| 1 |
#!/usr/bin/perl -w
| 2 |
# RCSid $Id: genklemsamp.pl,v 2.2 2009/06/16 04:54:08 greg Exp $
| 3 |
| 4 |
# Sample Klems (full) directions impinging on surface(s)
| 5 |
| 6 |
# G. Ward
| 7 |
| 8 |
use strict;
| 9 |
if ($#ARGV < 0) {
| 10 |
print STDERR, "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n";
| 11 |
exit 1;
| 12 |
| 13 |
my $td = `mktemp -d /tmp/genklemsamp.XXXXXX`;
| 14 |
chomp $td;
| 15 |
my $nsamp = 1000;
| 16 |
my $fmt = "a";
| 17 |
my @vopts="-vo 1e-5";
| 18 |
while ($#ARGV >= 0) {
| 19 |
if ("$ARGV[0]" eq "-c") {
| 20 |
shift @ARGV;
| 21 |
$nsamp = $ARGV[0];
| 22 |
} elsif ("$ARGV[0]" =~ /^-f[afd]$/) {
| 23 |
$fmt = substr($ARGV[0], 2, 1);
| 24 |
} elsif ("$ARGV[0]" =~ /^-v[pdu]$/) {
| 25 |
push @vopts, "@ARGV[0..3]";
| 26 |
shift @ARGV; shift @ARGV; shift @ARGV;
| 27 |
} elsif ("$ARGV[0]" =~ /^-v[fhvo]$/) {
| 28 |
push @vopts, "@ARGV[0..1]";
| 29 |
shift @ARGV;
| 30 |
} elsif ("$ARGV[0]" =~ /^-v./) {
| 31 |
print STDERR, "Unsupported view option: $ARGV[0]\n";
| 32 |
exit 1;
| 33 |
} elsif ("$ARGV[0]" =~ /^-./) {
| 34 |
print STDERR, "Unknown option: $ARGV[0]\n";
| 35 |
exit 1;
| 36 |
} else {
| 37 |
last;
| 38 |
| 39 |
shift @ARGV;
| 40 |
| 41 |
my $ofmt = "";
| 42 |
$ofmt = "-o$fmt" if ("$fmt" ne "a");
| 43 |
# Require parallel view and compile settings
| 44 |
push @vopts, "-vtl";
| 45 |
my $vwset = `vwright @vopts V`;
| 46 |
$_ = $vwset; s/^.*Vhn://; s/;.*$//;
| 47 |
my $width = $_;
| 48 |
$_ = $vwset; s/^.*Vvn://; s/;.*$//;
| 49 |
my $height = $_;
| 50 |
my $sca = sqrt($nsamp/($width*$height));
| 51 |
# Kbin is input to get direction in full Klems basis with (x1,x2) randoms
| 52 |
my $tcal = '
| 53 |
DEGREE : PI/180;
| 54 |
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
| 55 |
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
| 56 |
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
| 57 |
Kmax : Kaccum(Knaz(0));
| 58 |
Kfindrow(r, rem) : if(rem-Knaz(r)-.5, Kfindrow(r+1, rem-Knaz(r)), r);
| 59 |
Krow = if(Kbin-(Kmax+.5), 0, Kfindrow(1, Kbin));
| 60 |
Kcol = Kbin - Kaccum(Krow-1) - 1;
| 61 |
Kazi = 360*DEGREE * (Kcol + .5 - x2) / Knaz(Krow);
| 62 |
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
| 63 |
sin_kpol = sin(Kpol);
| 64 |
K0 = cos(Kazi)*sin_kpol;
| 65 |
K1 = sin(Kazi)*sin_kpol;
| 66 |
K2 = cos(Kpol);
| 67 |
| 68 |
my $ndiv = 145;
| 69 |
# Do we have any Radiance input files?
| 70 |
if ($#ARGV >= 0) {
| 71 |
system "oconv -f @ARGV > $td/surf.oct";
| 72 |
# Set our own view center and size based on bounding cube
| 73 |
$_ = $vwset; s/^.*Vdx://; s/;.*$//;
| 74 |
my @vd = $_;
| 75 |
$_ = $vwset; s/^.*Vdy://; s/;.*$//;
| 76 |
push @vd, $_;
| 77 |
$_ = $vwset; s/^.*Vdz://; s/;.*$//;
| 78 |
push @vd, $_;
| 79 |
my @bcube = split /\s+/, `getinfo -d < $td/surf.oct`;
| 80 |
$width = $bcube[3]*sqrt(3);
| 81 |
$height = $width;
| 82 |
push @vopts, ("-vp", $bcube[0]+$bcube[3]/2-$width/2*$vd[0],
| 83 |
$bcube[1]+$bcube[3]/2-$width/2*$vd[1],
| 84 |
$bcube[2]+$bcube[3]/2-$width/2*$vd[2]);
| 85 |
push @vopts, ("-vh", $width, "-vh", $height);
| 86 |
| 87 |
my $xres;
| 88 |
my $yres;
| 89 |
my $ntot;
| 90 |
# This generally passes through the loop twice to get density right
| 91 |
do {
| 92 |
$xres = int($width*$sca) + 1;
| 93 |
$yres = int($height*$sca) + 1;
| 94 |
system "vwrays -ff -x $xres -y $yres -pa 0 -pj .7 @vopts " .
| 95 |
"| rtrace -w -h -ff -opLN $td/surf.oct " .
| 96 |
q{| rcalc -e 'cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3' } .
| 97 |
"-e 'and(a,b):if(a,b,a);sq(x):x*x' -e '$vwset' " .
| 98 |
q{-e 'nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999' } .
| 99 |
"-if7 -of > $td/origins.flt";
| 100 |
$ntot = -s "$td/origins.flt";
| 101 |
$ntot /= 3*4;
| 102 |
if ($ntot == 0) {
| 103 |
print STDERR, "View direction does not correspond to any surfaces\n";
| 104 |
exit 1;
| 105 |
| 106 |
$sca *= 1.05 * sqrt($nsamp/$ntot);
| 107 |
} while ($ntot < $nsamp);
| 108 |
# All set to produce our samples
| 109 |
for ($k = 1; $k <= $ndiv; $k++) {
| 110 |
my $rn = rand(10);
| 111 |
my $r1 = rand; my $r2 = rand;
| 112 |
# Chance of using = (number_still_needed)/(number_left_avail)
| 113 |
system "rcalc $ofmt -e '$tcal' -e '$vwset' " .
| 114 |
"-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " .
| 115 |
"-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " .
| 116 |
q{-e '$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz' } .
| 117 |
q{-e '$4=K0*Vhx+K1*Vvx+K2*Vdx' } .
| 118 |
q{-e '$5=K0*Vhy+K1*Vvy+K2*Vdy' } .
| 119 |
q{-e '$6=K0*Vhz+K1*Vvz+K2*Vdz' } .
| 120 |
"-if3 $td/origins.flt";
| 121 |
| 122 |
} else {
| 123 |
# No Radiance input files, so just sample over parallel view
| 124 |
my $xres = int($width*$sca) + 1;
| 125 |
my $yres = int($height*$sca) + 1;
| 126 |
my $ntot = $xres * $yres;
| 127 |
| 128 |
my $rn = rand(10);
| 129 |
| 130 |
my $r3 = rand; my $r4 = rand;
| 131 |
| 132 |
system "cnt $yres $xres | rcalc $ofmt -e '$tcal' -e '$vwset' " .
| 133 |
q{-e 'xc=$2;yc=$1' } .
| 134 |
| 135 |
| 136 |
"-e 'hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)' " .
| 137 |
"-e 'vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)' " .
| 138 |
q{-e '$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx' } .
| 139 |
q{-e '$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy' } .
| 140 |
q{-e '$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz' } .
| 141 |
| 142 |
| 143 |
q{-e '$6=K0*Vhz+K1*Vvz+K2*Vdz' } ;
| 144 |
| 145 |
| 146 |
system "rm -rf $td";
