root/radiance/ray/src/util/genambpos.pl
Wed Apr 20 20:57:57 2016 UTC (8 years, 1 month ago) by greg
Diff to previous 2.9 , to selected 2.3
Added missing id count
Wed Sep 3 14:05:55 2014 UTC (9 years, 8 months ago) by greg
Changes since 2.8: +6 -1 lines
Added corral flag highlighting
Thu May 15 17:30:53 2014 UTC (10 years ago) by greg
CVS Tags: rad4R2
Improved geometry
Sat May 10 01:58:22 2014 UTC (10 years ago) by greg
Changes since 2.6: +12 -12 lines
Added significant digits to some of the output formats
Fri May 9 23:49:05 2014 UTC (10 years ago) by greg
Changes since 2.5: +4 -3 lines
Additional checks to avoid errors
Thu May 1 04:51:12 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.4: +8 -4 lines
Added -r option to specify ambient value radius at fixed size
Thu May 1 02:52:03 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.3: +22 -13 lines
Fixed a number of issues with zero values and corrected direction gradient
Sat Apr 26 04:02:03 2014 UTC (10 years, 1 month ago) by greg
Fixed problem when -aa setting is in scientific notation
Fri Apr 25 18:13:47 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.1: +14 -4 lines
Added -w option and changed arrow to reflect weight
Thu Apr 24 23:15:42 2014 UTC (10 years, 1 month ago) by greg
Diff to selected 2.3
Deprecated genambpos and put new Perl script in its place
