root/radiance/ray/src/util/genskyvec.pl
Revision: 2.9
Committed: Wed Sep 17 22:40:49 2014 UTC (9 years ago) by greg
CVS Tags: rad5R0, rad4R2P2
Changes since 2.8: +14 -1 lines
1 #!/usr/bin/perl -w
2 # RCSid $Id: genskyvec.pl,v 2.8 2012/06/28 20:48:03 greg Exp $
3 #
4 # Generate Reinhart vector for a given sky description
5 #
6 # G. Ward
7 #
8 use strict;
9 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 my @skycolor = (0.960, 1.004, 1.118);
11 my $mf = 4;
12 my $dosky = 1;
13 my $headout = 1;
14 my @origARGV = @ARGV;
15 while ($#ARGV >= 0) {
16 if ("$ARGV[0]" eq "-c") {
17 @skycolor = @ARGV[1..3];
18 shift @ARGV for (1..3);
19 } elsif ("$ARGV[0]" eq "-m") {
20 $mf = $ARGV[1];
21 shift @ARGV;
22 } elsif ("$ARGV[0]" eq "-d") {
23 $dosky = 0;
24 } elsif ("$ARGV[0]" eq "-h") {
25 $headout = 0;
26 }
27 shift @ARGV;
28 }
29 # Load sky description into line array, separating sun if one
30 my @skydesc;
31 my $lightline;
32 my @sunval;
33 my $sunline;
34 my $skyOK = 0;
35 my $srcmod; # putting this inside loop breaks code(?!)
36 while (<>) {
37 push @skydesc, $_;
38 if (/^\w+\s+light\s+/) {
39 s/\s*$//; s/^.*\s//;
40 $srcmod = $_;
41 $lightline = $#skydesc;
42 } elsif (defined($srcmod) && /^($srcmod)\s+source\s/) {
43 @sunval = split(' ', $skydesc[$lightline + 3]);
44 shift @sunval;
45 $sunline = $#skydesc;
46 } elsif (/\sskyfunc\s*$/) {
47 $skyOK = 1;
48 }
49 }
50 die "Bad sky description!\n" if (! $skyOK);
51 # Strip out the solar source if present
52 my @sundir;
53 if (defined $sunline) {
54 @sundir = split(' ', $skydesc[$sunline + 3]);
55 shift @sundir;
56 undef @sundir if ($sundir[2] <= 0);
57 splice(@skydesc, $sunline, 5);
58 }
59 # Reinhart sky sample generator
60 my $rhcal = 'DEGREE : PI/180;' .
61 'x1 = .5; x2 = .5;' .
62 'alpha : 90/(MF*7 + .5);' .
63 'tnaz(r) : select(r, 30, 30, 24, 24, 18, 12, 6);' .
64 'rnaz(r) : if(r-(7*MF-.5), 1, MF*tnaz(floor((r+.5)/MF) + 1));' .
65 'raccum(r) : if(r-.5, rnaz(r-1) + raccum(r-1), 0);' .
66 'RowMax : 7*MF + 1;' .
67 'Rmax : raccum(RowMax);' .
68 'Rfindrow(r, rem) : if(rem-rnaz(r)-.5, Rfindrow(r+1, rem-rnaz(r)), r);' .
69 'Rrow = if(Rbin-(Rmax-.5), RowMax-1, Rfindrow(0, Rbin));' .
70 'Rcol = Rbin - raccum(Rrow) - 1;' .
71 'Razi_width = 2*PI / rnaz(Rrow);' .
72 'RAH : alpha*DEGREE;' .
73 'Razi = if(Rbin-.5, (Rcol + x2 - .5)*Razi_width, 2*PI*x2);' .
74 'Ralt = if(Rbin-.5, (Rrow + x1)*RAH, asin(-x1));' .
75 'Romega = if(.5-Rbin, 2*PI, if(Rmax-.5-Rbin, ' .
76 ' Razi_width*(sin(RAH*(Rrow+1)) - sin(RAH*Rrow)),' .
77 ' 2*PI*(1 - cos(RAH/2)) ) );' .
78 'cos_ralt = cos(Ralt);' .
79 'Dx = sin(Razi)*cos_ralt;' .
80 'Dy = cos(Razi)*cos_ralt;' .
81 'Dz = sin(Ralt);' ;
82 my ($nbins, $octree, $tregcommand, $suncmd);
83 if ($windoz) {
84 $nbins = `rcalc -n -e MF:$mf -e \"$rhcal\" -e \"\$1=Rmax+1\"`;
85 chomp $nbins;
86 $octree = "gtv$$.oct";
87 $tregcommand = "cnt $nbins 16 | rcalc -e MF:$mf -e \"$rhcal\" " .
88 q{-e "Rbin=$1;x1=rand(recno*.37-5.3);x2=rand(recno*-1.47+.86)" } .
89 q{-e "$1=0;$2=0;$3=0;$4=Dx;$5=Dy;$6=Dz" } .
90 "| rtrace -h -ab 0 -w $octree | total -16 -m";
91 if (@sundir) {
92 $suncmd = "cnt " . ($nbins-1) .
93 " | rcalc -e MF:$mf -e \"$rhcal\" -e Rbin=recno " .
94 "-e \"dot=Dx*$sundir[0] + Dy*$sundir[1] + Dz*$sundir[2]\" " .
95 "-e \"cond=dot-.866\" " .
96 q{-e "$1=if(1-dot,acos(dot),0);$2=Romega;$3=recno" };
97 }
98 } else {
99 $nbins = `rcalc -n -e MF:$mf -e \'$rhcal\' -e \'\$1=Rmax+1\'`;
100 chomp $nbins;
101 $octree = "/tmp/gtv$$.oct";
102 $tregcommand = "cnt $nbins 16 | rcalc -of -e MF:$mf -e '$rhcal' " .
103 q{-e 'Rbin=$1;x1=rand(recno*.37-5.3);x2=rand(recno*-1.47+.86)' } .
104 q{-e '$1=0;$2=0;$3=0;$4=Dx;$5=Dy;$6=Dz' } .
105 "| rtrace -h -ff -ab 0 -w $octree | total -if3 -16 -m";
106 if (@sundir) {
107 $suncmd = "cnt " . ($nbins-1) .
108 " | rcalc -e MF:$mf -e '$rhcal' -e Rbin=recno " .
109 "-e 'dot=Dx*$sundir[0] + Dy*$sundir[1] + Dz*$sundir[2]' " .
110 "-e 'cond=dot-.866' " .
111 q{-e '$1=if(1-dot,acos(dot),0);$2=Romega;$3=recno' };
112 }
113 }
114 my @tregval;
115 if ($dosky) {
116 # Create octree for rtrace
117 open OCONV, "| oconv - > $octree";
118 print OCONV @skydesc;
119 print OCONV "skyfunc glow skyglow 0 0 4 @skycolor 0\n";
120 print OCONV "skyglow source sky 0 0 4 0 0 1 360\n";
121 close OCONV;
122 # Run rtrace and average output for every 16 samples
123 @tregval = `$tregcommand`;
124 unlink $octree;
125 } else {
126 push @tregval, "0\t0\t0\n" for (1..$nbins);
127 }
128 # Find closest 3 patches to sun and divvy up direct solar contribution
129 sub numSort1 {
130 my @a1 = split("\t", $a);
131 my @b1 = split("\t", $b);
132 return ($a1[0] <=> $b1[0]);
133 }
134 if (@sundir) {
135 my $somega = ($sundir[3]/360)**2 * 3.141592654**3;
136 my @bestdir = `$suncmd`;
137 @bestdir = sort numSort1 @bestdir;
138 my (@ang, @dom, @ndx);
139 my $wtot = 0;
140 for my $i (0..2) {
141 ($ang[$i], $dom[$i], $ndx[$i]) = split(' ', $bestdir[$i]);
142 $wtot += 1./($ang[$i]+.02);
143 }
144 for my $i (0..2) {
145 my $wt = 1./($ang[$i]+.02)/$wtot * $somega / $dom[$i];
146 my @scolor = split(' ', $tregval[$ndx[$i]]);
147 for my $j (0..2) { $scolor[$j] += $wt * $sunval[$j]; }
148 $tregval[$ndx[$i]] = "$scolor[0]\t$scolor[1]\t$scolor[2]\n";
149 }
150 }
151 # Output header if requested
152 if ($headout) {
153 print "#?RADIANCE\n";
154 print "genskyvec @origARGV\n";
155 print "NROWS=", $#tregval+1, "\n";
156 print "NCOLS=1\nNCOMP=3\n";
157 print "FORMAT=ascii\n";
158 print "\n";
159 }
160 # Output our final vector
161 print @tregval;
