| 1 |
#!/usr/bin/perl -w
| 2 |
# RCSid $Id: genBSDF.pl,v 2.16 2011/05/31 20:50:26 greg Exp $
| 3 |
| 4 |
# Compute BSDF based on geometry and material description
| 5 |
| 6 |
# G. Ward
| 7 |
| 8 |
use strict;
| 9 |
use File::Temp qw/ :mktemp /;
| 10 |
sub userror {
| 11 |
print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-t{3|4} Nlog2][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
| 12 |
exit 1;
| 13 |
| 14 |
my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
| 15 |
chomp $td;
| 16 |
my $tensortree = 0;
| 17 |
my $ttlog2 = 4;
| 18 |
my $nsamp = 1000;
| 19 |
my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
| 20 |
my $mgfin = 0;
| 21 |
my $geout = 1;
| 22 |
my $nproc = 1;
| 23 |
my $doforw = 0;
| 24 |
my $doback = 1;
| 25 |
my @dim;
| 26 |
# Get options
| 27 |
while ($#ARGV >= 0) {
| 28 |
if ("$ARGV[0]" =~ /^[-+]m/) {
| 29 |
$mgfin = ("$ARGV[0]" =~ /^\+/);
| 30 |
} elsif ("$ARGV[0]" eq "-r") {
| 31 |
$rtargs = "$rtargs $ARGV[1]";
| 32 |
shift @ARGV;
| 33 |
} elsif ("$ARGV[0]" =~ /^[-+]g/) {
| 34 |
$geout = ("$ARGV[0]" =~ /^\+/);
| 35 |
} elsif ("$ARGV[0]" =~ /^[-+]f/) {
| 36 |
$doforw = ("$ARGV[0]" =~ /^\+/);
| 37 |
} elsif ("$ARGV[0]" =~ /^[-+]b/) {
| 38 |
$doback = ("$ARGV[0]" =~ /^\+/);
| 39 |
} elsif ("$ARGV[0]" =~ /^-t[34]$/) {
| 40 |
$tensortree = substr($ARGV[0], 2, 1);
| 41 |
$ttlog2 = $ARGV[1];
| 42 |
shift @ARGV;
| 43 |
} elsif ("$ARGV[0]" eq "-c") {
| 44 |
$nsamp = $ARGV[1];
| 45 |
shift @ARGV;
| 46 |
} elsif ("$ARGV[0]" eq "-n") {
| 47 |
$nproc = $ARGV[1];
| 48 |
shift @ARGV;
| 49 |
} elsif ("$ARGV[0]" =~ /^-d/) {
| 50 |
userror() if ($#ARGV < 6);
| 51 |
@dim = @ARGV[1..6];
| 52 |
shift @ARGV for (1..6);
| 53 |
} elsif ("$ARGV[0]" =~ /^[-+]./) {
| 54 |
userror();
| 55 |
} else {
| 56 |
last;
| 57 |
| 58 |
shift @ARGV;
| 59 |
| 60 |
# Check that we're actually being asked to do something
| 61 |
die "Must have at least one of +forward or +backward\n" if (!$doforw && !$doback);
| 62 |
# Name our own persist file?
| 63 |
my $persistfile;
| 64 |
if ( $tensortree && $nproc > 1 && "$rtargs" !~ /-PP /) {
| 65 |
$persistfile = "$td/pfile.txt";
| 66 |
$rtargs = "-PP $persistfile $rtargs";
| 67 |
| 68 |
# Get scene description and dimensions
| 69 |
my $radscn = "$td/device.rad";
| 70 |
my $mgfscn = "$td/device.mgf";
| 71 |
my $octree = "$td/device.oct";
| 72 |
if ( $mgfin ) {
| 73 |
system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
| 74 |
die "Could not load MGF input\n" if ( $? );
| 75 |
system "mgf2rad $mgfscn > $radscn";
| 76 |
} else {
| 77 |
system "xform -e @ARGV > $radscn";
| 78 |
die "Could not load Radiance input\n" if ( $? );
| 79 |
system "rad2mgf $radscn > $mgfscn" if ( $geout );
| 80 |
| 81 |
if ($#dim != 5) {
| 82 |
@dim = split ' ', `getbbox -h $radscn`;
| 83 |
| 84 |
print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
| 85 |
# Add receiver surfaces (rectangular)
| 86 |
my $fmodnm="receiver_face";
| 87 |
my $bmodnm="receiver_behind";
| 88 |
open(RADSCN, ">> $radscn");
| 89 |
print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
| 90 |
print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
| 91 |
print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
| 92 |
print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
| 93 |
close RADSCN;
| 94 |
# Generate octree
| 95 |
system "oconv -w $radscn > $octree";
| 96 |
die "Could not compile scene\n" if ( $? );
| 97 |
# Output XML prologue
| 98 |
print
| 99 |
'<?xml version="1.0" encoding="UTF-8"?>
| 100 |
<WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
| 101 |
<WindowElementType>System</WindowElementType>
| 102 |
<Optical>
| 103 |
<Layer>
| 104 |
<Material>
| 105 |
<Name>Name</Name>
| 106 |
<Manufacturer>Manufacturer</Manufacturer>
| 107 |
| 108 |
printf "\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4];
| 109 |
printf "\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0];
| 110 |
printf "\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2];
| 111 |
print "\t\t<DeviceType>Integral</DeviceType>\n";
| 112 |
# Output MGF description if requested
| 113 |
if ( $geout ) {
| 114 |
print "\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n";
| 115 |
printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
| 116 |
open(MGFSCN, "< $mgfscn");
| 117 |
while (<MGFSCN>) { print $_; }
| 118 |
close MGFSCN;
| 119 |
print "xf\n";
| 120 |
print "\t\t</Geometry>\n";
| 121 |
| 122 |
print " </Material>\n";
| 123 |
# Set up surface sampling
| 124 |
my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
| 125 |
my $ny = int($nsamp/$nx + .5);
| 126 |
$nsamp = $nx * $ny;
| 127 |
my $ns = 2**$ttlog2;
| 128 |
my (@pdiv, $disk2sq, $sq2disk, $tcal, $kcal);
| 129 |
# Create data segments (all the work happens here)
| 130 |
if ( $tensortree ) {
| 131 |
do_tree_bsdf();
| 132 |
} else {
| 133 |
do_matrix_bsdf();
| 134 |
| 135 |
# Output XML epilogue
| 136 |
print
| 137 |
'</Layer>
| 138 |
</Optical>
| 139 |
</WindowElement>
| 140 |
| 141 |
# Clean up temporary files and exit
| 142 |
if ( $persistfile && open(PFI, "< $persistfile") ) {
| 143 |
while (<PFI>) {
| 144 |
s/^[^ ]* //;
| 145 |
kill('ALRM', $_);
| 146 |
last;
| 147 |
| 148 |
close PFI;
| 149 |
| 150 |
exec("rm -rf $td");
| 151 |
| 152 |
#-------------- End of main program segment --------------#
| 153 |
| 154 |
#++++++++++++++ Tensor tree BSDF generation ++++++++++++++#
| 155 |
sub do_tree_bsdf {
| 156 |
# Get sampling rate and subdivide task
| 157 |
my $ns2 = $ns;
| 158 |
$ns2 /= 2 if ( $tensortree == 3 );
| 159 |
@pdiv = (0, int($ns2/$nproc));
| 160 |
my $nrem = $ns2 % $nproc;
| 161 |
for (my $i = 1; $i < $nproc; $i++) {
| 162 |
my $nv = $pdiv[$i] + $pdiv[1];
| 163 |
++$nv if ( $nrem-- > 0 );
| 164 |
push @pdiv, $nv;
| 165 |
| 166 |
die "Script error 1" if ($pdiv[-1] != $ns2);
| 167 |
# Shirley-Chiu mapping from unit square to disk
| 168 |
$sq2disk = '
| 169 |
in_square_a = 2*in_square_x - 1;
| 170 |
in_square_b = 2*in_square_y - 1;
| 171 |
in_square_rgn = if(in_square_a + in_square_b,
| 172 |
if(in_square_a - in_square_b, 1, 2),
| 173 |
if(in_square_b - in_square_a, 3, 4));
| 174 |
out_disk_r = .999995*select(in_square_rgn, in_square_a, in_square_b,
| 175 |
-in_square_a, -in_square_b);
| 176 |
out_disk_phi = PI/4 * select(in_square_rgn,
| 177 |
in_square_b/in_square_a,
| 178 |
2 - in_square_a/in_square_b,
| 179 |
4 + in_square_b/in_square_a,
| 180 |
if(in_square_b*in_square_b,
| 181 |
6 - in_square_a/in_square_b, 0));
| 182 |
Dx = out_disk_r*cos(out_disk_phi);
| 183 |
Dy = out_disk_r*sin(out_disk_phi);
| 184 |
Dz = sqrt(1 - out_disk_r*out_disk_r);
| 185 |
| 186 |
# Shirley-Chiu mapping from unit disk to square
| 187 |
$disk2sq = '
| 188 |
norm_radians(p) : if(-p - PI/4, p + 2*PI, p);
| 189 |
in_disk_r = .999995*sqrt(Dx*Dx + Dy*Dy);
| 190 |
in_disk_phi = norm_radians(atan2(Dy, Dx));
| 191 |
in_disk_rgn = floor((in_disk_phi + PI/4)/(PI/2)) + 1;
| 192 |
out_square_a = select(in_disk_rgn,
| 193 |
in_disk_r,
| 194 |
(PI/2 - in_disk_phi)*in_disk_r/(PI/4),
| 195 |
-in_disk_r,
| 196 |
(in_disk_phi - 3*PI/2)*in_disk_r/(PI/4));
| 197 |
out_square_b = select(in_disk_rgn,
| 198 |
in_disk_phi*in_disk_r/(PI/4),
| 199 |
in_disk_r,
| 200 |
(PI - in_disk_phi)*in_disk_r/(PI/4),
| 201 |
-in_disk_r);
| 202 |
out_square_x = (out_square_a + 1)/2;
| 203 |
out_square_y = (out_square_b + 1)/2;
| 204 |
| 205 |
# Announce ourselves in XML output
| 206 |
print "\t<DataDefinition>\n";
| 207 |
print "\t\t<IncidentDataStructure>TensorTree$tensortree</IncidentDataStructure>\n";
| 208 |
print "\t</DataDefinition>\n";
| 209 |
# Fork parallel rtcontrib processes to compute each side
| 210 |
if ( $doback ) {
| 211 |
for (my $proc = 0; $proc < $nproc; $proc++) {
| 212 |
bg_tree_rtcontrib(0, $proc);
| 213 |
| 214 |
while (wait() >= 0) {
| 215 |
die "rtcontrib process reported error" if ( $? );
| 216 |
| 217 |
ttree_out(0);
| 218 |
| 219 |
if ( $doforw ) {
| 220 |
| 221 |
bg_tree_rtcontrib(1, $proc);
| 222 |
| 223 |
| 224 |
| 225 |
| 226 |
ttree_out(1);
| 227 |
| 228 |
} # end of sub do_tree_bsdf()
| 229 |
| 230 |
# Run i'th rtcontrib process for generating tensor tree samples
| 231 |
sub bg_tree_rtcontrib {
| 232 |
my $pid = fork();
| 233 |
die "Cannot fork new process" unless defined $pid;
| 234 |
if ($pid > 0) { return $pid; }
| 235 |
my $forw = shift;
| 236 |
my $pn = shift;
| 237 |
my $pbeg = $pdiv[$pn];
| 238 |
my $plen = $pdiv[$pn+1] - $pbeg;
| 239 |
my $matargs = "-m $bmodnm";
| 240 |
if ( !$forw || !$doback ) { $matargs .= " -m $fmodnm"; }
| 241 |
my $cmd = "rtcontrib $rtargs -h -ff -fo -c $nsamp " .
| 242 |
"-e '$disk2sq' -bn '$ns*$ns' " .
| 243 |
"-b '$ns*floor(out_square_x*$ns)+floor(out_square_y*$ns)' " .
| 244 |
"-o $td/%s_" . sprintf("%03d", $pn) . ".flt $matargs $octree";
| 245 |
if ( $tensortree == 3 ) {
| 246 |
# Isotropic BSDF
| 247 |
$cmd = "cnt $plen $ny $nx " .
| 248 |
"| rcalc -e 'r1=rand(($pn+.8681)*recno-.673892)' " .
| 249 |
"-e 'r2=rand(($pn-5.37138)*recno+67.1737811)' " .
| 250 |
"-e 'r3=rand(($pn+3.17603772)*recno+83.766771)' " .
| 251 |
"-e 'Dx=1-($pbeg+\$1+r1)/$ns;Dy:0;Dz=sqrt(1-Dx*Dx)' " .
| 252 |
"-e 'xp=(\$3+r2)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
| 253 |
"-e 'yp=(\$2+r3)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
| 254 |
"-e 'zp=$dim[5-$forw]' -e 'myDz=Dz*($forw*2-1)' " .
| 255 |
"-e '\$1=xp-Dx;\$2=yp-Dy;\$3=zp-myDz' " .
| 256 |
"-e '\$4=Dx;\$5=Dy;\$6=myDz' -of " .
| 257 |
"| $cmd";
| 258 |
} else {
| 259 |
# Anisotropic BSDF
| 260 |
# Sample area vertically to improve load balance, since
| 261 |
# shading systems usually have bilateral symmetry (L-R)
| 262 |
$cmd = "cnt $plen $ns $ny $nx " .
| 263 |
| 264 |
| 265 |
| 266 |
"-e 'r4=rand(($pn-2.3857833)*recno-964.72738)' " .
| 267 |
"-e 'in_square_x=($pbeg+\$1+r1)/$ns' " .
| 268 |
"-e 'in_square_y=(\$2+r2)/$ns' -e '$sq2disk' " .
| 269 |
"-e 'xp=(\$4+r3)*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
| 270 |
"-e 'yp=(\$3+r4)*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
| 271 |
| 272 |
| 273 |
| 274 |
"| $cmd";
| 275 |
| 276 |
# print STDERR "Starting: $cmd\n";
| 277 |
exec($cmd); # no return; status report to parent via wait
| 278 |
die "Cannot exec: $cmd\n";
| 279 |
} # end of bg_tree_rtcontrib()
| 280 |
| 281 |
# Simplify and output tensor tree results
| 282 |
sub ttree_out {
| 283 |
my $forw = shift;
| 284 |
my $side = ("Back","Front")[$forw];
| 285 |
# Only output one transmitted distribution, preferring backwards
| 286 |
| 287 |
print
| 288 |
' <WavelengthData>
| 289 |
<LayerNumber>System</LayerNumber>
| 290 |
<Wavelength unit="Integral">Visible</Wavelength>
| 291 |
<SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
| 292 |
<DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
| 293 |
<WavelengthDataBlock>
| 294 |
<WavelengthDataDirection>Transmission</WavelengthDataDirection>
| 295 |
<AngleBasis>LBNL/Shirley-Chiu</AngleBasis>
| 296 |
<ScatteringDataType>BTDF</ScatteringDataType>
| 297 |
<ScatteringData>
| 298 |
| 299 |
system "rcalc -if3 -e 'Omega:PI/($ns*$ns)' " .
| 300 |
q{-e '$1=(0.265*$1+0.670*$2+0.065*$3)/Omega' -of } .
| 301 |
"$td/" . ($bmodnm,$fmodnm)[$forw] . "_???.flt " .
| 302 |
"| rttree_reduce -h -ff -r $tensortree -g $ttlog2";
| 303 |
die "Failure running rttree_reduce" if ( $? );
| 304 |
print
| 305 |
' </ScatteringData>
| 306 |
</WavelengthDataBlock>
| 307 |
</WavelengthData>
| 308 |
| 309 |
| 310 |
# Output reflection
| 311 |
print
| 312 |
' <WavelengthData>
| 313 |
| 314 |
| 315 |
| 316 |
| 317 |
| 318 |
| 319 |
print "\t\t\t<WavelengthDataDirection>Reflection $side</WavelengthDataDirection>\n";
| 320 |
print '
| 321 |
| 322 |
<ScatteringDataType>BRDF</ScatteringDataType>
| 323 |
<ScatteringData>
| 324 |
| 325 |
| 326 |
| 327 |
"$td/" . ($fmodnm,$bmodnm)[$forw] . "_???.flt " .
| 328 |
| 329 |
| 330 |
print
| 331 |
' </ScatteringData>
| 332 |
| 333 |
</WavelengthData>
| 334 |
| 335 |
} # end of ttree_out()
| 336 |
| 337 |
#------------- End of do_tree_bsdf() & subroutines -------------#
| 338 |
| 339 |
#+++++++++++++++ Klems matrix BSDF generation +++++++++++++++#
| 340 |
sub do_matrix_bsdf {
| 341 |
# Set up sampling of portal
| 342 |
# Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
| 343 |
$tcal = '
| 344 |
DEGREE : PI/180;
| 345 |
sq(x) : x*x;
| 346 |
Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
| 347 |
Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
| 348 |
Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
| 349 |
Kmax : Kaccum(Knaz(0));
| 350 |
Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
| 351 |
Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
| 352 |
Kcol = Kbin - Kaccum(Krow-1);
| 353 |
Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
| 354 |
Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
| 355 |
sin_kpol = sin(Kpol);
| 356 |
Dx = cos(Kazi)*sin_kpol;
| 357 |
Dy = sin(Kazi)*sin_kpol;
| 358 |
Dz = sqrt(1 - sin_kpol*sin_kpol);
| 359 |
KprojOmega = PI * if(Kbin-.5,
| 360 |
(sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
| 361 |
1 - sq(cos(Kpola(1)*DEGREE)));
| 362 |
| 363 |
# Compute Klems bin from exiting ray direction (forward or backward)
| 364 |
$kcal = '
| 365 |
DEGREE : PI/180;
| 366 |
abs(x) : if(x, x, -x);
| 367 |
Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
| 368 |
posangle(a) : if(-a, a + 2*PI, a);
| 369 |
Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
| 370 |
kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
| 371 |
knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
| 372 |
kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
| 373 |
kfindrow(r, pol) : if(r-kpola(0)+.5, r,
| 374 |
if(pol-kpola(r), kfindrow(r+1, pol), r) );
| 375 |
kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
| 376 |
kbin2(pol,azi) = select(kfindrow(1, pol),
| 377 |
kazn(azi,360/knaz(1)),
| 378 |
kaccum(1) + kazn(azi,360/knaz(2)),
| 379 |
kaccum(2) + kazn(azi,360/knaz(3)),
| 380 |
kaccum(3) + kazn(azi,360/knaz(4)),
| 381 |
kaccum(4) + kazn(azi,360/knaz(5)),
| 382 |
kaccum(5) + kazn(azi,360/knaz(6)),
| 383 |
kaccum(6) + kazn(azi,360/knaz(7)),
| 384 |
kaccum(7) + kazn(azi,360/knaz(8)),
| 385 |
kaccum(8) + kazn(azi,360/knaz(9))
| 386 |
| 387 |
kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
| 388 |
| 389 |
my $ndiv = 145;
| 390 |
# Compute scattering data using rtcontrib
| 391 |
my @tfarr;
| 392 |
my @rfarr;
| 393 |
my @tbarr;
| 394 |
my @rbarr;
| 395 |
my $cmd;
| 396 |
my $rtcmd = "rtcontrib $rtargs -h -ff -fo -n $nproc -c $nsamp " .
| 397 |
"-e '$kcal' -b kbin -bn $ndiv " .
| 398 |
"-o '$td/%s.flt' -m $fmodnm -m $bmodnm $octree";
| 399 |
my $rccmd = "rcalc -e '$tcal' " .
| 400 |
"-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
| 401 |
q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
| 402 |
if ( $doforw ) {
| 403 |
$cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
| 404 |
"-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
| 405 |
"-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
| 406 |
"-e 'zp:$dim[4]' " .
| 407 |
q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
| 408 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
| 409 |
"| $rtcmd";
| 410 |
system "$cmd" || die "Failure running: $cmd\n";
| 411 |
@tfarr = `$rccmd $td/$fmodnm.flt`;
| 412 |
die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
| 413 |
@rfarr = `$rccmd $td/$bmodnm.flt`;
| 414 |
die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
| 415 |
| 416 |
if ( $doback ) {
| 417 |
| 418 |
"-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
| 419 |
"-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
| 420 |
"-e 'zp:$dim[5]' " .
| 421 |
q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
| 422 |
q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
| 423 |
"| $rtcmd";
| 424 |
| 425 |
@tbarr = `$rccmd $td/$bmodnm.flt`;
| 426 |
| 427 |
@rbarr = `$rccmd $td/$fmodnm.flt`;
| 428 |
| 429 |
| 430 |
# Output angle basis
| 431 |
print
| 432 |
' <DataDefinition>
| 433 |
<IncidentDataStructure>Columns</IncidentDataStructure>
| 434 |
<AngleBasis>
| 435 |
<AngleBasisName>LBNL/Klems Full</AngleBasisName>
| 436 |
<AngleBasisBlock>
| 437 |
<Theta>0</Theta>
| 438 |
<nPhis>1</nPhis>
| 439 |
<ThetaBounds>
| 440 |
<LowerTheta>0</LowerTheta>
| 441 |
<UpperTheta>5</UpperTheta>
| 442 |
</ThetaBounds>
| 443 |
</AngleBasisBlock>
| 444 |
<AngleBasisBlock>
| 445 |
<Theta>10</Theta>
| 446 |
<nPhis>8</nPhis>
| 447 |
<ThetaBounds>
| 448 |
<LowerTheta>5</LowerTheta>
| 449 |
<UpperTheta>15</UpperTheta>
| 450 |
</ThetaBounds>
| 451 |
</AngleBasisBlock>
| 452 |
<AngleBasisBlock>
| 453 |
<Theta>20</Theta>
| 454 |
<nPhis>16</nPhis>
| 455 |
<ThetaBounds>
| 456 |
<LowerTheta>15</LowerTheta>
| 457 |
<UpperTheta>25</UpperTheta>
| 458 |
</ThetaBounds>
| 459 |
</AngleBasisBlock>
| 460 |
<AngleBasisBlock>
| 461 |
<Theta>30</Theta>
| 462 |
<nPhis>20</nPhis>
| 463 |
<ThetaBounds>
| 464 |
<LowerTheta>25</LowerTheta>
| 465 |
<UpperTheta>35</UpperTheta>
| 466 |
</ThetaBounds>
| 467 |
</AngleBasisBlock>
| 468 |
<AngleBasisBlock>
| 469 |
<Theta>40</Theta>
| 470 |
<nPhis>24</nPhis>
| 471 |
<ThetaBounds>
| 472 |
<LowerTheta>35</LowerTheta>
| 473 |
<UpperTheta>45</UpperTheta>
| 474 |
</ThetaBounds>
| 475 |
</AngleBasisBlock>
| 476 |
<AngleBasisBlock>
| 477 |
<Theta>50</Theta>
| 478 |
<nPhis>24</nPhis>
| 479 |
<ThetaBounds>
| 480 |
<LowerTheta>45</LowerTheta>
| 481 |
<UpperTheta>55</UpperTheta>
| 482 |
</ThetaBounds>
| 483 |
</AngleBasisBlock>
| 484 |
<AngleBasisBlock>
| 485 |
<Theta>60</Theta>
| 486 |
<nPhis>24</nPhis>
| 487 |
<ThetaBounds>
| 488 |
<LowerTheta>55</LowerTheta>
| 489 |
<UpperTheta>65</UpperTheta>
| 490 |
</ThetaBounds>
| 491 |
</AngleBasisBlock>
| 492 |
<AngleBasisBlock>
| 493 |
<Theta>70</Theta>
| 494 |
<nPhis>16</nPhis>
| 495 |
<ThetaBounds>
| 496 |
<LowerTheta>65</LowerTheta>
| 497 |
<UpperTheta>75</UpperTheta>
| 498 |
</ThetaBounds>
| 499 |
</AngleBasisBlock>
| 500 |
<AngleBasisBlock>
| 501 |
<Theta>82.5</Theta>
| 502 |
<nPhis>12</nPhis>
| 503 |
<ThetaBounds>
| 504 |
<LowerTheta>75</LowerTheta>
| 505 |
<UpperTheta>90</UpperTheta>
| 506 |
</ThetaBounds>
| 507 |
</AngleBasisBlock>
| 508 |
</AngleBasis>
| 509 |
</DataDefinition>
| 510 |
| 511 |
if ( $doforw ) {
| 512 |
print
| 513 |
' <WavelengthData>
| 514 |
| 515 |
| 516 |
| 517 |
| 518 |
| 519 |
<WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
| 520 |
<ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
| 521 |
<RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
| 522 |
| 523 |
<ScatteringData>
| 524 |
| 525 |
# Output front transmission (transposed order)
| 526 |
for (my $od = 0; $od < $ndiv; $od++) {
| 527 |
for (my $id = 0; $id < $ndiv; $id++) {
| 528 |
print $tfarr[$ndiv*$id + $od];
| 529 |
| 530 |
print "\n";
| 531 |
| 532 |
print
| 533 |
' </ScatteringData>
| 534 |
| 535 |
</WavelengthData>
| 536 |
<WavelengthData>
| 537 |
| 538 |
| 539 |
| 540 |
| 541 |
| 542 |
<WavelengthDataDirection>Reflection Front</WavelengthDataDirection>
| 543 |
| 544 |
| 545 |
| 546 |
<ScatteringData>
| 547 |
| 548 |
# Output front reflection (transposed order)
| 549 |
| 550 |
| 551 |
print $rfarr[$ndiv*$id + $od];
| 552 |
| 553 |
print "\n";
| 554 |
| 555 |
print
| 556 |
' </ScatteringData>
| 557 |
| 558 |
</WavelengthData>
| 559 |
| 560 |
| 561 |
if ( $doback ) {
| 562 |
print
| 563 |
' <WavelengthData>
| 564 |
| 565 |
| 566 |
| 567 |
| 568 |
| 569 |
<WavelengthDataDirection>Transmission Back</WavelengthDataDirection>
| 570 |
| 571 |
| 572 |
| 573 |
<ScatteringData>
| 574 |
| 575 |
# Output back transmission (transposed order)
| 576 |
| 577 |
| 578 |
print $tbarr[$ndiv*$id + $od];
| 579 |
| 580 |
print "\n";
| 581 |
| 582 |
print
| 583 |
' </ScatteringData>
| 584 |
| 585 |
</WavelengthData>
| 586 |
<WavelengthData>
| 587 |
| 588 |
| 589 |
| 590 |
| 591 |
| 592 |
<WavelengthDataDirection>Reflection Back</WavelengthDataDirection>
| 593 |
| 594 |
| 595 |
| 596 |
<ScatteringData>
| 597 |
| 598 |
# Output back reflection (transposed order)
| 599 |
| 600 |
| 601 |
print $rbarr[$ndiv*$id + $od];
| 602 |
| 603 |
print "\n";
| 604 |
| 605 |
print
| 606 |
' </ScatteringData>
| 607 |
| 608 |
</WavelengthData>
| 609 |
| 610 |
| 611 |
| 612 |
#------------- End of do_matrix_bsdf() --------------#
