--- ray/src/util/genklemsamp.pl 2009/06/16 04:54:08 2.2 +++ ray/src/util/genklemsamp.pl 2009/11/05 06:30:57 2.6 @@ -1,12 +1,13 @@ #!/usr/bin/perl -w -# RCSid $Id: genklemsamp.pl,v 2.2 2009/06/16 04:54:08 greg Exp $ +# RCSid $Id: genklemsamp.pl,v 2.6 2009/11/05 06:30:57 greg Exp $ # # Sample Klems (full) directions impinging on surface(s) # # G. Ward # +use strict; if ($#ARGV < 0) { - print STDERR, "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n"; + print STDERR "Usage: genklemsamp [-c N ][-f{a|f|d}] [view opts] [geom.rad ..]\n"; exit 1; } my $td = `mktemp -d /tmp/genklemsamp.XXXXXX`; @@ -27,10 +28,10 @@ while ($#ARGV >= 0) { push @vopts, "@ARGV[0..1]"; shift @ARGV; } elsif ("$ARGV[0]" =~ /^-v./) { - print STDERR, "Unsupported view option: $ARGV[0]\n"; + print STDERR "Unsupported view option: $ARGV[0]\n"; exit 1; } elsif ("$ARGV[0]" =~ /^-./) { - print STDERR, "Unknown option: $ARGV[0]\n"; + print STDERR "Unknown option: $ARGV[0]\n"; exit 1; } else { last; @@ -62,7 +63,7 @@ Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1) sin_kpol = sin(Kpol); K0 = cos(Kazi)*sin_kpol; K1 = sin(Kazi)*sin_kpol; -K2 = cos(Kpol); +K2 = sqrt(1 - sin_kpol*sin_kpol); '; my $ndiv = 145; # Do we have any Radiance input files? @@ -83,11 +84,12 @@ if ($#ARGV >= 0) { $bcube[2]+$bcube[3]/2-$width/2*$vd[2]); push @vopts, ("-vh", $width, "-vh", $height); $vwset = `vwright @vopts V`; + $sca = sqrt($nsamp/($width*$height)); my $xres; my $yres; - my $ntot; + my $ntot = 0; # This generally passes through the loop twice to get density right - do { + while ($ntot < $nsamp) { $xres = int($width*$sca) + 1; $yres = int($height*$sca) + 1; system "vwrays -ff -x $xres -y $yres -pa 0 -pj .7 @vopts " . @@ -99,13 +101,17 @@ if ($#ARGV >= 0) { $ntot = -s "$td/origins.flt"; $ntot /= 3*4; if ($ntot == 0) { - print STDERR, "View direction does not correspond to any surfaces\n"; + if ($nsamp < 200) { + $sca = sqrt(200/($width*$height)); + redo; + } + print STDERR "View direction does not correspond to any surfaces\n"; exit 1; } $sca *= 1.05 * sqrt($nsamp/$ntot); - } while ($ntot < $nsamp); + } # All set to produce our samples - for ($k = 1; $k <= $ndiv; $k++) { + for (my $k = 1; $k <= $ndiv; $k++) { my $rn = rand(10); my $r1 = rand; my $r2 = rand; # Chance of using = (number_still_needed)/(number_left_avail) @@ -113,9 +119,9 @@ if ($#ARGV >= 0) { "-e 'cond=($nsamp-outno+1)/($ntot-recno+1)-rand($rn+recno)' " . "-e 'Kbin=$k;x1=rand($r1+recno);x2=rand($r2+recno)' " . q{-e '$1=$1+Vo*Vdx; $2=$2+Vo*Vdy; $3=$3+Vo*Vdz' } . - q{-e '$4=K0*Vhx+K1*Vvx+K2*Vdx' } . - q{-e '$5=K0*Vhy+K1*Vvy+K2*Vdy' } . - q{-e '$6=K0*Vhz+K1*Vvz+K2*Vdz' } . + q{-e '$4=K0*Vhx-K1*Vvx+K2*Vdx' } . + q{-e '$5=K0*Vhy-K1*Vvy+K2*Vdy' } . + q{-e '$6=K0*Vhz-K1*Vvz+K2*Vdz' } . "-if3 $td/origins.flt"; } } else { @@ -123,7 +129,7 @@ if ($#ARGV >= 0) { my $xres = int($width*$sca) + 1; my $yres = int($height*$sca) + 1; my $ntot = $xres * $yres; - for ($k = 1; $k <= $ndiv; $k++) { + for (my $k = 1; $k <= $ndiv; $k++) { my $rn = rand(10); my $r1 = rand; my $r2 = rand; my $r3 = rand; my $r4 = rand; @@ -137,9 +143,9 @@ if ($#ARGV >= 0) { q{-e '$1=Vpx+Vo*Vdx+hpos*Vhx+vpos*Vvx' } . q{-e '$2=Vpy+Vo*Vdy+hpos*Vhy+vpos*Vvy' } . q{-e '$3=Vpz+Vo*Vdz+hpos*Vhz+vpos*Vvz' } . - q{-e '$4=K0*Vhx+K1*Vvx+K2*Vdx' } . - q{-e '$5=K0*Vhy+K1*Vvy+K2*Vdy' } . - q{-e '$6=K0*Vhz+K1*Vvz+K2*Vdz' } ; + q{-e '$4=K0*Vhx-K1*Vvx+K2*Vdx' } . + q{-e '$5=K0*Vhy-K1*Vvy+K2*Vdy' } . + q{-e '$6=K0*Vhz-K1*Vvz+K2*Vdz' } ; } } system "rm -rf $td";
