $tregsamp -- found ",
73 `wc -l < $tregsamp`, "\n";
74 exit 1;
75 }
76 unlink $octree;
77 # Find closest 3 patches to sun and divvy up direct solar contribution
78 my @bestdir;
79 if (@sundir) {
80 my $somega = ($sundir[3]/360)**2 * 3.141592654**3;
81 my @tindex = (30, 60, 84, 108, 126, 138, 144, 145);
82 my @tomega = (0.0435449227, 0.0416418006, 0.0473984151,
83 0.0406730411, 0.0428934136, 0.0445221864,
84 0.0455168385, 0.0344199465);
85 my $cmd = "total -m -64 < $tregsamp | tail +2 | rcalc " .
86 q{-e 'Dx=$4;Dy=$5;Dz=$6' } .
87 "-e 'dot=Dx*$sundir[0] + Dy*$sundir[1] + Dz*$sundir[2]' " .
88 q{-e '$1=acos(dot);$2=recno' | sort -n};
89 @bestdir = `$cmd | head -3`;
90 my @ang; my @ndx;
91 ($ang[0], $ndx[0], $ang[1], $ndx[1], $ang[2], $ndx[2]) =
92 ( split(/\s+/, $bestdir[0]),
93 split(/\s+/, $bestdir[1]),
94 split(/\s+/, $bestdir[2]) );
95 my $wtot = 1/($ang[0]+.02) + 1/($ang[1]+.02) + 1/($ang[2]+.02);
96 for my $i (0..2) {
97 my $ti = 0;
98 while ($ndx[$i] > $tindex[$ti]) { $ti++ }
99 my $wt = 1/($ang[$i]+.02)/$wtot * $somega / $tomega[$ti];
100 my @scolor = split(/\s+/, $tregval[$ndx[$i]]);
101 for my $j (0..2) { $scolor[$j] += $wt * $sunval[$j]; }
102 $tregval[$ndx[$i]] = "@scolor\n";
103 }
104 }
105 # Output our final vector
106 print @tregval;
