| 1 |
#!/usr/bin/perl -w
| 2 |
# RCSid $Id: genBSDF.pl,v 2.65 2016/08/18 15:09:29 greg Exp $
| 3 |
| 4 |
# Compute BSDF based on geometry and material description
| 5 |
| 6 |
# G. Ward
| 7 |
| 8 |
use strict;
| 9 |
my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
| 10 |
use File::Temp qw/ :mktemp /;
| 11 |
sub userror {
| 12 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-s \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
| 13 |
exit 1;
| 14 |
| 15 |
my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
| 16 |
my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz,$cph,$sav);
| 17 |
my ($curphase, $recovery);
| 18 |
if ($#ARGV == 1 && "$ARGV[0]" =~ /^-rec/) {
| 19 |
$td = $ARGV[1];
| 20 |
open(MYAVH, "< $td/savedARGV.txt") or die "$td: invalid path\n";
| 21 |
@ARGV = <MYAVH>;
| 22 |
close MYAVH;
| 23 |
chomp @ARGV;
| 24 |
if (open(MYPH, "< $td/phase.txt")) {
| 25 |
while (<MYPH>) {
| 26 |
chomp($recovery = $_);
| 27 |
| 28 |
close MYPH;
| 29 |
| 30 |
} elsif ($windoz) {
| 31 |
my $tmploc = `echo \%TMP\%`;
| 32 |
chomp $tmploc;
| 33 |
$td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
| 34 |
} else {
| 35 |
$td = mkdtemp("/tmp/genBSDF.XXXXXX");
| 36 |
chomp $td;
| 37 |
| 38 |
if ($windoz) {
| 39 |
$radscn = "$td\\device.rad";
| 40 |
$mgfscn = "$td\\device.mgf";
| 41 |
$octree = "$td\\device.oct";
| 42 |
$fsender = "$td\\fsender.rad";
| 43 |
$bsender = "$td\\bsender.rad";
| 44 |
$receivers = "$td\\receivers.rad";
| 45 |
$facedat = "$td\\face.dat";
| 46 |
$behinddat = "$td\\behind.dat";
| 47 |
$tf = "$td\\tf.dat";
| 48 |
$rf = "$td\\rf.dat";
| 49 |
$tb = "$td\\tb.dat";
| 50 |
$rb = "$td\\rb.dat";
| 51 |
$tfx = "$td\\tfx.dat";
| 52 |
$rfx = "$td\\rfx.dat";
| 53 |
$tbx = "$td\\tbx.dat";
| 54 |
$rbx = "$td\\rbx.dat";
| 55 |
$tfz = "$td\\tfz.dat";
| 56 |
$rfz = "$td\\rfz.dat";
| 57 |
$tbz = "$td\\tbz.dat";
| 58 |
$rbz = "$td\\rbz.dat";
| 59 |
$cph = "$td\\phase.txt";
| 60 |
$rmtmp = "rd /S /Q $td";
| 61 |
} else {
| 62 |
$radscn = "$td/device.rad";
| 63 |
$mgfscn = "$td/device.mgf";
| 64 |
$octree = "$td/device.oct";
| 65 |
$fsender = "$td/fsender.rad";
| 66 |
$bsender = "$td/bsender.rad";
| 67 |
$receivers = "$td/receivers.rad";
| 68 |
$facedat = "$td/face.dat";
| 69 |
$behinddat = "$td/behind.dat";
| 70 |
$tf = "$td/tf.dat";
| 71 |
$rf = "$td/rf.dat";
| 72 |
$tb = "$td/tb.dat";
| 73 |
$rb = "$td/rb.dat";
| 74 |
$tfx = "$td/tfx.dat";
| 75 |
$rfx = "$td/rfx.dat";
| 76 |
$tbx = "$td/tbx.dat";
| 77 |
$rbx = "$td/rbx.dat";
| 78 |
$tfz = "$td/tfz.dat";
| 79 |
$rfz = "$td/rfz.dat";
| 80 |
$tbz = "$td/tbz.dat";
| 81 |
$rbz = "$td/rbz.dat";
| 82 |
$cph = "$td/phase.txt";
| 83 |
$rmtmp = "rm -rf $td";
| 84 |
| 85 |
my @savedARGV = @ARGV;
| 86 |
my $rfluxmtx = "rfluxmtx -ab 5 -ad 700 -lw 3e-6";
| 87 |
my $wrapper = "wrapBSDF";
| 88 |
my $tensortree = 0;
| 89 |
my $ttlog2 = 4;
| 90 |
my $nsamp = 2000;
| 91 |
my $mgfin = 0;
| 92 |
my $geout = 1;
| 93 |
my $nproc = 1;
| 94 |
my $docolor = 0;
| 95 |
my $doforw = 0;
| 96 |
my $doback = 1;
| 97 |
my $pctcull = 90;
| 98 |
my $gunit = "meter";
| 99 |
my $curspec = "Visible";
| 100 |
my @dim;
| 101 |
# Get options
| 102 |
while ($#ARGV >= 0) {
| 103 |
if ("$ARGV[0]" =~ /^[-+]m/) {
| 104 |
$mgfin = ("$ARGV[0]" =~ /^\+/);
| 105 |
} elsif ("$ARGV[0]" eq "-r") {
| 106 |
$rfluxmtx .= " $ARGV[1]";
| 107 |
shift @ARGV;
| 108 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
| 109 |
$geout = ("$ARGV[0]" =~ /^\+/);
| 110 |
$gunit = $ARGV[1];
| 111 |
if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
| 112 |
die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
| 113 |
| 114 |
shift @ARGV;
| 115 |
} elsif ("$ARGV[0]" =~ /^[-+]C/) {
| 116 |
$docolor = ("$ARGV[0]" =~ /^\+/);
| 117 |
} elsif ("$ARGV[0]" =~ /^[-+]f/) {
| 118 |
$doforw = ("$ARGV[0]" =~ /^\+/);
| 119 |
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
| 120 |
$doback = ("$ARGV[0]" =~ /^\+/);
| 121 |
} elsif ("$ARGV[0]" eq "-t") {
| 122 |
# Use value < 0 for rttree_reduce bypass
| 123 |
$pctcull = $ARGV[1];
| 124 |
if ($pctcull >= 100) {
| 125 |
die "Illegal -t culling percentage, must be < 100\n";
| 126 |
| 127 |
shift @ARGV;
| 128 |
} elsif ("$ARGV[0]" =~ /^-t[34]$/) {
| 129 |
$tensortree = substr($ARGV[0], 2, 1);
| 130 |
$ttlog2 = $ARGV[1];
| 131 |
shift @ARGV;
| 132 |
} elsif ("$ARGV[0]" eq "-s") {
| 133 |
$wrapper .= " -f \"$ARGV[1]\"";
| 134 |
shift @ARGV;
| 135 |
} elsif ("$ARGV[0]" eq "-W") {
| 136 |
$wrapper .= " -W";
| 137 |
} elsif ("$ARGV[0]" eq "-c") {
| 138 |
$nsamp = $ARGV[1];
| 139 |
shift @ARGV;
| 140 |
} elsif ("$ARGV[0]" eq "-n") {
| 141 |
$nproc = $ARGV[1];
| 142 |
shift @ARGV;
| 143 |
} elsif ("$ARGV[0]" =~ /^-d/) {
| 144 |
userror() if ($#ARGV < 6);
| 145 |
@dim = @ARGV[1..6];
| 146 |
shift @ARGV for (1..6);
| 147 |
} elsif ("$ARGV[0]" =~ /^[-+]./) {
| 148 |
userror();
| 149 |
} else {
| 150 |
last;
| 151 |
| 152 |
shift @ARGV;
| 153 |
| 154 |
# Check that we're actually being asked to do something
| 155 |
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
| 156 |
$wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
| 157 |
$wrapper .= " -u $gunit";
| 158 |
if (!defined $recovery) {
| 159 |
# Issue warning for unhandled reciprocity case
| 160 |
print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
| 161 |
($tensortree==3 && !($doforw && $doback));
| 162 |
# Get scene description and dimensions
| 163 |
if ( $mgfin ) {
| 164 |
system "mgf2rad @ARGV > $radscn";
| 165 |
die "Could not load MGF input\n" if ( $? );
| 166 |
} else {
| 167 |
system "xform -e @ARGV > $radscn";
| 168 |
die "Could not load Radiance input\n" if ( $? );
| 169 |
| 170 |
| 171 |
if ($#dim != 5) {
| 172 |
@dim = split ' ', `getbbox -h $radscn`;
| 173 |
| 174 |
die "Device entirely inside room!\n" if ($dim[4] >= 0);
| 175 |
if ($dim[5] > 1e-5) {
| 176 |
print STDERR "Warning: Device extends into room\n";
| 177 |
} elsif ($dim[5]*$dim[5] > .01*($dim[1]-$dim[0])*($dim[3]-$dim[2])) {
| 178 |
print STDERR "Warning: Device far behind Z==0 plane\n";
| 179 |
| 180 |
# Assume Zmax==0 to derive thickness so pkgBSDF will work
| 181 |
$wrapper .= ' -f "t=' . (-$dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
| 182 |
';h=' . ($dim[3] - $dim[2]) . '"';
| 183 |
# Calculate CIE (u',v') from Radiance RGB:
| 184 |
my $CIEuv = 'Xi=.5141*Ri+.3239*Gi+.1620*Bi;' .
| 185 |
'Yi=.2651*Ri+.6701*Gi+.0648*Bi;' .
| 186 |
'Zi=.0241*Ri+.1229*Gi+.8530*Bi;' .
| 187 |
'den=Xi+15*Yi+3*Zi;' .
| 188 |
'uprime=4*Xi/den;vprime=9*Yi/den;' ;
| 189 |
my $FEPS = 1e-5;
| 190 |
my $ns = 2**$ttlog2;
| 191 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
| 192 |
my $ny = int($nsamp/$nx + 1);
| 193 |
$nsamp = $nx * $ny;
| 194 |
$rfluxmtx .= " -n $nproc -c $nsamp";
| 195 |
| 196 |
open(MYAVH, "> $td/savedARGV.txt");
| 197 |
foreach (@savedARGV) {
| 198 |
print MYAVH "$_\n";
| 199 |
| 200 |
close MYAVH;
| 201 |
# Generate octree
| 202 |
system "oconv -w $radscn > $octree";
| 203 |
die "Could not compile scene\n" if ( $? );
| 204 |
# Add MGF description if requested
| 205 |
if ( $geout ) {
| 206 |
open(MGFSCN, "> $mgfscn");
| 207 |
printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
| 208 |
close MGFSCN;
| 209 |
if ( $mgfin ) {
| 210 |
system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
| 211 |
} else {
| 212 |
system "rad2mgf $radscn >> $mgfscn";
| 213 |
| 214 |
open(MGFSCN, ">> $mgfscn");
| 215 |
print MGFSCN "xf\n";
| 216 |
close MGFSCN;
| 217 |
$wrapper .= " -g $mgfscn";
| 218 |
| 219 |
# Create receiver & sender surfaces (rectangular)
| 220 |
open(RADSCN, "> $receivers");
| 221 |
print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=-sc$ns\n" : "h=-kf\n");
| 222 |
print RADSCN '#@rfluxmtx ' . "u=-Y o=$facedat\n\n";
| 223 |
print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
| 224 |
print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
| 225 |
print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=+sc$ns\n" : "h=+kf\n");
| 226 |
print RADSCN '#@rfluxmtx ' . "u=-Y o=$behinddat\n\n";
| 227 |
print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
| 228 |
print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
| 229 |
close RADSCN;
| 230 |
# Prepare sender surfaces
| 231 |
if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
| 232 |
open (RADSCN, "> $fsender");
| 233 |
print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=-sc$ns\n\n" : "h=-kf\n\n");
| 234 |
print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
| 235 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[4]-$FEPS;
| 236 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[4]-$FEPS;
| 237 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[4]-$FEPS;
| 238 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[4]-$FEPS;
| 239 |
close RADSCN;
| 240 |
open (RADSCN, "> $bsender");
| 241 |
print RADSCN '#@rfluxmtx u=-Y ' . ($tensortree ? "h=+sc$ns\n\n" : "h=+kf\n\n");
| 242 |
print RADSCN "void polygon bwd_sender\n0\n0\n12\n";
| 243 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[2], $dim[5]+$FEPS;
| 244 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[2], $dim[5]+$FEPS;
| 245 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[1], $dim[3], $dim[5]+$FEPS;
| 246 |
printf RADSCN "\t%e\t%e\t%e\n", $dim[0], $dim[3], $dim[5]+$FEPS;
| 247 |
close RADSCN;
| 248 |
| 249 |
print STDERR "Recover using: $0 -recover $td\n";
| 250 |
| 251 |
open(MYPH, ">> $td/phase.txt");
| 252 |
{ # unbuffer output to MYPH
| 253 |
my $ofh = select MYPH;
| 254 |
$| = 1;
| 255 |
select $ofh;
| 256 |
| 257 |
$curphase = 0;
| 258 |
# Function to determine if next phase should be skipped or recovered
| 259 |
sub do_phase {
| 260 |
$curphase++;
| 261 |
if (defined $recovery) {
| 262 |
if ($recovery == $curphase) { return -1; }
| 263 |
if ($recovery > $curphase) { return 0; }
| 264 |
| 265 |
print MYPH "$curphase\n";
| 266 |
return 1;
| 267 |
| 268 |
# Create data segments (all the work happens here)
| 269 |
if ( $tensortree ) {
| 270 |
do_tree_bsdf();
| 271 |
} else {
| 272 |
do_matrix_bsdf();
| 273 |
| 274 |
# Output XML
| 275 |
print STDERR "Running: $wrapper\n";
| 276 |
system "$wrapper -C \"Created by: genBSDF @savedARGV\"";
| 277 |
die "Could not wrap BSDF data\n" if ( $? );
| 278 |
# Clean up temporary files and exit
| 279 |
exec $rmtmp;
| 280 |
| 281 |
#-------------- End of main program segment --------------#
| 282 |
| 283 |
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
| 284 |
sub do_tree_bsdf {
| 285 |
| 286 |
# Run rfluxmtx processes to compute each side
| 287 |
do_ttree_dir(0) if ( $doback );
| 288 |
do_ttree_dir(1) if ( $doforw );
| 289 |
| 290 |
} # end of sub do_tree_bsdf()
| 291 |
| 292 |
# Call rfluxmtx and process tensor tree BSDF for the given direction
| 293 |
sub do_ttree_dir {
| 294 |
my $forw = shift;
| 295 |
my $r = do_phase();
| 296 |
if (!$r) { return; }
| 297 |
$r = ($r < 0) ? " -r" : "";
| 298 |
my $cmd;
| 299 |
if ( $tensortree == 3 ) {
| 300 |
# Isotropic BSDF
| 301 |
my $ns2 = $ns / 2;
| 302 |
if ($windoz) {
| 303 |
$cmd = "cnt $ns2 $ny $nx " .
| 304 |
qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
| 305 |
qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
| 306 |
qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
| 307 |
qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
| 308 |
qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
| 309 |
qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
| 310 |
qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
| 311 |
qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
| 312 |
qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
| 313 |
"| $rfluxmtx$r -fa -y $ns2 - $receivers -i $octree";
| 314 |
} else {
| 315 |
| 316 |
| 317 |
| 318 |
| 319 |
| 320 |
| 321 |
| 322 |
| 323 |
qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
| 324 |
qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
| 325 |
"| $rfluxmtx$r -h -ff -y $ns2 - $receivers -i $octree";
| 326 |
| 327 |
} else {
| 328 |
# Anisotropic BSDF
| 329 |
my $sender = ($bsender,$fsender)[$forw];
| 330 |
if ($windoz) {
| 331 |
$cmd = "$rfluxmtx$r -fa $sender $receivers -i $octree";
| 332 |
} else {
| 333 |
$cmd = "$rfluxmtx$r -h -ff $sender $receivers -i $octree";
| 334 |
| 335 |
| 336 |
print STDERR "Starting: $cmd\n";
| 337 |
system $cmd;
| 338 |
die "Failure running rfluxmtx" if ( $? );
| 339 |
ttree_out($forw);
| 340 |
} # end of do_ttree_dir()
| 341 |
| 342 |
# Simplify and store tensor tree results
| 343 |
sub ttree_out {
| 344 |
my $forw = shift;
| 345 |
my ($refldat,$transdat);
| 346 |
if ( $forw ) {
| 347 |
$transdat = $facedat;
| 348 |
$refldat = $behinddat;
| 349 |
} else {
| 350 |
$transdat = $behinddat;
| 351 |
$refldat = $facedat;
| 352 |
| 353 |
# Only output one transmitted anisotropic distribution, preferring backwards
| 354 |
if ( !$forw || !$doback || $tensortree==3 ) {
| 355 |
my $ttyp = ("tb","tf")[$forw];
| 356 |
ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
| 357 |
if ( $docolor ) {
| 358 |
ttree_comp($ttyp, "CIE-u", $transdat, ($tbx,$tfx)[$forw]);
| 359 |
ttree_comp($ttyp, "CIE-v", $transdat, ($tbz,$tfz)[$forw]);
| 360 |
| 361 |
| 362 |
# Output reflection
| 363 |
my $rtyp = ("rb","rf")[$forw];
| 364 |
ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
| 365 |
if ( $docolor ) {
| 366 |
ttree_comp($rtyp, "CIE-u", $refldat, ($rbx,$rfx)[$forw]);
| 367 |
ttree_comp($rtyp, "CIE-v", $refldat, ($rbz,$rfz)[$forw]);
| 368 |
| 369 |
} # end of ttree_out()
| 370 |
| 371 |
# Call rttree_reduce on the given component
| 372 |
sub ttree_comp {
| 373 |
my $typ = shift;
| 374 |
my $spec = shift;
| 375 |
my $src = shift;
| 376 |
my $dest = shift;
| 377 |
my $cmd;
| 378 |
if ($windoz) {
| 379 |
if ("$spec" eq "Visible") {
| 380 |
$cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
| 381 |
q{-e "Ri=$1;Gi=$2;Bi=$3" } .
| 382 |
qq{-e "$CIEuv" } .
| 383 |
q{-e "$1=Yi/Omega"};
| 384 |
} elsif ("$spec" eq "CIE-u") {
| 385 |
$cmd = q{rcalc -e "Ri=$1;Gi=$2;Bi=$3" } .
| 386 |
qq{-e "$CIEuv" } .
| 387 |
q{-e "$1=uprime"};
| 388 |
} elsif ("$spec" eq "CIE-v") {
| 389 |
| 390 |
qq{-e "$CIEuv" } .
| 391 |
q{-e "$1=vprime"};
| 392 |
| 393 |
} else {
| 394 |
| 395 |
$cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
| 396 |
q{-e 'Ri=$1;Gi=$2;Bi=$3' } .
| 397 |
"-e '$CIEuv' " .
| 398 |
q{-e '$1=Yi/Omega'};
| 399 |
| 400 |
$cmd = q{rcalc -if3 -e 'Ri=$1;Gi=$2;Bi=$3' } .
| 401 |
"-e '$CIEuv' " .
| 402 |
q{-e '$1=uprime'};
| 403 |
| 404 |
| 405 |
"-e '$CIEuv' " .
| 406 |
q{-e '$1=vprime'};
| 407 |
| 408 |
| 409 |
if ($pctcull >= 0) {
| 410 |
my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : "";
| 411 |
my $pcull = ("$spec" eq "Visible") ? $pctcull :
| 412 |
(100 - (100-$pctcull)*.25) ;
| 413 |
if ($windoz) {
| 414 |
$cmd = "rcollate -ho -oc 1 $src | " .
| 415 |
$cmd .
| 416 |
" | rttree_reduce$avg -h -fa -t $pcull -r $tensortree -g $ttlog2";
| 417 |
} else {
| 418 |
$cmd .= " -of $src " .
| 419 |
"| rttree_reduce$avg -h -ff -t $pcull -r $tensortree -g $ttlog2";
| 420 |
| 421 |
print STDERR "Running: $cmd\n";
| 422 |
system "$cmd > $dest";
| 423 |
die "Failure running rttree_reduce" if ( $? );
| 424 |
} else {
| 425 |
if ($windoz) {
| 426 |
$cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
| 427 |
} else {
| 428 |
$cmd .= " $src";
| 429 |
| 430 |
open(DATOUT, "> $dest");
| 431 |
print DATOUT "{\n";
| 432 |
close DATOUT;
| 433 |
| 434 |
system "$cmd >> $dest";
| 435 |
die "Failure running rcalc" if ( $? );
| 436 |
open(DATOUT, ">> $dest");
| 437 |
for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
| 438 |
print DATOUT "0\n";
| 439 |
| 440 |
print DATOUT "}\n";
| 441 |
close DATOUT;
| 442 |
| 443 |
if ( "$spec" ne "$curspec" ) {
| 444 |
$wrapper .= " -s $spec";
| 445 |
$curspec = $spec;
| 446 |
| 447 |
$wrapper .= " -$typ $dest";
| 448 |
} # end of ttree_comp()
| 449 |
| 450 |
#------------- End of do_tree_bsdf() & subroutines -------------#
| 451 |
| 452 |
#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
| 453 |
sub do_matrix_bsdf {
| 454 |
| 455 |
| 456 |
do_matrix_dir(0) if ( $doback );
| 457 |
do_matrix_dir(1) if ( $doforw );
| 458 |
| 459 |
} # end of sub do_matrix_bsdf()
| 460 |
| 461 |
| 462 |
sub do_matrix_dir {
| 463 |
my $forw = shift;
| 464 |
my $r = do_phase();
| 465 |
| 466 |
| 467 |
my $cmd;
| 468 |
| 469 |
$cmd = "$rfluxmtx$r -fd $sender $receivers -i $octree";
| 470 |
| 471 |
system $cmd;
| 472 |
| 473 |
matrix_out($forw);
| 474 |
} # end of do_matrix_dir()
| 475 |
| 476 |
sub matrix_out {
| 477 |
my $forw = shift;
| 478 |
| 479 |
if ( $forw ) {
| 480 |
| 481 |
| 482 |
} else {
| 483 |
| 484 |
| 485 |
| 486 |
# Output transmission
| 487 |
| 488 |
matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
| 489 |
if ( $docolor ) {
| 490 |
matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
| 491 |
matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
| 492 |
| 493 |
# Output reflection
| 494 |
| 495 |
matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
| 496 |
if ( $docolor ) {
| 497 |
matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
| 498 |
matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
| 499 |
| 500 |
} # end of matrix_out()
| 501 |
| 502 |
# Transpose matrix component data and save to file
| 503 |
sub matrix_comp {
| 504 |
my $typ = shift;
| 505 |
my $spec = shift;
| 506 |
my $src = shift;
| 507 |
my $dest = shift;
| 508 |
my $cmd = "rmtxop -fa -t";
| 509 |
| 510 |
$cmd .= " -c 0.2651 0.6701 0.0648";
| 511 |
} elsif ("$spec" eq "CIE-X") {
| 512 |
$cmd .= " -c 0.5141 0.3239 0.1620";
| 513 |
} elsif ("$spec" eq "CIE-Z") {
| 514 |
$cmd .= " -c 0.0241 0.1229 0.8530";
| 515 |
| 516 |
$cmd .= " $src | rcollate -ho -oc 145";
| 517 |
| 518 |
| 519 |
die "Failure running rmtxop" if ( $? );
| 520 |
| 521 |
| 522 |
$curspec = $spec;
| 523 |
| 524 |
| 525 |
} # end of matrix_comp()
| 526 |
| 527 |
#------------- End of do_matrix_bsdf() & subroutines --------------#
