root/radiance/ray/src/util/genklemsamp.pl
Revision: 2.13
Committed: Sun Feb 28 00:28:36 2016 UTC (8 years, 1 month ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R1, rad5R3, HEAD
Fix for git bash
# User Rev Content
1 greg 2.1 #!/usr/bin/perl -w
2 greg 2.13 # RCSid $Id: genklemsamp.pl,v 2.12 2012/06/28 17:35:18 greg Exp $
3 greg 2.1 #
4     # Sample Klems (full) directions impinging on surface(s)
5     #
6 greg 2.2 # G. Ward
7     #
8 greg 2.3 use strict;
9 greg 2.11 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 greg 2.10 use File::Temp qw/ :mktemp /;
11 greg 2.1 if ($#ARGV < 0) {
12 greg 2.4 print STDERR "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n";
13 greg 2.1 exit 1;
14     }
15     my $nsamp = 1000;
16     my $fmt = "a";
17     my @vopts="-vo 1e-5";
18     while ($#ARGV >= 0) {
19     if ("$ARGV[0]" eq "-c") {
20     shift @ARGV;
21     $nsamp = $ARGV[0];
22     } elsif ("$ARGV[0]" =~ /^-f[afd]$/) {
23     $fmt = substr($ARGV[0], 2, 1);
24     } elsif ("$ARGV[0]" =~ /^-v[pdu]$/) {
25     push @vopts, "@ARGV[0..3]";
26     shift @ARGV; shift @ARGV; shift @ARGV;
27     } elsif ("$ARGV[0]" =~ /^-v[fhvo]$/) {
28     push @vopts, "@ARGV[0..1]";
29     shift @ARGV;
30     } elsif ("$ARGV[0]" =~ /^-v./) {
31 greg 2.4 print STDERR "Unsupported view option: $ARGV[0]\n";
32 greg 2.1 exit 1;
33     } elsif ("$ARGV[0]" =~ /^-./) {
34 greg 2.4 print STDERR "Unknown option: $ARGV[0]\n";
35 greg 2.1 exit 1;
36     } else {
37     last;
38     }
39     shift @ARGV;
40     }
41     my $ofmt = "";
42     $ofmt = "-o$fmt" if ("$fmt" ne "a");
43     # Require parallel view and compile settings
44     push @vopts, "-vtl";
45     my $vwset = `vwright @vopts V`;
46 greg 2.11 chomp $vwset;
47 greg 2.1 $_ = $vwset; s/^.*Vhn://; s/;.*$//;
48     my $width = $_;
49     $_ = $vwset; s/^.*Vvn://; s/;.*$//;
50     my $height = $_;
51     my $sca = sqrt($nsamp/($width*$height));
52     # Kbin is input to get direction in full Klems basis with (x1,x2) randoms
53 greg 2.11 my $tcal = 'DEGREE : PI/180;' .
54     'Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);' .
55     'Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);' .
56     'Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);' .
57     'Kmax : Kaccum(Knaz(0));' .
58     'Kfindrow(r, rem) : if(rem-Knaz(r)-.5, Kfindrow(r+1, rem-Knaz(r)), r);' .
59     'Krow = if(Kbin-(Kmax+.5), 0, Kfindrow(1, Kbin));' .
60     'Kcol = Kbin - Kaccum(Krow-1) - 1;' .
61     'Kazi = 360*DEGREE * (Kcol + .5 - x2) / Knaz(Krow);' .
62     'Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));' .
63     'sin_kpol = sin(Kpol);' .
64     'K0 = cos(Kazi)*sin_kpol;' .
65     'K1 = sin(Kazi)*sin_kpol;' .
66     'K2 = sqrt(1 - sin_kpol*sin_kpol);' ;
67 greg 2.1 my $ndiv = 145;
68 greg 2.11 my ($td, $inchk, $rmtmp, $orgcnt);
69     if ($windoz) {
70     my $tmploc = `echo \%TMP\%`;
71     chomp($tmploc);
72     $td = mkdtemp("$tmploc\\genklemsamp.XXXXXX");
73     chomp $td;
74     $inchk = "rtrace -w -h -opLN $td\\surf.oct " .
75     q{| rcalc -e "cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3" } .
76     "-e \"and(a,b):if(a,b,a);sq(x):x*x\" -e \"$vwset\" " .
77     q{-e "nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999" } .
78     " > $td\\origins.txt";
79 greg 2.13 $rmtmp = "rd /S /Q $td";
80 greg 2.11 } else {
81     $td = mkdtemp("/tmp/genklemsamp.XXXXXX");
82     chomp $td;
83     $inchk = "rtrace -w -h -faf -opLN $td/surf.oct " .
84     q{| rcalc -e 'cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3' } .
85     "-e 'and(a,b):if(a,b,a);sq(x):x*x' -e '$vwset' " .
86     q{-e 'nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999' } .
87     "-if7 -of > $td/origins.flt";
88     $rmtmp = "rm -rf $td";
89     }
90     sub GetNOrigins {
91     if ($windoz) {
92     my $count = 0;
93     open(FILE, "< $td\\origins.txt");
94     $count++ while <FILE>;
95     close(FILE);
96     return $count;
97     }
98     return (-s "$td/origins.flt") / (4*3);
99     }
100 greg 2.1 # Do we have any Radiance input files?
101     if ($#ARGV >= 0) {
102 greg 2.12 system "xform -m void @ARGV | oconv - > $td/surf.oct";
103 greg 2.1 # Set our own view center and size based on bounding cube
104     $_ = $vwset; s/^.*Vdx://; s/;.*$//;
105     my @vd = $_;
106     $_ = $vwset; s/^.*Vdy://; s/;.*$//;
107     push @vd, $_;
108     $_ = $vwset; s/^.*Vdz://; s/;.*$//;
109     push @vd, $_;
110 greg 2.8 my @bcube = split ' ', `getinfo -d < $td/surf.oct`;
111 greg 2.1 $width = $bcube[3]*sqrt(3);
112     $height = $width;
113     push @vopts, ("-vp", $bcube[0]+$bcube[3]/2-$width/2*$vd[0],
114     $bcube[1]+$bcube[3]/2-$width/2*$vd[1],
115     $bcube[2]+$bcube[3]/2-$width/2*$vd[2]);
116 greg 2.7 push @vopts, ("-vh", $width, "-vv", $height);
117 greg 2.1 $vwset = `vwright @vopts V`;
118 greg 2.6 $sca = sqrt($nsamp/($width*$height));
119 greg 2.1 my $xres;
120     my $yres;
121 greg 2.4 my $ntot = 0;
122 greg 2.1 # This generally passes through the loop twice to get density right
123 greg 2.4 while ($ntot < $nsamp) {
124 greg 2.1 $xres = int($width*$sca) + 1;
125     $yres = int($height*$sca) + 1;
126 greg 2.11 system "vwrays -x $xres -y $yres -pa 0 -pj .7 @vopts | $inchk";
127     $ntot = GetNOrigins();
128 greg 2.1 if ($ntot == 0) {
129 greg 2.6 if ($nsamp < 200) {
130 greg 2.4 $sca = sqrt(200/($width*$height));
131     redo;
132     }
133     print STDERR "View direction does not correspond to any surfaces\n";
134 greg 2.1 exit 1;
135     }
136     $sca *= 1.05 * sqrt($nsamp/$ntot);
137 greg 2.4 }
138 greg 2.1 # All set to produce our samples
139 greg 2.4 for (my $k = 1; $k <= $ndiv; $k++) {
140 greg 2.1 my $rn = rand(10);
141     my $r1 = rand; my $r2 = rand;
142     # Chance of using = (number_still_needed)/(number_left_avail)
143 greg 2.11 if ($windoz) {
144     system "rcalc $ofmt -e \"$tcal\" -e \"$vwset\" " .
145     "-e \"cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)\" " .
146     "-e \"Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)\" " .
147     q{-e "$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz" } .
148     q{-e "$4=-K0*Vhx-K1*Vvx+K2*Vdx" } .
149     q{-e "$5=-K0*Vhy-K1*Vvy+K2*Vdy" } .
150     q{-e "$6=-K0*Vhz-K1*Vvz+K2*Vdz" } .
151     "$td\\origins.txt";
152     } else {
153     system "rcalc $ofmt -e '$tcal' -e '$vwset' " .
154 greg 2.1 "-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " .
155     "-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " .
156     q{-e '$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz' } .
157 greg 2.9 q{-e '$4=-K0*Vhx-K1*Vvx+K2*Vdx' } .
158     q{-e '$5=-K0*Vhy-K1*Vvy+K2*Vdy' } .
159     q{-e '$6=-K0*Vhz-K1*Vvz+K2*Vdz' } .
160 greg 2.1 "-if3 $td/origins.flt";
161 greg 2.11 }
162 greg 2.1 }
163     } else {
164     # No Radiance input files, so just sample over parallel view
165     my $xres = int($width*$sca) + 1;
166     my $yres = int($height*$sca) + 1;
167     my $ntot = $xres * $yres;
168 greg 2.4 for (my $k = 1; $k <= $ndiv; $k++) {
169 greg 2.1 my $rn = rand(10);
170     my $r1 = rand; my $r2 = rand;
171     my $r3 = rand; my $r4 = rand;
172     # Chance of using = (number_still_needed)/(number_left_avail)
173 greg 2.11 if ($windoz) {
174     system "cnt $yres $xres | rcalc $ofmt -e \"$tcal\" -e \"$vwset\" " .
175     "-e \"xc=\$2;yc=\$1\" ".
176     "-e \"cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)\" " .
177     "-e \"Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)\" " .
178     "-e \"hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)\" " .
179     "-e \"vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)\" " .
180     q{-e "$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx" } .
181     q{-e "$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy" } .
182     q{-e "$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz" } .
183     q{-e "$4=-K0*Vhx-K1*Vvx+K2*Vdx" } .
184     q{-e "$5=-K0*Vhy-K1*Vvy+K2*Vdy" } .
185     q{-e "$6=-K0*Vhz-K1*Vvz+K2*Vdz" } ;
186     } else {
187     system "cnt $yres $xres | rcalc $ofmt -e '$tcal' -e '$vwset' " .
188 greg 2.1 q{-e 'xc=$2;yc=$1' } .
189     "-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " .
190     "-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " .
191     "-e 'hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)' " .
192     "-e 'vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)' " .
193     q{-e '$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx' } .
194     q{-e '$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy' } .
195     q{-e '$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz' } .
196 greg 2.9 q{-e '$4=-K0*Vhx-K1*Vvx+K2*Vdx' } .
197     q{-e '$5=-K0*Vhy-K1*Vvy+K2*Vdy' } .
198     q{-e '$6=-K0*Vhz-K1*Vvz+K2*Vdz' } ;
199 greg 2.11 }
200 greg 2.1 }
201     }
202 greg 2.11 system $rmtmp;
