root/radiance/ray/src/util/genskyvec.pl
Tue Jun 5 01:25:11 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.10: +23 -14 lines
Taoning added (secret) '-5' option for 5-phase calculation
Mon Dec 12 17:40:07 2016 UTC (8 years, 7 months ago) by greg
Changes since 2.9: +3 -1 lines
Added check for bad argument
Wed Sep 17 22:40:49 2014 UTC (10 years, 10 months ago) by greg
CVS Tags: rad4R2P2, rad5R0
Changes since 2.8: +14 -1 lines
Thu Jun 28 20:48:03 2012 UTC (13 years, 1 month ago) by greg
CVS Tags: rad4R2, rad4R2P1
Changes since 2.7: +19 -11 lines
Added -d option for sun-only vector
Thu Sep 29 22:36:11 2011 UTC (13 years, 10 months ago) by greg
Changes since 2.6: +15 -11 lines
Fixed bug when no sun present
Mon May 16 23:56:32 2011 UTC (14 years, 2 months ago) by greg
Changes since 2.5: +59 -39 lines
Made scripts Windows-compatible.  Thanks to Andy McNeil for sorting it out
Thu Jan 27 22:28:12 2011 UTC (14 years, 6 months ago) by greg
Changes since 2.4: +5 -5 lines
Sat Jan 23 22:30:29 2010 UTC (15 years, 6 months ago) by greg
Made it so solar lines use same separator (tabs)
Wed Dec 9 21:30:48 2009 UTC (15 years, 7 months ago) by greg
Changes since 2.2: +9 -5 lines
Added -m option to control sky subdivision
Mon Jul 13 23:45:08 2009 UTC (16 years ago) by greg
Fixed bug in ground sampling vectors
Thu Jul 2 02:13:08 2009 UTC (16 years, 1 month ago) by greg
