root/radiance/ray/src/util/genBSDF.pl
Revision: 2.52
Committed: Mon Mar 16 00:40:51 2015 UTC (10 years, 5 months ago) by greg
Fixed issue with missing rcollate -oc specification
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.51 2015/03/12 13:24:41 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 my $windoz = ($^O eq "MSWin32" or $^O eq "MSWin64");
10 use File::Temp qw/ :mktemp /;
11 sub userror {
12 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-W][-t{3|4} Nlog2][-r \"ropts\"][-f \"x=string;y=string\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}C][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom units] [input ..]\n";
13 exit 1;
14 }
15 my ($td,$radscn,$mgfscn,$octree,$fsender,$bsender,$receivers,$facedat,$behinddat,$rmtmp);
16 my ($tf,$rf,$tb,$rb,$tfx,$rfx,$tbx,$rbx,$tfz,$rfz,$tbz,$rbz);
17 if ($windoz) {
18 my $tmploc = `echo \%TMP\%`;
19 chomp($tmploc);
20 $td = mkdtemp("$tmploc\\genBSDF.XXXXXX");
21 $radscn = "$td\\device.rad";
22 $mgfscn = "$td\\device.mgf";
23 $octree = "$td\\device.oct";
24 $fsender = "$td\\fsender.rad";
25 $bsender = "$td\\bsender.rad";
26 $receivers = "$td\\receivers.rad";
27 $facedat = "$td\\face.dat";
28 $behinddat = "$td\\behind.dat";
29 $tf = "$td\\tf.dat";
30 $rf = "$td\\rf.dat";
31 $tb = "$td\\tb.dat";
32 $rb = "$td\\rb.dat";
33 $tfx = "$td\\tfx.dat";
34 $rfx = "$td\\rfx.dat";
35 $tbx = "$td\\tbx.dat";
36 $rbx = "$td\\rbx.dat";
37 $tfz = "$td\\tfz.dat";
38 $rfz = "$td\\rfz.dat";
39 $tbz = "$td\\tbz.dat";
40 $rbz = "$td\\rbz.dat";
41 chomp $td;
42 $rmtmp = "rmdir /S /Q $td";
43 } else {
44 $td = mkdtemp("/tmp/genBSDF.XXXXXX");
45 chomp $td;
46 $radscn = "$td/device.rad";
47 $mgfscn = "$td/device.mgf";
48 $octree = "$td/device.oct";
49 $fsender = "$td/fsender.rad";
50 $bsender = "$td/bsender.rad";
51 $receivers = "$td/receivers.rad";
52 $facedat = "$td/face.dat";
53 $behinddat = "$td/behind.dat";
54 $tf = "$td/tf.dat";
55 $rf = "$td/rf.dat";
56 $tb = "$td/tb.dat";
57 $rb = "$td/rb.dat";
58 $tfx = "$td/tfx.dat";
59 $rfx = "$td/rfx.dat";
60 $tbx = "$td/tbx.dat";
61 $rbx = "$td/rbx.dat";
62 $tfz = "$td/tfz.dat";
63 $rfz = "$td/rfz.dat";
64 $tbz = "$td/tbz.dat";
65 $rbz = "$td/rbz.dat";
66 $rmtmp = "rm -rf $td";
67 }
68 my @savedARGV = @ARGV;
69 my $rfluxmtx = "rfluxmtx -v -ab 5 -ad 700 -lw 3e-6";
70 my $wrapper = "wrapBSDF";
71 my $tensortree = 0;
72 my $ttlog2 = 4;
73 my $nsamp = 2000;
74 my $mgfin = 0;
75 my $geout = 1;
76 my $nproc = 1;
77 my $docolor = 0;
78 my $doforw = 0;
79 my $doback = 1;
80 my $pctcull = 90;
81 my $gunit = "meter";
82 my $curspec = "Visible";
83 my @dim;
84 # Get options
85 while ($#ARGV >= 0) {
86 if ("$ARGV[0]" =~ /^[-+]m/) {
87 $mgfin = ("$ARGV[0]" =~ /^\+/);
88 } elsif ("$ARGV[0]" eq "-r") {
89 $rfluxmtx .= " $ARGV[1]";
90 shift @ARGV;
91 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
92 $geout = ("$ARGV[0]" =~ /^\+/);
93 $gunit = $ARGV[1];
94 if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
95 die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
96 }
97 shift @ARGV;
98 } elsif ("$ARGV[0]" =~ /^[-+]C/) {
99 $docolor = ("$ARGV[0]" =~ /^\+/);
100 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
101 $doforw = ("$ARGV[0]" =~ /^\+/);
102 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
103 $doback = ("$ARGV[0]" =~ /^\+/);
104 } elsif ("$ARGV[0]" eq "-t") {
105 # Use value < 0 for rttree_reduce bypass
106 $pctcull = $ARGV[1];
107 shift @ARGV;
108 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
109 $tensortree = substr($ARGV[0], 2, 1);
110 $ttlog2 = $ARGV[1];
111 shift @ARGV;
112 } elsif ("$ARGV[0]" eq "-f") {
113 $wrapper .= " -f \"$ARGV[1]\"";
114 shift @ARGV;
115 } elsif ("$ARGV[0]" eq "-W") {
116 $wrapper .= " -W";
117 } elsif ("$ARGV[0]" eq "-c") {
118 $nsamp = $ARGV[1];
119 shift @ARGV;
120 } elsif ("$ARGV[0]" eq "-n") {
121 $nproc = $ARGV[1];
122 shift @ARGV;
123 } elsif ("$ARGV[0]" =~ /^-d/) {
124 userror() if ($#ARGV < 6);
125 @dim = @ARGV[1..6];
126 shift @ARGV for (1..6);
127 } elsif ("$ARGV[0]" =~ /^[-+]./) {
128 userror();
129 } else {
130 last;
131 }
132 shift @ARGV;
133 }
134 # Check that we're actually being asked to do something
135 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
136 # Issue warning for unhandled reciprocity case
137 print STDERR "Warning: recommend both +forward and +backward with -t3\n" if
138 ($tensortree==3 && !($doforw && $doback));
139 $wrapper .= $tensortree ? " -a t$tensortree" : " -a kf -c";
140 $wrapper .= " -u $gunit";
141 # Get scene description and dimensions
142 if ( $mgfin ) {
143 system "mgf2rad @ARGV > $radscn";
144 die "Could not load MGF input\n" if ( $? );
145 } else {
146 system "xform -e @ARGV > $radscn";
147 die "Could not load Radiance input\n" if ( $? );
148 }
149 if ($#dim != 5) {
150 @dim = split ' ', `getbbox -h $radscn`;
151 }
152 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
153 $wrapper .= ' -f "t=' . ($dim[5] - $dim[4]) . ';w=' . ($dim[1] - $dim[0]) .
154 ';h=' . ($dim[3] - $dim[2]) . '"';
155 # Generate octree
156 system "oconv -w $radscn > $octree";
157 die "Could not compile scene\n" if ( $? );
158 # Add MGF description if requested
159 if ( $geout ) {
160 open(MGFSCN, "> $mgfscn");
161 printf MGFSCN "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
162 close MGFSCN;
163 if ( $mgfin ) {
164 system qq{mgfilt "#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus" @ARGV >> $mgfscn};
165 } else {
166 system "rad2mgf $radscn >> $mgfscn";
167 }
168 open(MGFSCN, ">> $mgfscn");
169 print MGFSCN "xf\n";
170 close MGFSCN;
171 $wrapper .= " -g $mgfscn";
172 }
173 # Create receiver & sender surfaces (rectangular)
174 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + 1);
175 my $ny = int($nsamp/$nx + 1);
176 $nsamp = $nx * $ny;
177 my $ns = 2**$ttlog2;
178 open(RADSCN, "> $receivers");
179 print RADSCN '#@rfluxmtx ' . ($tensortree ? "h=sc$ns\n" : "h=kf\n");
180 print RADSCN '#@rfluxmtx ' . "u=Y o=$facedat\n\n";
181 print RADSCN "void glow receiver_face\n0\n0\n4 1 1 1 0\n\n";
182 print RADSCN "receiver_face source f_receiver\n0\n0\n4 0 0 1 180\n\n";
183 print RADSCN '#@rfluxmtx ' . "u=Y o=$behinddat\n\n";
184 print RADSCN "void glow receiver_behind\n0\n0\n4 1 1 1 0\n\n";
185 print RADSCN "receiver_behind source b_receiver\n0\n0\n4 0 0 -1 180\n";
186 close RADSCN;
187 # Finish rfluxmtx command and prepare sender surfaces
188 $rfluxmtx .= " -n $nproc -c $nsamp";
189 if ( $tensortree != 3 ) { # Isotropic tensor tree is exception
190 open (RADSCN, "> $fsender");
191 print RADSCN '#@rfluxmtx u=Y ' . ($tensortree ? "h=sc$ns\n\n" : "h=kf\n\n");
192 print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
193 printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[2], $dim[4];
194 printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[3], $dim[4];
195 printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[3], $dim[4];
196 printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[2], $dim[4];
197 close RADSCN;
198 open (RADSCN, "> $bsender");
199 print RADSCN '#@rfluxmtx u=Y ' . ($tensortree ? "h=sc$ns\n\n" : "h=kf\n\n");
200 print RADSCN "void polygon fwd_sender\n0\n0\n12\n";
201 printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[2], $dim[5];
202 printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[2], $dim[5];
203 printf RADSCN "\t%f\t%f\t%f\n", $dim[1], $dim[3], $dim[5];
204 printf RADSCN "\t%f\t%f\t%f\n", $dim[0], $dim[3], $dim[5];
205 close RADSCN;
206 }
207 # Create data segments (all the work happens here)
208 if ( $tensortree ) {
209 do_tree_bsdf();
210 } else {
211 do_matrix_bsdf();
212 }
213 # Output XML
214 my $old_fh = select(STDOUT);
215 $| = 1;
216 select($old_fh);
217 print "<!-- Created by: genBSDF @savedARGV -->\n";
218 # print STDERR "Running: $wrapper\n";
219 system $wrapper;
220 die "Could not wrap BSDF data\n" if ( $? );
221 # Clean up temporary files and exit
222 system $rmtmp;
223
224 #-------------- End of main program segment --------------#
225
226 #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
227 sub do_tree_bsdf {
228
229 # Run rfluxmtx processes to compute each side
230 do_ttree_dir(0) if ( $doback );
231 do_ttree_dir(1) if ( $doforw );
232
233 } # end of sub do_tree_bsdf()
234
235 # Call rfluxmtx and process tensor tree BSDF for the given direction
236 sub do_ttree_dir {
237 my $forw = shift;
238 my $cmd;
239 if ( $tensortree == 3 ) {
240 # Isotropic BSDF
241 my $ns2 = $ns / 2;
242 if ($windoz) {
243 $cmd = "cnt $ns2 $ny $nx " .
244 qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
245 qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
246 qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
247 qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
248 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
249 qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
250 qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
251 qq{-e "\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz" } .
252 qq{-e "\$4=Dx;\$5=Dy;\$6=myDz" } .
253 "| $rfluxmtx -fa -y $ns2 - $receivers -i $octree";
254 } else {
255 $cmd = "cnt $ns2 $ny $nx " .
256 qq{| rcalc -e "r1=rand(.8681*recno-.673892)" } .
257 qq{-e "r2=rand(-5.37138*recno+67.1737811)" } .
258 qq{-e "r3=rand(+3.17603772*recno+83.766771)" } .
259 qq{-e "Dx=1-2*(\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)" } .
260 qq{-e "xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]" } .
261 qq{-e "yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]" } .
262 qq{-e "zp=$dim[5-$forw]" -e "myDz=Dz*($forw*2-1)" } .
263 qq{-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' } .
264 qq{-e '\$4=Dx;\$5=Dy;\$6=myDz' -of } .
265 "| $rfluxmtx -h -ff -y $ns2 - $receivers -i $octree";
266 }
267 } else {
268 # Anisotropic BSDF
269 my $sender = ($bsender,$fsender)[$forw];
270 if ($windoz) {
271 $cmd = "$rfluxmtx -fa $sender $receivers -i $octree";
272 } else {
273 $cmd = "$rfluxmtx -h -ff $sender $receivers -i $octree";
274 }
275 }
276 # print STDERR "Starting: $cmd\n";
277 system $cmd;
278 die "Failure running rfluxmtx" if ( $? );
279 ttree_out($forw);
280 } # end of do_ttree_dir()
281
282 # Simplify and store tensor tree results
283 sub ttree_out {
284 my $forw = shift;
285 my ($refldat,$transdat);
286 if ( $forw ) {
287 $transdat = $facedat;
288 $refldat = $behinddat;
289 } else {
290 $transdat = $behinddat;
291 $refldat = $facedat;
292 }
293 # Only output one transmitted anisotropic distribution, preferring backwards
294 if ( !$forw || !$doback || $tensortree==3 ) {
295 my $ttyp = ("tb","tf")[$forw];
296 ttree_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
297 if ( $docolor ) {
298 ttree_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
299 ttree_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
300 }
301 }
302 # Output reflection
303 my $rtyp = ("rb","rf")[$forw];
304 ttree_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
305 if ( $docolor ) {
306 ttree_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
307 ttree_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
308 }
309 } # end of ttree_out()
310
311 # Call rttree_reduce on the given component
312 sub ttree_comp {
313 my $typ = shift;
314 my $spec = shift;
315 my $src = shift;
316 my $dest = shift;
317 my $cmd;
318 if ($windoz) {
319 if ("$spec" eq "Visible") {
320 $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
321 q{-e "$1=(0.265*$1+0.670*$2+0.065*$3)/Omega"};
322 } elsif ("$spec" eq "CIE-X") {
323 $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
324 q{-e "$1=(0.514*$1+0.324*$2+0.162*$3)/Omega"};
325 } elsif ("$spec" eq "CIE-Z") {
326 $cmd = qq{rcalc -e "Omega:PI/($ns*$ns)" } .
327 q{-e "$1=(0.024*$1+0.123*$2+0.853*$3)/Omega"};
328 }
329 } else {
330 if ("$spec" eq "Visible") {
331 $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
332 q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega'};
333 } elsif ("$spec" eq "CIE-X") {
334 $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
335 q{-e '$1=(0.514*$1+0.324*$2+0.162*$3)/Omega'};
336 } elsif ("$spec" eq "CIE-Z") {
337 $cmd = "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
338 q{-e '$1=(0.024*$1+0.123*$2+0.853*$3)/Omega'};
339 }
340 }
341 if ($pctcull >= 0) {
342 my $avg = ( "$typ" =~ /^r[fb]/ ) ? " -a" : "";
343 if ($windoz) {
344 $cmd = "rcollate -ho -oc 1 $src | " .
345 $cmd .
346 " | rttree_reduce$avg -h -fa -t $pctcull -r $tensortree -g $ttlog2";
347 } else {
348 $cmd .= " -of $src " .
349 "| rttree_reduce$avg -h -ff -t $pctcull -r $tensortree -g $ttlog2";
350 }
351 # print STDERR "Running: $cmd\n";
352 system "$cmd > $dest";
353 die "Failure running rttree_reduce" if ( $? );
354 } else {
355 if ($windoz) {
356 $cmd = "rcollate -ho -oc 1 $src | " . $cmd ;
357 } else {
358 $cmd .= " $src";
359 }
360 open(DATOUT, "> $dest");
361 print DATOUT "{\n";
362 close DATOUT;
363 # print STDERR "Running: $cmd\n";
364 system "$cmd >> $dest";
365 die "Failure running rcalc" if ( $? );
366 open(DATOUT, ">> $dest");
367 for (my $i = ($tensortree==3)*$ns*$ns*$ns/2; $i-- > 0; ) {
368 print DATOUT "0\n";
369 }
370 print DATOUT "}\n";
371 close DATOUT;
372 }
373 if ( "$spec" ne "$curspec" ) {
374 $wrapper .= " -s $spec";
375 $curspec = $spec;
376 }
377 $wrapper .= " -$typ $dest";
378 } # end of ttree_comp()
379
380 #------------- End of do_tree_bsdf() & subroutines -------------#
381
382 #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
383 sub do_matrix_bsdf {
384
385 # Run rfluxmtx processes to compute each side
386 do_matrix_dir(0) if ( $doback );
387 do_matrix_dir(1) if ( $doforw );
388
389 } # end of sub do_matrix_bsdf()
390
391 # Call rfluxmtx and process tensor tree BSDF for the given direction
392 sub do_matrix_dir {
393 my $forw = shift;
394 my $cmd;
395 my $sender = ($bsender,$fsender)[$forw];
396 $cmd = "$rfluxmtx -fd $sender $receivers -i $octree";
397 # print STDERR "Starting: $cmd\n";
398 system $cmd;
399 die "Failure running rfluxmtx" if ( $? );
400 matrix_out($forw);
401 } # end of do_matrix_dir()
402
403 sub matrix_out {
404 my $forw = shift;
405 my ($refldat,$transdat);
406 if ( $forw ) {
407 $transdat = $facedat;
408 $refldat = $behinddat;
409 } else {
410 $transdat = $behinddat;
411 $refldat = $facedat;
412 }
413 # Output transmission
414 my $ttyp = ("tb","tf")[$forw];
415 matrix_comp($ttyp, "Visible", $transdat, ($tb,$tf)[$forw]);
416 if ( $docolor ) {
417 matrix_comp($ttyp, "CIE-X", $transdat, ($tbx,$tfx)[$forw]);
418 matrix_comp($ttyp, "CIE-Z", $transdat, ($tbz,$tfz)[$forw]);
419 }
420 # Output reflection
421 my $rtyp = ("rb","rf")[$forw];
422 matrix_comp($rtyp, "Visible", $refldat, ($rb,$rf)[$forw]);
423 if ( $docolor ) {
424 matrix_comp($rtyp, "CIE-X", $refldat, ($rbx,$rfx)[$forw]);
425 matrix_comp($rtyp, "CIE-Z", $refldat, ($rbz,$rfz)[$forw]);
426 }
427 } # end of matrix_out()
428
429 # Transpose matrix component data and save to file
430 sub matrix_comp {
431 my $typ = shift;
432 my $spec = shift;
433 my $src = shift;
434 my $dest = shift;
435 my $cmd = "rmtxop -fa -t";
436 if ("$spec" eq "Visible") {
437 $cmd .= " -c 0.265 0.670 0.065";
438 } elsif ("$spec" eq "CIE-X") {
439 $cmd .= " -c 0.514 0.324 0.162";
440 } elsif ("$spec" eq "CIE-Z") {
441 $cmd .= " -c 0.024 0.123 0.853";
442 }
443 $cmd .= " $src | rcollate -ho -oc 145";
444 # print STDERR "Running: $cmd\n";
445 system "$cmd > $dest";
446 die "Failure running rttree_reduce" if ( $? );
447 if ( "$spec" ne "$curspec" ) {
448 $wrapper .= " -s $spec";
449 $curspec = $spec;
450 }
451 $wrapper .= " -$typ $dest";
452 } # end of matrix_comp()
453
454 #------------- End of do_matrix_bsdf() & subroutines --------------#
