root/Development/ray/src/util/genklemsamp.pl
Revision: 2.5
Committed: Fri Jun 19 18:42:06 2009 UTC (16 years, 4 months ago) by greg
Changes since 2.4: +8 -8 lines
Fixed bug in coordinate orientation
1 #!/usr/bin/perl -w
2 # RCSid $Id: genklemsamp.pl,v 2.4 2009/06/19 06:49:42 greg Exp $
3 #
4 # Sample Klems (full) directions impinging on surface(s)
5 #
6 # G. Ward
7 #
8 use strict;
9 if ($#ARGV < 0) {
10 print STDERR "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n";
11 exit 1;
12 }
13 my $td = `mktemp -d /tmp/genklemsamp.XXXXXX`;
14 chomp $td;
15 my $nsamp = 1000;
16 my $fmt = "a";
17 my @vopts="-vo 1e-5";
18 while ($#ARGV >= 0) {
19 if ("$ARGV[0]" eq "-c") {
20 shift @ARGV;
21 $nsamp = $ARGV[0];
22 } elsif ("$ARGV[0]" =~ /^-f[afd]$/) {
23 $fmt = substr($ARGV[0], 2, 1);
24 } elsif ("$ARGV[0]" =~ /^-v[pdu]$/) {
25 push @vopts, "@ARGV[0..3]";
26 shift @ARGV; shift @ARGV; shift @ARGV;
27 } elsif ("$ARGV[0]" =~ /^-v[fhvo]$/) {
28 push @vopts, "@ARGV[0..1]";
29 shift @ARGV;
30 } elsif ("$ARGV[0]" =~ /^-v./) {
31 print STDERR "Unsupported view option: $ARGV[0]\n";
32 exit 1;
33 } elsif ("$ARGV[0]" =~ /^-./) {
34 print STDERR "Unknown option: $ARGV[0]\n";
35 exit 1;
36 } else {
37 last;
38 }
39 shift @ARGV;
40 }
41 my $ofmt = "";
42 $ofmt = "-o$fmt" if ("$fmt" ne "a");
43 # Require parallel view and compile settings
44 push @vopts, "-vtl";
45 my $vwset = `vwright @vopts V`;
46 $_ = $vwset; s/^.*Vhn://; s/;.*$//;
47 my $width = $_;
48 $_ = $vwset; s/^.*Vvn://; s/;.*$//;
49 my $height = $_;
50 my $sca = sqrt($nsamp/($width*$height));
51 # Kbin is input to get direction in full Klems basis with (x1,x2) randoms
52 my $tcal = '
53 DEGREE : PI/180;
54 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
55 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
56 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
57 Kmax : Kaccum(Knaz(0));
58 Kfindrow(r, rem) : if(rem-Knaz(r)-.5, Kfindrow(r+1, rem-Knaz(r)), r);
59 Krow = if(Kbin-(Kmax+.5), 0, Kfindrow(1, Kbin));
60 Kcol = Kbin - Kaccum(Krow-1) - 1;
61 Kazi = 360*DEGREE * (Kcol + .5 - x2) / Knaz(Krow);
62 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
63 sin_kpol = sin(Kpol);
64 K0 = cos(Kazi)*sin_kpol;
65 K1 = sin(Kazi)*sin_kpol;
66 K2 = sqrt(1 - sin_kpol*sin_kpol);
67 ';
68 my $ndiv = 145;
69 # Do we have any Radiance input files?
70 if ($#ARGV >= 0) {
71 system "oconv -f @ARGV > $td/surf.oct";
72 # Set our own view center and size based on bounding cube
73 $_ = $vwset; s/^.*Vdx://; s/;.*$//;
74 my @vd = $_;
75 $_ = $vwset; s/^.*Vdy://; s/;.*$//;
76 push @vd, $_;
77 $_ = $vwset; s/^.*Vdz://; s/;.*$//;
78 push @vd, $_;
79 my @bcube = split /\s+/, `getinfo -d < $td/surf.oct`;
80 $width = $bcube[3]*sqrt(3);
81 $height = $width;
82 push @vopts, ("-vp", $bcube[0]+$bcube[3]/2-$width/2*$vd[0],
83 $bcube[1]+$bcube[3]/2-$width/2*$vd[1],
84 $bcube[2]+$bcube[3]/2-$width/2*$vd[2]);
85 push @vopts, ("-vh", $width, "-vh", $height);
86 $vwset = `vwright @vopts V`;
87 my $xres;
88 my $yres;
89 my $ntot = 0;
90 # This generally passes through the loop twice to get density right
91 while ($ntot < $nsamp) {
92 $xres = int($width*$sca) + 1;
93 $yres = int($height*$sca) + 1;
94 system "vwrays -ff -x $xres -y $yres -pa 0 -pj .7 @vopts " .
95 "| rtrace -w -h -ff -opLN $td/surf.oct " .
96 q{| rcalc -e 'cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3' } .
97 "-e 'and(a,b):if(a,b,a);sq(x):x*x' -e '$vwset' " .
98 q{-e 'nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999' } .
99 "-if7 -of > $td/origins.flt";
100 $ntot = -s "$td/origins.flt";
101 $ntot /= 3*4;
102 if ($ntot == 0) {
103 if ($sca < sqrt(199/($width*$height))) {
104 $sca = sqrt(200/($width*$height));
105 redo;
106 }
107 print STDERR "View direction does not correspond to any surfaces\n";
108 exit 1;
109 }
110 $sca *= 1.05 * sqrt($nsamp/$ntot);
111 }
112 # All set to produce our samples
113 for (my $k = 1; $k <= $ndiv; $k++) {
114 my $rn = rand(10);
115 my $r1 = rand; my $r2 = rand;
116 # Chance of using = (number_still_needed)/(number_left_avail)
117 system "rcalc $ofmt -e '$tcal' -e '$vwset' " .
118 "-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " .
119 "-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " .
120 q{-e '$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz' } .
121 q{-e '$4=K0*Vhx-K1*Vvx+K2*Vdx' } .
122 q{-e '$5=K0*Vhy-K1*Vvy+K2*Vdy' } .
123 q{-e '$6=K0*Vhz-K1*Vvz+K2*Vdz' } .
124 "-if3 $td/origins.flt";
125 }
126 } else {
127 # No Radiance input files, so just sample over parallel view
128 my $xres = int($width*$sca) + 1;
129 my $yres = int($height*$sca) + 1;
130 my $ntot = $xres * $yres;
131 for (my $k = 1; $k <= $ndiv; $k++) {
132 my $rn = rand(10);
133 my $r1 = rand; my $r2 = rand;
134 my $r3 = rand; my $r4 = rand;
135 # Chance of using = (number_still_needed)/(number_left_avail)
136 system "cnt $yres $xres | rcalc $ofmt -e '$tcal' -e '$vwset' " .
137 q{-e 'xc=$2;yc=$1' } .
138 "-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " .
139 "-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " .
140 "-e 'hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)' " .
141 "-e 'vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)' " .
142 q{-e '$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx' } .
143 q{-e '$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy' } .
144 q{-e '$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz' } .
145 q{-e '$4=K0*Vhx-K1*Vvx+K2*Vdx' } .
146 q{-e '$5=K0*Vhy-K1*Vvy+K2*Vdy' } .
147 q{-e '$6=K0*Vhz-K1*Vvz+K2*Vdz' } ;
148 }
149 }
150 system "rm -rf $td";
