root/radiance/ray/src/util/genklemsamp.pl
Thu Jun 28 17:35:18 2012 UTC (11 years, 11 months ago) by greg
Removed requirement to specify materials in Radiance scene input
Mon May 16 23:56:32 2011 UTC (13 years ago) by greg
Changes since 2.10: +80 -30 lines
Made scripts Windows-compatible.  Thanks to Andy McNeil for sorting it out
Sat Apr 16 00:39:07 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.9: +3 -2 lines
Bug fix for 32-bit OS
Mon Apr 11 03:47:46 2011 UTC (13 years, 1 month ago) by greg
Changes since 2.8: +7 -7 lines
Final fix to Klems angles -- I hope
Thu Jan 27 22:28:12 2011 UTC (13 years, 4 months ago) by greg
Sun Sep 26 15:40:53 2010 UTC (13 years, 8 months ago) by greg
Fixed bug in sampling pattern for input geometry
Thu Nov 5 06:30:57 2009 UTC (14 years, 7 months ago) by greg
Changes since 2.5: +3 -2 lines
Fixed bug in surface sample generator
Fri Jun 19 18:42:06 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.4: +8 -8 lines
Fixed bug in coordinate orientation
Fri Jun 19 06:49:42 2009 UTC (14 years, 11 months ago) by greg
Changes since 2.3: +14 -10 lines
Improvements and bug fixes
Tue Jun 16 17:18:38 2009 UTC (14 years, 11 months ago) by greg
Fixed incorrect expression and other minor improvements
Tue Jun 16 04:54:08 2009 UTC (14 years, 11 months ago) by greg
Sun Jun 14 00:33:16 2009 UTC (14 years, 11 months ago) by greg
