root/radiance/ray/src/util/genskyvec.pl
Revision: 2.9
Committed: Wed Sep 17 22:40:49 2014 UTC (10 years, 8 months ago) by greg
CVS Tags: rad4R2P2, rad5R0
Changes since 2.8: +14 -1 lines
# User Rev Content
1 greg 2.1 #!/usr/bin/perl -w
2 greg 2.9 # RCSid $Id: genskyvec.pl,v 2.8 2012/06/28 20:48:03 greg Exp $
3 greg 2.1 #
4     # Generate Reinhart vector for a given sky description
5     #
6     # G. Ward
7     #
8     use strict;
9 greg 2.6 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 greg 2.1 my @skycolor = (0.960, 1.004, 1.118);
11 greg 2.3 my $mf = 4;
12 greg 2.8 my $dosky = 1;
13 greg 2.9 my $headout = 1;
14     my @origARGV = @ARGV;
15 greg 2.1 while ($#ARGV >= 0) {
16     if ("$ARGV[0]" eq "-c") {
17     @skycolor = @ARGV[1..3];
18 greg 2.8 shift @ARGV for (1..3);
19 greg 2.3 } elsif ("$ARGV[0]" eq "-m") {
20     $mf = $ARGV[1];
21     shift @ARGV;
22 greg 2.8 } elsif ("$ARGV[0]" eq "-d") {
23     $dosky = 0;
24 greg 2.9 } elsif ("$ARGV[0]" eq "-h") {
25     $headout = 0;
26 greg 2.1 }
27     shift @ARGV;
28     }
29     # Load sky description into line array, separating sun if one
30     my @skydesc;
31     my $lightline;
32     my @sunval;
33     my $sunline;
34     my $skyOK = 0;
35     my $srcmod; # putting this inside loop breaks code(?!)
36     while (<>) {
37     push @skydesc, $_;
38     if (/^\w+\s+light\s+/) {
39     s/\s*$//; s/^.*\s//;
40     $srcmod = $_;
41     $lightline = $#skydesc;
42     } elsif (defined($srcmod) && /^($srcmod)\s+source\s/) {
43 greg 2.5 @sunval = split(' ', $skydesc[$lightline + 3]);
44 greg 2.1 shift @sunval;
45     $sunline = $#skydesc;
46     } elsif (/\sskyfunc\s*$/) {
47     $skyOK = 1;
48     }
49     }
50     die "Bad sky description!\n" if (! $skyOK);
51     # Strip out the solar source if present
52     my @sundir;
53     if (defined $sunline) {
54 greg 2.5 @sundir = split(' ', $skydesc[$sunline + 3]);
55 greg 2.1 shift @sundir;
56     undef @sundir if ($sundir[2] <= 0);
57     splice(@skydesc, $sunline, 5);
58     }
59     # Reinhart sky sample generator
60 greg 2.6 my $rhcal = 'DEGREE : PI/180;' .
61     'x1 = .5; x2 = .5;' .
62     'alpha : 90/(MF*7 + .5);' .
63     'tnaz(r) : select(r, 30, 30, 24, 24, 18, 12, 6);' .
64     'rnaz(r) : if(r-(7*MF-.5), 1, MF*tnaz(floor((r+.5)/MF) + 1));' .
65     'raccum(r) : if(r-.5, rnaz(r-1) + raccum(r-1), 0);' .
66     'RowMax : 7*MF + 1;' .
67     'Rmax : raccum(RowMax);' .
68     'Rfindrow(r, rem) : if(rem-rnaz(r)-.5, Rfindrow(r+1, rem-rnaz(r)), r);' .
69     'Rrow = if(Rbin-(Rmax-.5), RowMax-1, Rfindrow(0, Rbin));' .
70     'Rcol = Rbin - raccum(Rrow) - 1;' .
71     'Razi_width = 2*PI / rnaz(Rrow);' .
72     'RAH : alpha*DEGREE;' .
73     'Razi = if(Rbin-.5, (Rcol + x2 - .5)*Razi_width, 2*PI*x2);' .
74     'Ralt = if(Rbin-.5, (Rrow + x1)*RAH, asin(-x1));' .
75     'Romega = if(.5-Rbin, 2*PI, if(Rmax-.5-Rbin, ' .
76     ' Razi_width*(sin(RAH*(Rrow+1)) - sin(RAH*Rrow)),' .
77     ' 2*PI*(1 - cos(RAH/2)) ) );' .
78     'cos_ralt = cos(Ralt);' .
79     'Dx = sin(Razi)*cos_ralt;' .
80     'Dy = cos(Razi)*cos_ralt;' .
81     'Dz = sin(Ralt);' ;
82     my ($nbins, $octree, $tregcommand, $suncmd);
83     if ($windoz) {
84     $nbins = `rcalc -n -e MF:$mf -e \"$rhcal\" -e \"\$1=Rmax+1\"`;
85     chomp $nbins;
86     $octree = "gtv$$.oct";
87     $tregcommand = "cnt $nbins 16 | rcalc -e MF:$mf -e \"$rhcal\" " .
88     q{-e "Rbin=$1;x1=rand(recno*.37-5.3);x2=rand(recno*-1.47+.86)" } .
89     q{-e "$1=0;$2=0;$3=0;$4=Dx;$5=Dy;$6=Dz" } .
90     "| rtrace -h -ab 0 -w $octree | total -16 -m";
91 greg 2.7 if (@sundir) {
92     $suncmd = "cnt " . ($nbins-1) .
93     " | rcalc -e MF:$mf -e \"$rhcal\" -e Rbin=recno " .
94     "-e \"dot=Dx*$sundir[0] + Dy*$sundir[1] + Dz*$sundir[2]\" " .
95     "-e \"cond=dot-.866\" " .
96     q{-e "$1=if(1-dot,acos(dot),0);$2=Romega;$3=recno" };
97     }
98 greg 2.6 } else {
99     $nbins = `rcalc -n -e MF:$mf -e \'$rhcal\' -e \'\$1=Rmax+1\'`;
100     chomp $nbins;
101     $octree = "/tmp/gtv$$.oct";
102     $tregcommand = "cnt $nbins 16 | rcalc -of -e MF:$mf -e '$rhcal' " .
103     q{-e 'Rbin=$1;x1=rand(recno*.37-5.3);x2=rand(recno*-1.47+.86)' } .
104     q{-e '$1=0;$2=0;$3=0;$4=Dx;$5=Dy;$6=Dz' } .
105     "| rtrace -h -ff -ab 0 -w $octree | total -if3 -16 -m";
106 greg 2.7 if (@sundir) {
107     $suncmd = "cnt " . ($nbins-1) .
108     " | rcalc -e MF:$mf -e '$rhcal' -e Rbin=recno " .
109     "-e 'dot=Dx*$sundir[0] + Dy*$sundir[1] + Dz*$sundir[2]' " .
110     "-e 'cond=dot-.866' " .
111     q{-e '$1=if(1-dot,acos(dot),0);$2=Romega;$3=recno' };
112     }
113 greg 2.6 }
114 greg 2.8 my @tregval;
115     if ($dosky) {
116     # Create octree for rtrace
117     open OCONV, "| oconv - > $octree";
118     print OCONV @skydesc;
119     print OCONV "skyfunc glow skyglow 0 0 4 @skycolor 0\n";
120     print OCONV "skyglow source sky 0 0 4 0 0 1 360\n";
121     close OCONV;
122     # Run rtrace and average output for every 16 samples
123     @tregval = `$tregcommand`;
124     unlink $octree;
125     } else {
126     push @tregval, "0\t0\t0\n" for (1..$nbins);
127     }
128 greg 2.1 # Find closest 3 patches to sun and divvy up direct solar contribution
129 greg 2.6 sub numSort1 {
130     my @a1 = split("\t", $a);
131     my @b1 = split("\t", $b);
132     return ($a1[0] <=> $b1[0]);
133     }
134 greg 2.1 if (@sundir) {
135     my $somega = ($sundir[3]/360)**2 * 3.141592654**3;
136 greg 2.6 my @bestdir = `$suncmd`;
137     @bestdir = sort numSort1 @bestdir;
138 greg 2.1 my (@ang, @dom, @ndx);
139     my $wtot = 0;
140     for my $i (0..2) {
141 greg 2.5 ($ang[$i], $dom[$i], $ndx[$i]) = split(' ', $bestdir[$i]);
142 greg 2.1 $wtot += 1./($ang[$i]+.02);
143     }
144     for my $i (0..2) {
145     my $wt = 1./($ang[$i]+.02)/$wtot * $somega / $dom[$i];
146 greg 2.5 my @scolor = split(' ', $tregval[$ndx[$i]]);
147 greg 2.1 for my $j (0..2) { $scolor[$j] += $wt * $sunval[$j]; }
148 greg 2.4 $tregval[$ndx[$i]] = "$scolor[0]\t$scolor[1]\t$scolor[2]\n";
149 greg 2.1 }
150     }
151 greg 2.9 # Output header if requested
152     if ($headout) {
153     print "#?RADIANCE\n";
154     print "genskyvec @origARGV\n";
155     print "NROWS=", $#tregval+1, "\n";
156     print "NCOLS=1\nNCOMP=3\n";
157     print "FORMAT=ascii\n";
158     print "\n";
159     }
160 greg 2.1 # Output our final vector
161     print @tregval;
