root/radiance/ray/src/util/genBSDF.pl
Revision: 2.25
Committed: Wed Aug 24 04:14:58 2011 UTC (13 years, 11 months ago) by greg
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.24 2011/08/23 14:02:41 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 use File::Temp qw/ :mktemp /;
10 sub userror {
11 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
12 exit 1;
13 }
14 my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
15 chomp $td;
16 my @savedARGV = @ARGV;
17 my $tensortree = 0;
18 my $ttlog2 = 4;
19 my $nsamp = 2000;
20 my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
21 my $mgfin = 0;
22 my $geout = 1;
23 my $nproc = 1;
24 my $doforw = 0;
25 my $doback = 1;
26 my $gunit = "Meter";
27 my @dim;
28 # Get options
29 while ($#ARGV >= 0) {
30 if ("$ARGV[0]" =~ /^[-+]m/) {
31 $mgfin = ("$ARGV[0]" =~ /^\+/);
32 } elsif ("$ARGV[0]" eq "-r") {
33 $rtargs = "$rtargs $ARGV[1]";
34 shift @ARGV;
35 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
36 $geout = ("$ARGV[0]" =~ /^\+/);
37 $gunit = $ARGV[1];
38 if ($gunit !~ /^(?i)(meter|foot|inch|centimeter|millimeter)$/) {
39 die "Illegal geometry unit '$gunit': must be meter, foot, inch, centimeter, or millimeter\n";
40 }
41 shift @ARGV;
42 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
43 $doforw = ("$ARGV[0]" =~ /^\+/);
44 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
45 $doback = ("$ARGV[0]" =~ /^\+/);
46 } elsif ("$ARGV[0]" =~ /^-t[34]$/) {
47 $tensortree = substr($ARGV[0], 2, 1);
48 $ttlog2 = $ARGV[1];
49 shift @ARGV;
50 } elsif ("$ARGV[0]" eq "-c") {
51 $nsamp = $ARGV[1];
52 shift @ARGV;
53 } elsif ("$ARGV[0]" eq "-n") {
54 $nproc = $ARGV[1];
55 shift @ARGV;
56 } elsif ("$ARGV[0]" =~ /^-d/) {
57 userror() if ($#ARGV < 6);
58 @dim = @ARGV[1..6];
59 shift @ARGV for (1..6);
60 } elsif ("$ARGV[0]" =~ /^[-+]./) {
61 userror();
62 } else {
63 last;
64 }
65 shift @ARGV;
66 }
67 # Check that we're actually being asked to do something
68 die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
69 # Name our own persist file?
70 my $persistfile;
71 if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) {
72 $persistfile = "$td/pfile.txt";
73 $rtargs = "-PP $persistfile $rtargs";
74 }
75 # Get scene description and dimensions
76 my $radscn = "$td/device.rad";
77 my $mgfscn = "$td/device.mgf";
78 my $octree = "$td/device.oct";
79 if ( $mgfin ) {
80 system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
81 die "Could not load MGF input\n" if ( $? );
82 system "mgf2rad $mgfscn > $radscn";
83 } else {
84 system "xform -e @ARGV > $radscn";
85 die "Could not load Radiance input\n" if ( $? );
86 system "rad2mgf $radscn > $mgfscn" if ( $geout );
87 }
88 if ($#dim != 5) {
89 @dim = split ' ', `getbbox -h $radscn`;
90 }
91 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
92 # Add receiver surfaces (rectangular)
93 my $fmodnm="receiver_face";
94 my $bmodnm="receiver_behind";
95 open(RADSCN, ">> $radscn");
96 print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
97 print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
98 print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
99 print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
100 close RADSCN;
101 # Generate octree
102 system "oconv -w $radscn > $octree";
103 die "Could not compile scene\n" if ( $? );
104 # Output XML prologue
105 print
106 '<?xml version="1.0" encoding="UTF-8"?>
107 <WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
108 ';
109 print "<!-- File produced by: genBSDF @savedARGV -->\n";
110 print
111 '<WindowElementType>System</WindowElementType>
112 <Optical>
113 <Layer>
114 <Material>
115 <Name>Name</Name>
116 <Manufacturer>Manufacturer</Manufacturer>
117 ';
118 printf "\t\t<Thickness unit=\"$gunit\">%.3f</Thickness>\n", $dim[5] - $dim[4];
119 printf "\t\t<Width unit=\"$gunit\">%.3f</Width>\n", $dim[1] - $dim[0];
120 printf "\t\t<Height unit=\"$gunit\">%.3f</Height>\n", $dim[3] - $dim[2];
121 print "\t\t<DeviceType>Integral</DeviceType>\n";
122 # Output MGF description if requested
123 if ( $geout ) {
124 print "\t\t<Geometry format=\"MGF\" unit=\"$gunit\">\n";
125 printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
126 open(MGFSCN, "< $mgfscn");
127 while (<MGFSCN>) { print $_; }
128 close MGFSCN;
129 print "xf\n";
130 print "\t\t</Geometry>\n";
131 }
132 print " </Material>\n";
133 # Set up surface sampling
134 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
135 my $ny = int($nsamp/$nx + .5);
136 $nsamp = $nx * $ny;
137 my $ns = 2**$ttlog2;
138 my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
139 # Create data segments (all the work happens here)
140 if ( $tensortree ) {
141 do_tree_bsdf();
142 } else {
143 do_matrix_bsdf();
144 }
145 # Output XML epilogue
146 print
147 '</Layer>
148 </Optical>
149 </WindowElement>
150 ';
151 # Clean up temporary files and exit
152 if ( $persistfile && open(PFI, "< $persistfile") ) {
153 while (<PFI>) {
154 s/^[^ ]* //;
155 kill('ALRM', $_);
156 last;
157 }
158 close PFI;
159 }
160 exec("rm -rf $td");
161
162 #-------------- End of main program segment --------------#
163
164 #++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
165 sub do_tree_bsdf {
166 # Get sampling rate and subdivide task
167 my $ns2 = $ns;
168 $ns2 /= 2 if ( $tensortree == 3 );
169 my $nsplice = $nproc;
170 $nsplice *= 10 if ($nproc > 1);
171 $nsplice = $ns2 if ($nsplice > $ns2);
172 $nsplice = 999 if ($nsplice > 999);
173 @pdiv = (0, int($ns2/$nsplice));
174 my $nrem = $ns2 % $nsplice;
175 for (my $i = 1; $i < $nsplice; $i++) {
176 my $nv = $pdiv[$i] + $pdiv[1];
177 ++$nv if ( $nrem-- > 0 );
178 push @pdiv, $nv;
179 }
180 die "Script error 1" if ($pdiv[-1] != $ns2);
181 # Shirley-Chiu mapping from unit square to disk
182 $sq2disk = '
183 in_square_a = 2*in_square_x - 1;
184 in_square_b = 2*in_square_y - 1;
185 in_square_rgn = if(in_square_a + in_square_b,
186 if(in_square_a - in_square_b, 1, 2),
187 if(in_square_b - in_square_a, 3, 4));
188 out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b,
189 -in_square_a, -in_square_b);
190 out_disk_phi = PI/4 * select(in_square_rgn,
191 in_square_b/in_square_a,
192 2 - in_square_a/in_square_b,
193 4 + in_square_b/in_square_a,
194 if(in_square_b*in_square_b,
195 6 - in_square_a/in_square_b, 0));
196 Dx = out_disk_r*cos(out_disk_phi);
197 Dy = out_disk_r*sin(out_disk_phi);
198 Dz = sqrt(1 - out_disk_r*out_disk_r);
199 ';
200 # Shirley-Chiu mapping from unit disk to square
201 $disk2sq = '
202 norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
203 in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
204 in_disk_phi = norm_radians(atan2(Dy, Dx));
205 in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
206 out_square_a = select(in_disk_rgn,
207 in_disk_r,
208 (PI/2 - in_disk_phi)*in_disk_r/(PI/4),
209 -in_disk_r,
210 (in_disk_phi - 3*PI/2)*in_disk_r/(PI/4));
211 out_square_b = select(in_disk_rgn,
212 in_disk_phi*in_disk_r/(PI/4),
213 in_disk_r,
214 (PI - in_disk_phi)*in_disk_r/(PI/4),
215 -in_disk_r);
216 out_square_x = (out_square_a + 1)/2;
217 out_square_y = (out_square_b + 1)/2;
218 ';
219 # Announce ourselves in XML output
220 print "\t<DataDefinition>\n";
221 print "\t\t<IncidentDataStructure>TensorTree$tensortree</IncidentDataStructure>\n";
222 print "\t</DataDefinition>\n";
223 # Fork parallel rtcontrib processes to compute each side
224 my $npleft = $nproc;
225 if ( $doback ) {
226 for (my $splice = 0; $splice < $nsplice; $splice++) {
227 if (! $npleft ) {
228 wait();
229 die "rtcontrib process reported error" if ( $? );
230 $npleft++;
231 }
232 bg_tree_rtcontrib(0, $splice);
233 $npleft--;
234 }
235 while (wait() >= 0) {
236 die "rtcontrib process reported error" if ( $? );
237 $npleft++;
238 }
239 ttree_out(0);
240 }
241 if ( $doforw ) {
242 for (my $splice = 0; $splice < $nsplice; $splice++) {
243 if (! $npleft ) {
244 wait();
245 die "rtcontrib process reported error" if ( $? );
246 $npleft++;
247 }
248 bg_tree_rtcontrib(1, $splice);
249 $npleft--;
250 }
251 while (wait() >= 0) {
252 die "rtcontrib process reported error" if ( $? );
253 $npleft++;
254 }
255 ttree_out(1);
256 }
257 } # end of sub do_tree_bsdf()
258
259 # Run rtcontrib process in background to generate tensor tree samples
260 sub bg_tree_rtcontrib {
261 my $pid = fork();
262 die "Cannot fork new process" unless defined $pid;
263 if ($pid > 0) { return $pid; }
264 my $forw = shift;
265 my $pn = shift;
266 my $pbeg = $pdiv[$pn];
267 my $plen = $pdiv[$pn+1] - $pbeg;
268 my $matargs = "-m $bmodnm";
269 if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; }
270 my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " .
271 "-e '$disk2sq' -bn '$ns*$ns' " .
272 "-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
273 "-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree";
274 if ( $tensortree == 3 ) {
275 # Isotropic BSDF
276 $cmd = "cnt $plen $ny $nx " .
277 "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
278 "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
279 "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
280 "-e 'Dx=1-2*($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
281 "-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
282 "-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
283 "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
284 "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
285 "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
286 "| $cmd";
287 } else {
288 # Anisotropic BSDF
289 # Sample area vertically to improve load balance, since
290 # shading systems usually have bilateral symmetry (L-R)
291 $cmd = "cnt $plen $ns $ny $nx " .
292 "| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
293 "-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
294 "-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
295 "-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " .
296 "-e 'in_square_x=($pbeg+\$1+r1)/$ns' " .
297 "-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
298 "-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
299 "-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
300 "-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
301 "-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
302 "-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
303 "| $cmd";
304 }
305 # print STDERR "Starting: $cmd\n";
306 exec($cmd); # no return; status report to parent via wait
307 die "Cannot exec: $cmd\n";
308 } # end of bg_tree_rtcontrib()
309
310 # Simplify and output tensor tree results
311 sub ttree_out {
312 my $forw = shift;
313 my $side = ("Back","Front")[$forw];
314 # Only output one transmitted distribution, preferring backwards
315 if ( !$forw || !$doback ) {
316 print
317 ' <WavelengthData>
318 <LayerNumber>System</LayerNumber>
319 <Wavelength unit="Integral">Visible</Wavelength>
320 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
321 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
322 <WavelengthDataBlock>
323 <WavelengthDataDirection>Transmission</WavelengthDataDirection>
324 <AngleBasis>LBNL/Shirley-Chiu</AngleBasis>
325 <ScatteringDataType>BTDF</ScatteringDataType>
326 <ScatteringData>
327 ';
328 system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
329 q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
330 "$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " .
331 "| rttree_reduce -h -ff -r $tensortree -g $ttlog2";
332 die "Failure running rttree_reduce" if ( $? );
333 print
334 ' </ScatteringData>
335 </WavelengthDataBlock>
336 </WavelengthData>
337 ';
338 }
339 # Output reflection
340 print
341 ' <WavelengthData>
342 <LayerNumber>System</LayerNumber>
343 <Wavelength unit="Integral">Visible</Wavelength>
344 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
345 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
346 <WavelengthDataBlock>
347 ';
348 print "\t\t\t<WavelengthDataDirection>Reflection $side</WavelengthDataDirection>\n";
349 print
350 ' <AngleBasis>LBNL/Shirley-Chiu</AngleBasis>
351 <ScatteringDataType>BRDF</ScatteringDataType>
352 <ScatteringData>
353 ';
354 system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
355 q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
356 "$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " .
357 "| rttree_reduce -h -ff -r $tensortree -g $ttlog2";
358 die "Failure running rttree_reduce" if ( $? );
359 print
360 ' </ScatteringData>
361 </WavelengthDataBlock>
362 </WavelengthData>
363 ';
364 } # end of ttree_out()
365
366 #------------- End of do_tree_bsdf() & subroutines -------------#
367
368 #+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
369 sub do_matrix_bsdf {
370 # Set up sampling of portal
371 # Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
372 $tcal = '
373 DEGREE : PI/180;
374 sq(x) : x*x;
375 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
376 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
377 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
378 Kmax : Kaccum(Knaz(0));
379 Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
380 Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
381 Kcol = Kbin - Kaccum(Krow-1);
382 Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
383 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
384 sin_kpol = sin(Kpol);
385 Dx = cos(Kazi)*sin_kpol;
386 Dy = sin(Kazi)*sin_kpol;
387 Dz = sqrt(1 - sin_kpol*sin_kpol);
388 KprojOmega = PI * if(Kbin-.5,
389 (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
390 1 - sq(cos(Kpola(1)*DEGREE)));
391 ';
392 # Compute Klems bin from exiting ray direction (forward or backward)
393 $kcal = '
394 DEGREE : PI/180;
395 abs(x) : if(x, x, -x);
396 Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
397 posangle(a) : if(-a, a + 2*PI, a);
398 Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
399 kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
400 knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
401 kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
402 kfindrow(r, pol) : if(r-kpola(0)+.5, r,
403 if(pol-kpola(r), kfindrow(r+1, pol), r) );
404 kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
405 kbin2(pol,azi) = select(kfindrow(1, pol),
406 kazn(azi,360/knaz(1)),
407 kaccum(1) + kazn(azi,360/knaz(2)),
408 kaccum(2) + kazn(azi,360/knaz(3)),
409 kaccum(3) + kazn(azi,360/knaz(4)),
410 kaccum(4) + kazn(azi,360/knaz(5)),
411 kaccum(5) + kazn(azi,360/knaz(6)),
412 kaccum(6) + kazn(azi,360/knaz(7)),
413 kaccum(7) + kazn(azi,360/knaz(8)),
414 kaccum(8) + kazn(azi,360/knaz(9))
415 );
416 kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
417 ';
418 my $ndiv = 145;
419 # Compute scattering data using rtcontrib
420 my @tfarr;
421 my @rfarr;
422 my @tbarr;
423 my @rbarr;
424 my $cmd;
425 my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
426 "-e '$kcal' -b kbin -bn $ndiv " .
427 "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
428 my $rccmd = "rcalc -e '$tcal' " .
429 "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
430 q{-if3 -e 'oval=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega' } .
431 q[-o '${ oval },'];
432 if ( $doforw ) {
433 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
434 "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
435 "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
436 "-e 'zp:$dim[4]' " .
437 q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
438 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
439 "| $rtcmd";
440 system "$cmd" || die "Failure running: $cmd\n";
441 @tfarr = `$rccmd $td/$fmodnm.flt`;
442 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
443 @rfarr = `$rccmd $td/$bmodnm.flt`;
444 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
445 }
446 if ( $doback ) {
447 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
448 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
449 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
450 "-e 'zp:$dim[5]' " .
451 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
452 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
453 "| $rtcmd";
454 system "$cmd" || die "Failure running: $cmd\n";
455 @tbarr = `$rccmd $td/$bmodnm.flt`;
456 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
457 @rbarr = `$rccmd $td/$fmodnm.flt`;
458 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
459 }
460 # Output angle basis
461 print
462 ' <DataDefinition>
463 <IncidentDataStructure>Columns</IncidentDataStructure>
464 <AngleBasis>
465 <AngleBasisName>LBNL/Klems Full</AngleBasisName>
466 <AngleBasisBlock>
467 <Theta>0</Theta>
468 <nPhis>1</nPhis>
469 <ThetaBounds>
470 <LowerTheta>0</LowerTheta>
471 <UpperTheta>5</UpperTheta>
472 </ThetaBounds>
473 </AngleBasisBlock>
474 <AngleBasisBlock>
475 <Theta>10</Theta>
476 <nPhis>8</nPhis>
477 <ThetaBounds>
478 <LowerTheta>5</LowerTheta>
479 <UpperTheta>15</UpperTheta>
480 </ThetaBounds>
481 </AngleBasisBlock>
482 <AngleBasisBlock>
483 <Theta>20</Theta>
484 <nPhis>16</nPhis>
485 <ThetaBounds>
486 <LowerTheta>15</LowerTheta>
487 <UpperTheta>25</UpperTheta>
488 </ThetaBounds>
489 </AngleBasisBlock>
490 <AngleBasisBlock>
491 <Theta>30</Theta>
492 <nPhis>20</nPhis>
493 <ThetaBounds>
494 <LowerTheta>25</LowerTheta>
495 <UpperTheta>35</UpperTheta>
496 </ThetaBounds>
497 </AngleBasisBlock>
498 <AngleBasisBlock>
499 <Theta>40</Theta>
500 <nPhis>24</nPhis>
501 <ThetaBounds>
502 <LowerTheta>35</LowerTheta>
503 <UpperTheta>45</UpperTheta>
504 </ThetaBounds>
505 </AngleBasisBlock>
506 <AngleBasisBlock>
507 <Theta>50</Theta>
508 <nPhis>24</nPhis>
509 <ThetaBounds>
510 <LowerTheta>45</LowerTheta>
511 <UpperTheta>55</UpperTheta>
512 </ThetaBounds>
513 </AngleBasisBlock>
514 <AngleBasisBlock>
515 <Theta>60</Theta>
516 <nPhis>24</nPhis>
517 <ThetaBounds>
518 <LowerTheta>55</LowerTheta>
519 <UpperTheta>65</UpperTheta>
520 </ThetaBounds>
521 </AngleBasisBlock>
522 <AngleBasisBlock>
523 <Theta>70</Theta>
524 <nPhis>16</nPhis>
525 <ThetaBounds>
526 <LowerTheta>65</LowerTheta>
527 <UpperTheta>75</UpperTheta>
528 </ThetaBounds>
529 </AngleBasisBlock>
530 <AngleBasisBlock>
531 <Theta>82.5</Theta>
532 <nPhis>12</nPhis>
533 <ThetaBounds>
534 <LowerTheta>75</LowerTheta>
535 <UpperTheta>90</UpperTheta>
536 </ThetaBounds>
537 </AngleBasisBlock>
538 </AngleBasis>
539 </DataDefinition>
540 ';
541 if ( $doforw ) {
542 print
543 ' <WavelengthData>
544 <LayerNumber>System</LayerNumber>
545 <Wavelength unit="Integral">Visible</Wavelength>
546 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
547 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
548 <WavelengthDataBlock>
549 <WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
550 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
551 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
552 <ScatteringDataType>BTDF</ScatteringDataType>
553 <ScatteringData>
554 ';
555 # Output front transmission (transposed order)
556 for (my $od = 0; $od < $ndiv; $od++) {
557 for (my $id = 0; $id < $ndiv; $id++) {
558 print $tfarr[$ndiv*$id + $od];
559 }
560 print "\n";
561 }
562 print
563 ' </ScatteringData>
564 </WavelengthDataBlock>
565 </WavelengthData>
566 <WavelengthData>
567 <LayerNumber>System</LayerNumber>
568 <Wavelength unit="Integral">Visible</Wavelength>
569 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
570 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
571 <WavelengthDataBlock>
572 <WavelengthDataDirection>Reflection Front</WavelengthDataDirection>
573 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
574 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
575 <ScatteringDataType>BRDF</ScatteringDataType>
576 <ScatteringData>
577 ';
578 # Output front reflection (transposed order)
579 for (my $od = 0; $od < $ndiv; $od++) {
580 for (my $id = 0; $id < $ndiv; $id++) {
581 print $rfarr[$ndiv*$id + $od];
582 }
583 print "\n";
584 }
585 print
586 ' </ScatteringData>
587 </WavelengthDataBlock>
588 </WavelengthData>
589 ';
590 }
591 if ( $doback ) {
592 print
593 ' <WavelengthData>
594 <LayerNumber>System</LayerNumber>
595 <Wavelength unit="Integral">Visible</Wavelength>
596 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
597 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
598 <WavelengthDataBlock>
599 <WavelengthDataDirection>Transmission Back</WavelengthDataDirection>
600 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
601 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
602 <ScatteringDataType>BTDF</ScatteringDataType>
603 <ScatteringData>
604 ';
605 # Output back transmission (transposed order)
606 for (my $od = 0; $od < $ndiv; $od++) {
607 for (my $id = 0; $id < $ndiv; $id++) {
608 print $tbarr[$ndiv*$id + $od];
609 }
610 print "\n";
611 }
612 print
613 ' </ScatteringData>
614 </WavelengthDataBlock>
615 </WavelengthData>
616 <WavelengthData>
617 <LayerNumber>System</LayerNumber>
618 <Wavelength unit="Integral">Visible</Wavelength>
619 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
620 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
621 <WavelengthDataBlock>
622 <WavelengthDataDirection>Reflection Back</WavelengthDataDirection>
623 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
624 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
625 <ScatteringDataType>BRDF</ScatteringDataType>
626 <ScatteringData>
627 ';
628 # Output back reflection (transposed order)
629 for (my $od = 0; $od < $ndiv; $od++) {
630 for (my $id = 0; $id < $ndiv; $id++) {
631 print $rbarr[$ndiv*$id + $od];
632 }
633 print "\n";
634 }
635 print
636 ' </ScatteringData>
637 </WavelengthDataBlock>
638 </WavelengthData>
639 ';
640 }
641 }
642 #------------- End of do_matrix_bsdf() --------------#
