| 1 |
#!/usr/bin/perl -w
| 2 |
# RCSid $Id: genBSDF.pl,v 2.79 2018/04/17 18:11:17 greg Exp $
| 3 |
| 4 |
# Compute BSDF based on geometry and material description
| 5 |
| 6 |
# G. Ward
| 7 |
| 8 |
use strict;
| 9 |
my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
| 10 |
use File::Temp qw/ :mktemp /;
| 11 |
sub userror {
| 12 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}a][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
| 13 |
exit 1;
| 14 |
| 15 |
my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
| 16 |
my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph);
| 17 |
my ($curphase, $recovery);
| 18 |
if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) {
| 19 |
$td = $ARGV[1];
| 20 |
open(MYAVH, "< $td/savedARGV.txt") or die "$td: invalid path\n";
| 21 |
@ARGV = <MYAVH>;
| 22 |
close MYAVH;
| 23 |
chomp @ARGV;
| 24 |
$recovery = 0;
| 25 |
if (open(MYPH, "< $td/phase.txt")) {
| 26 |
while (<MYPH>) {
| 27 |
chomp($recovery = $_);
| 28 |
| 29 |
close MYPH;
| 30 |
| 31 |
} elsif ($windoz) {
| 32 |
my $tmploc = `echo \%TMP\%`;
| 33 |
chomp $tmploc;
| 34 |
$td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
| 35 |
} else {
| 36 |
$td = mkdtemp("/tmp/genBSDF.XXXXXX");
| 37 |
chomp $td;
| 38 |
| 39 |
if ($windoz) {
| 40 |
$radscn = "$td\\device.rad";
| 41 |
$mgfscn = "$td\\device.mgf";
| 42 |
$octree = "$td\\device.oct";
| 43 |
$fsender = "$td\\fsender.rad";
| 44 |
$bsender = "$td\\bsender.rad";
| 45 |
$receivers = "$td\\receivers.rad";
| 46 |
$facedat = "$td\\face.dat";
| 47 |
$behinddat = "$td\\behind.dat";
| 48 |
$tf = "$td\\tf.dat";
| 49 |
$rf = "$td\\rf.dat";
| 50 |
$tb = "$td\\tb.dat";
| 51 |
$rb = "$td\\rb.dat";
| 52 |
$tfx = "$td\\tfx.dat";
| 53 |
$rfx = "$td\\rfx.dat";
| 54 |
$tbx = "$td\\tbx.dat";
| 55 |
$rbx = "$td\\rbx.dat";
| 56 |
$tfz = "$td\\tfz.dat";
| 57 |
$rfz = "$td\\rfz.dat";
| 58 |
$tbz = "$td\\tbz.dat";
| 59 |
$rbz = "$td\\rbz.dat";
| 60 |
$cph = "$td\\phase.txt";
| 61 |
$rmtmp = "rd /S /Q $td";
| 62 |
} else {
| 63 |
$radscn = "$td/device.rad";
| 64 |
$mgfscn = "$td/device.mgf";
| 65 |
$octree = "$td/device.oct";
| 66 |
$fsender = "$td/fsender.rad";
| 67 |
$bsender = "$td/bsender.rad";
| 68 |
$receivers = "$td/receivers.rad";
| 69 |
$facedat = "$td/face.dat";
| 70 |
$behinddat = "$td/behind.dat";
| 71 |
$tf = "$td/tf.dat";
| 72 |
$rf = "$td/rf.dat";
| 73 |
$tb = "$td/tb.dat";
| 74 |
$rb = "$td/rb.dat";
| 75 |
$tfx = "$td/tfx.dat";
| 76 |
$rfx = "$td/rfx.dat";
| 77 |
$tbx = "$td/tbx.dat";
| 78 |
$rbx = "$td/rbx.dat";
| 79 |
$tfz = "$td/tfz.dat";
| 80 |
$rfz = "$td/rfz.dat";
| 81 |
$tbz = "$td/tbz.dat";
| 82 |
$rbz = "$td/rbz.dat";
| 83 |
$cph = "$td/phase.txt";
| 84 |
$rmtmp = "rm -rf $td";
| 85 |
| 86 |
my @savedARGV = @ARGV;
| 87 |
my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6 -w-";
| 88 |
my $wrapper = "wrapBSDF";
| 89 |
my $tensortree = 0;
| 90 |
my $ttlog2 = 4;
| 91 |
my $dorecip = 1;
| 92 |
my $nsamp = 2000;
| 93 |
my $mgfin = 0;
| 94 |
my $geout = 1;
| 95 |
my $nproc = 1;
| 96 |
my $docolor = 0;
| 97 |
my $doforw = 0;
| 98 |
my $doback = 1;
| 99 |
my $pctcull = 90;
| 100 |
my $gunit = "meter";
| 101 |
my $curspec = "Visible";
| 102 |
my @dim;
| 103 |
# Get options
| 104 |
while ($#ARGV >= 0) {
| 105 |
if ("$ARGV[0]" =~ /^[-+]m/) {
| 106 |
$mgfin = ("$ARGV[0]" =~ /^\+/);
| 107 |
} elsif ("$ARGV[0]" eq "-r") {
| 108 |
$rfluxmtx .= " $ARGV[1]";
| 109 |
shift @ARGV;
| 110 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
| 111 |
$geout = ("$ARGV[0]" =~ /^\+/);
| 112 |
$gunit = $ARGV[1];
| 113 |
if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
| 114 |
die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
| 115 |
| 116 |
shift @ARGV;
| 117 |
} elsif ("$ARGV[0]" =~ /^[-+]C/) {
| 118 |
$docolor = ("$ARGV[0]" =~ /^\+/);
| 119 |
} elsif ("$ARGV[0]" =~ /^[-+]a/) {
| 120 |
$dorecip = ("$ARGV[0]" =~ /^\+/);
| 121 |
} elsif ("$ARGV[0]" =~ /^[-+]f/) {
| 122 |
$doforw = ("$ARGV[0]" =~ /^\+/);
| 123 |
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
| 124 |
$doback = ("$ARGV[0]" =~ /^\+/);
| 125 |
} elsif ("$ARGV[0]" eq "-t") {
| 126 |
# Use value < 0 for rttree_reduce bypass
| 127 |
$pctcull = $ARGV[1];
| 128 |
if ($pctcull >= 100) {
| 129 |
die "Illegal -t culling percentage, must be < 100\n";
| 130 |
| 131 |
shift @ARGV;
| 132 |
} elsif ("$ARGV[0]" =~ /^-t[34]$/) {
| 133 |
$tensortree = substr($ARGV[0], 2, 1);
| 134 |
$ttlog2 = $ARGV[1];
| 135 |
shift @ARGV;
| 136 |
} elsif ("$ARGV[0]" eq "-s") {
| 137 |
$wrapper .= " -f \"$ARGV[1]\"";
| 138 |
shift @ARGV;
| 139 |
} elsif ("$ARGV[0]" eq "-W") {
| 140 |
$wrapper .= " -W";
| 141 |
} elsif ("$ARGV[0]" eq "-c") {
| 142 |
$nsamp = $ARGV[1];
| 143 |
shift @ARGV;
| 144 |
} elsif ("$ARGV[0]" eq "-n") {
| 145 |
$nproc = $ARGV[1];
| 146 |
shift @ARGV;
| 147 |
} elsif ("$ARGV[0]" =~ /^-d/) {
| 148 |
userror() if ($#ARGV < 6);
| 149 |
@dim = @ARGV[1..6];
| 150 |
shift @ARGV for (1..6);
| 151 |
} elsif ("$ARGV[0]" =~ /^[-+]./) {
| 152 |
userror();
| 153 |
} else {
| 154 |
last;
| 155 |
| 156 |
shift @ARGV;
| 157 |
| 158 |
# Check that we're actually being asked to do something
| 159 |
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
| 160 |
$wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
| 161 |
$wrapper .= " -u $gunit";
| 162 |
if ( !defined $recovery ) {
| 163 |
# Issue warning for unhandled reciprocity case
| 164 |
print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
| 165 |
($tensortree==3 && !($doforw && $doback));
| 166 |
# Get scene description
| 167 |
if ( $mgfin ) {
| 168 |
system "mgf2rad @ARGV > $radscn";
| 169 |
die "Could not load MGF input\n" if ( $? );
| 170 |
} else {
| 171 |
system "xform -e @ARGV > $radscn";
| 172 |
die "Could not load Radiance input\n" if ( $? );
| 173 |
| 174 |
| 175 |
if ( $#dim != 5 ) {
| 176 |
@dim = split ' ', `getbbox -h -w $radscn`;
| 177 |
| 178 |
die "Device entirely inside room!\n" if ( $dim[4] >= 0 );
| 179 |
if ( $dim[5] > 1e-5 ) {
| 180 |
print STDERR "Warning: Device extends into room\n";
| 181 |
} elsif ( $dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2]) ) {
| 182 |
print STDERR "Warning: Device far behind Z==0 plane\n";
| 183 |
| 184 |
# Assume Zmax==0 to derive thickness so pkgBSDF will work
| 185 |
$wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
| 186 |
';h=' . ($dim[3] - $dim[2]) . '"';
| 187 |
$wrapper .= " -g $mgfscn" if ( $geout );
| 188 |
# Calculate CIE (u',v') from Radiance RGB:
| 189 |
my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
| 190 |
'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
| 191 |
'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
| 192 |
'den=Xi+15*Yi+3*Zi;' .
| 193 |
'uprime=if(Yi,4*Xi/den,4/19);' .
| 194 |
'vprime=if(Yi,9*Yi/den,9/19);' ;
| 195 |
my $FEPS = 1e-5;
| 196 |
my $ns = 2**$ttlog2;
| 197 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
| 198 |
my $ny = int($nsamp/$nx + 1);
| 199 |
$nsamp = $nx * $ny;
| 200 |
$rfluxmtx .= " -n $nproc -c $nsamp";
| 201 |
| 202 |
open(MYAVH, "> $td/savedARGV.txt");
| 203 |
foreach (@savedARGV) {
| 204 |
print MYAVH "$_\n";
| 205 |
| 206 |
close MYAVH;
| 207 |
# Generate octree
| 208 |
system "oconv -w -f $radscn > $octree";
| 209 |
die "Could not compile scene\n" if ( $? );
| 210 |
# Add MGF description if requested
| 211 |
if ( $geout ) {
| 212 |
open(MGFSCN, "> $mgfscn");
| 213 |
printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
| 214 |
close MGFSCN;
| 215 |
if ( $mgfin ) {
| 216 |
system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
| 217 |
} else {
| 218 |
system "rad2mgf $radscn >> $mgfscn";
| 219 |
| 220 |
open(MGFSCN, ">> $mgfscn");
| 221 |
print MGFSCN "xf\n";
| 222 |
close MGFSCN;
| 223 |
| 224 |
# Create receiver & sender surfaces (rectangular)
| 225 |
open(RADSCN, "> $receivers");
| 226 |
print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
| 227 |
print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
| 228 |
print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
| 229 |
print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
| 230 |
print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
| 231 |
print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
| 232 |
print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
| 233 |
print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
| 234 |
close RADSCN;
| 235 |
# Prepare sender surfaces
| 236 |
if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
| 237 |
open (RADSCN, "> $fsender");
| 238 |
print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
| 239 |
print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
| 240 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
| 241 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
| 242 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
| 243 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
| 244 |
close RADSCN;
| 245 |
open (RADSCN, "> $bsender");
| 246 |
print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
| 247 |
print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
| 248 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
| 249 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
| 250 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
| 251 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
| 252 |
close RADSCN;
| 253 |
| 254 |
print STDERR "Recover using: $0 -recover $td\n";
| 255 |
| 256 |
$curphase = 0;
| 257 |
# Create data segments (all the work happens here)
| 258 |
if ( $tensortree ) {
| 259 |
do_tree_bsdf();
| 260 |
} else {
| 261 |
do_matrix_bsdf();
| 262 |
| 263 |
# Output XML
| 264 |
# print STDERR "Running: $wrapper\n";
| 265 |
system "$wrapper -C \"Created by: genBSDF @savedARGV\"";
| 266 |
die "Could not wrap BSDF data\n" if ( $? );
| 267 |
# Clean up temporary files and exit
| 268 |
exec $rmtmp;
| 269 |
| 270 |
#============== End of main program segment ==============#
| 271 |
| 272 |
# Function to determine if next phase should be skipped or recovered
| 273 |
sub do_phase {
| 274 |
$curphase++;
| 275 |
if ( defined $recovery ) {
| 276 |
if ( $recovery > $curphase ) { return 0; }
| 277 |
if ( $recovery == $curphase ) { return -1; }
| 278 |
| 279 |
open(MYPH, ">> $td/phase.txt");
| 280 |
print MYPH "$curphase\n";
| 281 |
close MYPH;
| 282 |
return 1;
| 283 |
| 284 |
| 285 |
# Check if we are in active phase (not skipping parts)
| 286 |
sub active_phase {
| 287 |
| 288 |
| 289 |
| 290 |
| 291 |
return 1;
| 292 |
| 293 |
| 294 |
# Function to run program and check output if in active phase
| 295 |
sub run_check {
| 296 |
if ( !active_phase() ) { return; }
| 297 |
my $cmd = shift;
| 298 |
# print STDERR "Running: $cmd\n";
| 299 |
system $cmd;
| 300 |
die "Failure running: $cmd\n" if ( $? );
| 301 |
| 302 |
| 303 |
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
| 304 |
sub do_tree_bsdf {
| 305 |
| 306 |
# Run rfluxmtx processes to compute each side
| 307 |
do_ttree_dir(0) if ( $doback );
| 308 |
do_ttree_dir(1) if ( $doforw );
| 309 |
| 310 |
} # end of sub do_tree_bsdf()
| 311 |
| 312 |
# Call rfluxmtx and process tensor tree BSDF for the given direction
| 313 |
sub do_ttree_dir {
| 314 |
my $forw = shift;
| 315 |
my $dop = do_phase();
| 316 |
my $r = ($dop < 0) ? " -r" : "";
| 317 |
my $cmd;
| 318 |
if ( $tensortree == 3 ) {
| 319 |
# Isotropic BSDF
| 320 |
my $ns2 = $ns / 2;
| 321 |
if ($windoz) {
| 322 |
$cmd = "cnt $ns2 $ny $nx " .
| 323 |
qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
| 324 |
qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
| 325 |
qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
| 326 |
qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
| 327 |
qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
| 328 |
qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
| 329 |
qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
| 330 |
qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
| 331 |
qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
| 332 |
"| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree";
| 333 |
} else {
| 334 |
| 335 |
qq{| rcalc -e 'r1=rand(.8681*recno-.673892)' } .
| 336 |
qq{-e 'r2=rand(-5.37138*recno+67.1737811)' } .
| 337 |
qq{-e 'r3=rand(+3.17603772*recno+83.766771)' } .
| 338 |
qq{-e 'Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' } .
| 339 |
qq{-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' } .
| 340 |
qq{-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' } .
| 341 |
qq{-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' } .
| 342 |
qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
| 343 |
qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
| 344 |
"| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree";
| 345 |
| 346 |
} else {
| 347 |
# Anisotropic BSDF
| 348 |
my $sender = ($bsender,$fsender)[$forw];
| 349 |
if ($windoz) {
| 350 |
$cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree";
| 351 |
} else {
| 352 |
$cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree";
| 353 |
| 354 |
| 355 |
if ( $dop ) {
| 356 |
| 357 |
system $cmd;
| 358 |
die "Failure running rfluxmtx" if ( $? );
| 359 |
| 360 |
ttree_out($forw);
| 361 |
} # end of do_ttree_dir()
| 362 |
| 363 |
# Simplify and store tensor tree results
| 364 |
sub ttree_out {
| 365 |
my $forw = shift;
| 366 |
my ($refldat,$transdat);
| 367 |
if ( $forw ) {
| 368 |
$transdat = $facedat;
| 369 |
$refldat = $behinddat;
| 370 |
} else {
| 371 |
$transdat = $behinddat;
| 372 |
$refldat = $facedat;
| 373 |
| 374 |
# Only output one transmitted anisotropic distribution, preferring backwards
| 375 |
if ( !$forw || !$doback || $tensortree==3 ) {
| 376 |
my $ttyp = ("tb","tf")[$forw];
| 377 |
ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
| 378 |
if ( $docolor ) {
| 379 |
ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
| 380 |
ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
| 381 |
| 382 |
| 383 |
# Output reflection
| 384 |
my $rtyp = ("rb","rf")[$forw];
| 385 |
ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
| 386 |
if ( $docolor ) {
| 387 |
ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
| 388 |
ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
| 389 |
| 390 |
} # end of ttree_out()
| 391 |
| 392 |
# Call rttree_reduce on the given component
| 393 |
sub ttree_comp {
| 394 |
my $typ = shift;
| 395 |
my $spec = shift;
| 396 |
my $src = shift;
| 397 |
my $dest = shift;
| 398 |
my $cmd;
| 399 |
if ($windoz) {
| 400 |
if ("$spec" eq "Visible") {
| 401 |
$cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
| 402 |
q{-e "Ri=$1;Gi=$2;Bi=$3" } .
| 403 |
qq{-e "$CIEuv" } .
| 404 |
q{-e "$1=Yi/Omega"};
| 405 |
} elsif ("$spec" eq "CIE-u") {
| 406 |
$cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
| 407 |
qq{-e "$CIEuv" } .
| 408 |
q{-e "$1=uprime"};
| 409 |
} elsif ("$spec" eq "CIE-v") {
| 410 |
| 411 |
qq{-e "$CIEuv" } .
| 412 |
q{-e "$1=vprime"};
| 413 |
| 414 |
} else {
| 415 |
| 416 |
$cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
| 417 |
q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
| 418 |
"-e '$CIEuv' " .
| 419 |
q{-e '$1=Yi/Omega'};
| 420 |
| 421 |
$cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
| 422 |
"-e '$CIEuv' " .
| 423 |
q{-e '$1=uprime'};
| 424 |
| 425 |
| 426 |
"-e '$CIEuv' " .
| 427 |
q{-e '$1=vprime'};
| 428 |
| 429 |
| 430 |
if ($pctcull >= 0) {
| 431 |
my $avg = ( $dorecip && "$typ" =~ /^r[fb]/ ) ? " -a" : "";
| 432 |
my $pcull = ("$spec" eq "Visible") ? $pctcull :
| 433 |
(100 - (100-$pctcull)*.25) ;
| 434 |
if ($windoz) {
| 435 |
$cmd = "rcollate -ho -oc 1 $src | " .
| 436 |
$cmd .
| 437 |
" | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
| 438 |
} else {
| 439 |
$cmd .= " -of $src " .
| 440 |
"| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
| 441 |
| 442 |
run_check "$cmd > $dest";
| 443 |
} else {
| 444 |
if ($windoz) {
| 445 |
$cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
| 446 |
} else {
| 447 |
$cmd .= " $src";
| 448 |
| 449 |
if ( active_phase() ) {
| 450 |
open(DATOUT, "> $dest");
| 451 |
print DATOUT "{\n";
| 452 |
close DATOUT;
| 453 |
| 454 |
system "$cmd >> $dest";
| 455 |
die "Failure running rcalc" if ( $? );
| 456 |
open(DATOUT, ">> $dest");
| 457 |
for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
| 458 |
print DATOUT "0\n";
| 459 |
| 460 |
print DATOUT "}\n";
| 461 |
close DATOUT;
| 462 |
| 463 |
| 464 |
if ( "$spec" ne "$curspec" ) {
| 465 |
$wrapper .= " -s $spec";
| 466 |
$curspec = $spec;
| 467 |
| 468 |
$wrapper .= " -$typ $dest";
| 469 |
} # end of ttree_comp()
| 470 |
| 471 |
#------------- End of do_tree_bsdf() & subroutines -------------#
| 472 |
| 473 |
#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
| 474 |
sub do_matrix_bsdf {
| 475 |
| 476 |
| 477 |
do_matrix_dir(0) if ( $doback );
| 478 |
do_matrix_dir(1) if ( $doforw );
| 479 |
| 480 |
} # end of sub do_matrix_bsdf()
| 481 |
| 482 |
| 483 |
sub do_matrix_dir {
| 484 |
my $forw = shift;
| 485 |
| 486 |
| 487 |
| 488 |
my $cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree";
| 489 |
if ( $dop ) {
| 490 |
| 491 |
system $cmd;
| 492 |
| 493 |
| 494 |
matrix_out($forw);
| 495 |
} # end of do_matrix_dir()
| 496 |
| 497 |
sub matrix_out {
| 498 |
my $forw = shift;
| 499 |
| 500 |
if ( $forw ) {
| 501 |
| 502 |
| 503 |
} else {
| 504 |
| 505 |
| 506 |
| 507 |
# Output transmission
| 508 |
| 509 |
matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
| 510 |
if ( $docolor ) {
| 511 |
matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
| 512 |
matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
| 513 |
| 514 |
# Output reflection
| 515 |
| 516 |
matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
| 517 |
if ( $docolor ) {
| 518 |
matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
| 519 |
matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
| 520 |
| 521 |
} # end of matrix_out()
| 522 |
| 523 |
# Transpose matrix component data and save to file
| 524 |
sub matrix_comp {
| 525 |
my $typ = shift;
| 526 |
my $spec = shift;
| 527 |
my $src = shift;
| 528 |
my $dest = shift;
| 529 |
my $cmd = "rmtxop -fa -t";
| 530 |
| 531 |
$cmd .= " -c 0.2651 0.6701 0.0648";
| 532 |
} elsif ("$spec" eq "CIE-X") {
| 533 |
$cmd .= " -c 0.5141 0.3239 0.1620";
| 534 |
} elsif ("$spec" eq "CIE-Z") {
| 535 |
$cmd .= " -c 0.0241 0.1229 0.8530";
| 536 |
| 537 |
$cmd .= " $src | getinfo -";
| 538 |
| 539 |
| 540 |
| 541 |
$curspec = $spec;
| 542 |
| 543 |
| 544 |
} # end of matrix_comp()
| 545 |
| 546 |
#------------- End of do_matrix_bsdf() & subroutines --------------#
