| 1 |
#!/usr/bin/perl -w |
| 2 |
# RCSid $Id: genklemsamp.pl,v 2.9 2011/04/11 03:47:46 greg Exp $ |
| 3 |
| 4 |
# Sample Klems (full) directions impinging on surface(s) |
| 5 |
| 6 |
# G. Ward |
| 7 |
| 8 |
use strict; |
| 9 |
use File::Temp qw/ :mktemp /; |
| 10 |
if ($#ARGV < 0) { |
| 11 |
print STDERR "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n"; |
| 12 |
exit 1; |
| 13 |
| 14 |
my $td = mkdtemp("/tmp/genklemsamp.XXXXXX"); |
| 15 |
chomp $td; |
| 16 |
my $nsamp = 1000; |
| 17 |
my $fmt = "a"; |
| 18 |
my @vopts="-vo 1e-5"; |
| 19 |
while ($#ARGV >= 0) { |
| 20 |
if ("$ARGV[0]" eq "-c") { |
| 21 |
shift @ARGV; |
| 22 |
$nsamp = $ARGV[0]; |
| 23 |
} elsif ("$ARGV[0]" =~ /^-f[afd]$/) { |
| 24 |
$fmt = substr($ARGV[0], 2, 1); |
| 25 |
} elsif ("$ARGV[0]" =~ /^-v[pdu]$/) { |
| 26 |
push @vopts, "@ARGV[0..3]"; |
| 27 |
shift @ARGV; shift @ARGV; shift @ARGV; |
| 28 |
} elsif ("$ARGV[0]" =~ /^-v[fhvo]$/) { |
| 29 |
push @vopts, "@ARGV[0..1]"; |
| 30 |
shift @ARGV; |
| 31 |
} elsif ("$ARGV[0]" =~ /^-v./) { |
| 32 |
print STDERR "Unsupported view option: $ARGV[0]\n"; |
| 33 |
exit 1; |
| 34 |
} elsif ("$ARGV[0]" =~ /^-./) { |
| 35 |
print STDERR "Unknown option: $ARGV[0]\n"; |
| 36 |
exit 1; |
| 37 |
} else { |
| 38 |
last; |
| 39 |
| 40 |
shift @ARGV; |
| 41 |
| 42 |
my $ofmt = ""; |
| 43 |
$ofmt = "-o$fmt" if ("$fmt" ne "a"); |
| 44 |
# Require parallel view and compile settings |
| 45 |
push @vopts, "-vtl"; |
| 46 |
my $vwset = `vwright @vopts V`; |
| 47 |
$_ = $vwset; s/^.*Vhn://; s/;.*$//; |
| 48 |
my $width = $_; |
| 49 |
$_ = $vwset; s/^.*Vvn://; s/;.*$//; |
| 50 |
my $height = $_; |
| 51 |
my $sca = sqrt($nsamp/($width*$height)); |
| 52 |
# Kbin is input to get direction in full Klems basis with (x1,x2) randoms |
| 53 |
my $tcal = ' |
| 54 |
DEGREE : PI/180; |
| 55 |
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90); |
| 56 |
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12); |
| 57 |
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0); |
| 58 |
Kmax : Kaccum(Knaz(0)); |
| 59 |
Kfindrow(r, rem) : if(rem-Knaz(r)-.5, Kfindrow(r+1, rem-Knaz(r)), r); |
| 60 |
Krow = if(Kbin-(Kmax+.5), 0, Kfindrow(1, Kbin)); |
| 61 |
Kcol = Kbin - Kaccum(Krow-1) - 1; |
| 62 |
Kazi = 360*DEGREE * (Kcol + .5 - x2) / Knaz(Krow); |
| 63 |
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1)); |
| 64 |
sin_kpol = sin(Kpol); |
| 65 |
K0 = cos(Kazi)*sin_kpol; |
| 66 |
K1 = sin(Kazi)*sin_kpol; |
| 67 |
K2 = sqrt(1 - sin_kpol*sin_kpol); |
| 68 |
| 69 |
my $ndiv = 145; |
| 70 |
# Do we have any Radiance input files? |
| 71 |
if ($#ARGV >= 0) { |
| 72 |
system "oconv -f @ARGV > $td/surf.oct"; |
| 73 |
# Set our own view center and size based on bounding cube |
| 74 |
$_ = $vwset; s/^.*Vdx://; s/;.*$//; |
| 75 |
my @vd = $_; |
| 76 |
$_ = $vwset; s/^.*Vdy://; s/;.*$//; |
| 77 |
push @vd, $_; |
| 78 |
$_ = $vwset; s/^.*Vdz://; s/;.*$//; |
| 79 |
push @vd, $_; |
| 80 |
my @bcube = split ' ', `getinfo -d < $td/surf.oct`; |
| 81 |
$width = $bcube[3]*sqrt(3); |
| 82 |
$height = $width; |
| 83 |
push @vopts, ("-vp", $bcube[0]+$bcube[3]/2-$width/2*$vd[0], |
| 84 |
$bcube[1]+$bcube[3]/2-$width/2*$vd[1], |
| 85 |
$bcube[2]+$bcube[3]/2-$width/2*$vd[2]); |
| 86 |
push @vopts, ("-vh", $width, "-vv", $height); |
| 87 |
| 88 |
| 89 |
my $xres; |
| 90 |
my $yres; |
| 91 |
my $ntot = 0; |
| 92 |
# This generally passes through the loop twice to get density right |
| 93 |
while ($ntot < $nsamp) { |
| 94 |
$xres = int($width*$sca) + 1; |
| 95 |
$yres = int($height*$sca) + 1; |
| 96 |
system "vwrays -ff -x $xres -y $yres -pa 0 -pj .7 @vopts " . |
| 97 |
"| rtrace -w -h -ff -opLN $td/surf.oct " . |
| 98 |
q{| rcalc -e 'cond=and(5e9-$4,nOK);$1=$1;$2=$2;$3=$3' } . |
| 99 |
"-e 'and(a,b):if(a,b,a);sq(x):x*x' -e '$vwset' " . |
| 100 |
q{-e 'nOK=sq(Vdx*$5+Vdy*$6+Vdz*$7)-.999' } . |
| 101 |
"-if7 -of > $td/origins.flt"; |
| 102 |
$ntot = -s "$td/origins.flt"; |
| 103 |
$ntot /= 3*4; # number of bytes per sample position |
| 104 |
if ($ntot == 0) { |
| 105 |
if ($nsamp < 200) { |
| 106 |
$sca = sqrt(200/($width*$height)); |
| 107 |
redo; |
| 108 |
| 109 |
print STDERR "View direction does not correspond to any surfaces\n"; |
| 110 |
exit 1; |
| 111 |
| 112 |
$sca *= 1.05 * sqrt($nsamp/$ntot); |
| 113 |
| 114 |
# All set to produce our samples |
| 115 |
for (my $k = 1; $k <= $ndiv; $k++) { |
| 116 |
my $rn = rand(10); |
| 117 |
my $r1 = rand; my $r2 = rand; |
| 118 |
# Chance of using = (number_still_needed)/(number_left_avail) |
| 119 |
system "rcalc $ofmt -e '$tcal' -e '$vwset' " . |
| 120 |
"-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " . |
| 121 |
"-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " . |
| 122 |
q{-e '$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz' } . |
| 123 |
q{-e '$4=-K0*Vhx-K1*Vvx+K2*Vdx' } . |
| 124 |
q{-e '$5=-K0*Vhy-K1*Vvy+K2*Vdy' } . |
| 125 |
q{-e '$6=-K0*Vhz-K1*Vvz+K2*Vdz' } . |
| 126 |
"-if3 $td/origins.flt"; |
| 127 |
| 128 |
} else { |
| 129 |
# No Radiance input files, so just sample over parallel view |
| 130 |
my $xres = int($width*$sca) + 1; |
| 131 |
my $yres = int($height*$sca) + 1; |
| 132 |
my $ntot = $xres * $yres; |
| 133 |
| 134 |
| 135 |
| 136 |
my $r3 = rand; my $r4 = rand; |
| 137 |
| 138 |
system "cnt $yres $xres | rcalc $ofmt -e '$tcal' -e '$vwset' " . |
| 139 |
q{-e 'xc=$2;yc=$1' } . |
| 140 |
| 141 |
| 142 |
"-e 'hpos=Vhn*((xc+rand($r3+recno))/$xres - .5)' " . |
| 143 |
"-e 'vpos=Vvn*((yc+rand($r4+recno))/$yres - .5)' " . |
| 144 |
q{-e '$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx' } . |
| 145 |
q{-e '$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy' } . |
| 146 |
q{-e '$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz' } . |
| 147 |
| 148 |
| 149 |
q{-e '$6=-K0*Vhz-K1*Vvz+K2*Vdz' } ; |
| 150 |
| 151 |
| 152 |
system "rm -rf $td"; |
