root/radiance/ray/src/util/genBSDF.pl
Revision: 2.13
Committed: Sat Apr 16 00:39:07 2011 UTC (14 years, 4 months ago) by greg
Bug fix for 32-bit OS
1 #!/usr/bin/perl -w
2 # RCSid $Id: genBSDF.pl,v 2.12 2011/02/24 20:27:00 greg Exp $
3 #
4 # Compute BSDF based on geometry and material description
5 #
6 # G. Ward
7 #
8 use strict;
9 use File::Temp qw/ :mktemp /;
10 sub userror {
11 print STDERR "Usage: genBSDF [-n Nproc][-c Nsamp][-r \"ropts\"][-dim xmin xmax ymin ymax zmin zmax][{+|-}f][{+|-}b][{+|-}mgf][{+|-}geom] [input ..]\n";
12 exit 1;
13 }
14 my $td = mkdtemp("/tmp/genBSDF.XXXXXX");
15 chomp $td;
16 my $nsamp = 1000;
17 my $rtargs = "-w -ab 5 -ad 700 -lw 3e-6";
18 my $mgfin = 0;
19 my $geout = 1;
20 my $nproc = 1;
21 my $doforw = 0;
22 my $doback = 1;
23 my @dim;
24 # Get options
25 while ($#ARGV >= 0) {
26 if ("$ARGV[0]" =~ /^[-+]m/) {
27 $mgfin = ("$ARGV[0]" =~ /^\+/);
28 } elsif ("$ARGV[0]" eq "-r") {
29 $rtargs = "$rtargs $ARGV[1]";
30 shift @ARGV;
31 } elsif ("$ARGV[0]" =~ /^[-+]g/) {
32 $geout = ("$ARGV[0]" =~ /^\+/);
33 } elsif ("$ARGV[0]" =~ /^[-+]f/) {
34 $doforw = ("$ARGV[0]" =~ /^\+/);
35 } elsif ("$ARGV[0]" =~ /^[-+]b/) {
36 $doback = ("$ARGV[0]" =~ /^\+/);
37 } elsif ("$ARGV[0]" eq "-c") {
38 $nsamp = $ARGV[1];
39 shift @ARGV;
40 } elsif ("$ARGV[0]" eq "-n") {
41 $nproc = $ARGV[1];
42 shift @ARGV;
43 } elsif ("$ARGV[0]" =~ /^-d/) {
44 userror() if ($#ARGV < 6);
45 @dim = @ARGV[1..6];
46 shift @ARGV for (1..6);
47 } elsif ("$ARGV[0]" =~ /^[-+]./) {
48 userror();
49 } else {
50 last;
51 }
52 shift @ARGV;
53 }
54 # Check that we're actually being asked to do something
55 die "Must have at least one of +forward or +backward" if (!$doforw && !$doback);
56 # Get scene description and dimensions
57 my $radscn = "$td/device.rad";
58 my $mgfscn = "$td/device.mgf";
59 my $octree = "$td/device.oct";
60 if ( $mgfin ) {
61 system "mgfilt '#,o,xf,c,cxy,cspec,cmix,m,sides,rd,td,rs,ts,ir,v,p,n,f,fh,sph,cyl,cone,prism,ring,torus' @ARGV > $mgfscn";
62 die "Could not load MGF input\n" if ( $? );
63 system "mgf2rad $mgfscn > $radscn";
64 } else {
65 system "xform -e @ARGV > $radscn";
66 die "Could not load Radiance input\n" if ( $? );
67 system "rad2mgf $radscn > $mgfscn" if ( $geout );
68 }
69 if ($#dim != 5) {
70 @dim = split ' ', `getbbox -h $radscn`;
71 }
72 print STDERR "Warning: Device extends into room\n" if ($dim[5] > 1e-5);
73 # Add receiver surfaces (rectangular)
74 my $fmodnm="receiver_face";
75 my $bmodnm="receiver_behind";
76 open(RADSCN, ">> $radscn");
77 print RADSCN "void glow $fmodnm\n0\n0\n4 1 1 1 0\n\n";
78 print RADSCN "$fmodnm source f_receiver\n0\n0\n4 0 0 1 180\n";
79 print RADSCN "void glow $bmodnm\n0\n0\n4 1 1 1 0\n\n";
80 print RADSCN "$bmodnm source b_receiver\n0\n0\n4 0 0 -1 180\n";
81 close RADSCN;
82 # Generate octree
83 system "oconv -w $radscn > $octree";
84 die "Could not compile scene\n" if ( $? );
85 # Set up sampling of interior portal
86 # Kbin to produce incident direction in full Klems basis with (x1,x2) randoms
87 my $tcal = '
88 DEGREE : PI/180;
89 sq(x) : x*x;
90 Kpola(r) : select(r+1, -5, 5, 15, 25, 35, 45, 55, 65, 75, 90);
91 Knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
92 Kaccum(r) : if(r-.5, Knaz(r) + Kaccum(r-1), 0);
93 Kmax : Kaccum(Knaz(0));
94 Kfindrow(r, rem) : if(rem-Knaz(r)+.5, Kfindrow(r+1, rem-Knaz(r)), r);
95 Krow = if(Kbin-(Kmax-.5), 0, Kfindrow(1, Kbin));
96 Kcol = Kbin - Kaccum(Krow-1);
97 Kazi = 360*DEGREE * (Kcol + (.5 - x2)) / Knaz(Krow);
98 Kpol = DEGREE * (x1*Kpola(Krow) + (1-x1)*Kpola(Krow-1));
99 sin_kpol = sin(Kpol);
100 Dx = cos(Kazi)*sin_kpol;
101 Dy = sin(Kazi)*sin_kpol;
102 Dz = sqrt(1 - sin_kpol*sin_kpol);
103 KprojOmega = PI * if(Kbin-.5,
104 (sq(cos(Kpola(Krow-1)*DEGREE)) - sq(cos(Kpola(Krow)*DEGREE)))/Knaz(Krow),
105 1 - sq(cos(Kpola(1)*DEGREE)));
106 ';
107 # Compute Klems bin from exiting ray direction (forward or backward)
108 my $kcal = '
109 DEGREE : PI/180;
110 abs(x) : if(x, x, -x);
111 Acos(x) : 1/DEGREE * if(x-1, 0, if(-1-x, 0, acos(x)));
112 posangle(a) : if(-a, a + 2*PI, a);
113 Atan2(y,x) : 1/DEGREE * posangle(atan2(y,x));
114 kpola(r) : select(r, 5, 15, 25, 35, 45, 55, 65, 75, 90);
115 knaz(r) : select(r, 1, 8, 16, 20, 24, 24, 24, 16, 12);
116 kaccum(r) : if(r-.5, knaz(r) + kaccum(r-1), 0);
117 kfindrow(r, pol) : if(r-kpola(0)+.5, r,
118 if(pol-kpola(r), kfindrow(r+1, pol), r) );
119 kazn(azi,inc) : if((360-.5*inc)-azi, floor((azi+.5*inc)/inc), 0);
120 kbin2(pol,azi) = select(kfindrow(1, pol),
121 kazn(azi,360/knaz(1)),
122 kaccum(1) + kazn(azi,360/knaz(2)),
123 kaccum(2) + kazn(azi,360/knaz(3)),
124 kaccum(3) + kazn(azi,360/knaz(4)),
125 kaccum(4) + kazn(azi,360/knaz(5)),
126 kaccum(5) + kazn(azi,360/knaz(6)),
127 kaccum(6) + kazn(azi,360/knaz(7)),
128 kaccum(7) + kazn(azi,360/knaz(8)),
129 kaccum(8) + kazn(azi,360/knaz(9))
130 );
131 kbin = kbin2(Acos(abs(Dz)),Atan2(Dy,Dx));
132 ';
133 my $ndiv = 145;
134 my $nx = int(sqrt($nsamp*($dim[1]-$dim[0])/($dim[3]-$dim[2])) + .5);
135 my $ny = int($nsamp/$nx + .5);
136 $nsamp = $nx * $ny;
137 # Compute scattering data using rtcontrib
138 my @tfarr;
139 my @rfarr;
140 my @tbarr;
141 my @rbarr;
142 my $cmd;
143 my $rtcmd = "rtcontrib -h -ff -fo -n $nproc -c $nsamp " .
144 "-e '$kcal' -b kbin -bn $ndiv " .
145 "-o '$td/%s.flt' -m $fmodnm -m $bmodnm $rtargs $octree";
146 my $rccmd = "rcalc -e '$tcal' " .
147 "-e 'mod(n,d):n-floor(n/d)*d' -e 'Kbin=mod(recno-.999,$ndiv)' " .
148 q{-if3 -e '$1=(0.265*$1+0.670*$2+0.065*$3)/KprojOmega'};
149 if ( $doforw ) {
150 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
151 "-e 'xp=(\$3+rand(.12*recno+288))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
152 "-e 'yp=(\$2+rand(.37*recno-44))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
153 "-e 'zp:$dim[4]' " .
154 q{-e 'Kbin=$1;x1=rand(2.75*recno+3.1);x2=rand(-2.01*recno-3.37)' } .
155 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp-Dz;$4=Dx;$5=Dy;$6=Dz' } .
156 "| $rtcmd";
157 system "$cmd" || die "Failure running: $cmd\n";
158 @tfarr = `$rccmd $td/$fmodnm.flt`;
159 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
160 @rfarr = `$rccmd $td/$bmodnm.flt`;
161 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
162 }
163 if ( $doback ) {
164 $cmd = "cnt $ndiv $ny $nx | rcalc -of -e '$tcal' " .
165 "-e 'xp=(\$3+rand(.35*recno-15))*(($dim[1]-$dim[0])/$nx)+$dim[0]' " .
166 "-e 'yp=(\$2+rand(.86*recno+11))*(($dim[3]-$dim[2])/$ny)+$dim[2]' " .
167 "-e 'zp:$dim[5]' " .
168 q{-e 'Kbin=$1;x1=rand(1.21*recno+2.75);x2=rand(-3.55*recno-7.57)' } .
169 q{-e '$1=xp-Dx;$2=yp-Dy;$3=zp+Dz;$4=Dx;$5=Dy;$6=-Dz' } .
170 "| $rtcmd";
171 system "$cmd" || die "Failure running: $cmd\n";
172 @tbarr = `$rccmd $td/$bmodnm.flt`;
173 die "Failure running: $rccmd $td/$bmodnm.flt\n" if ( $? );
174 @rbarr = `$rccmd $td/$fmodnm.flt`;
175 die "Failure running: $rccmd $td/$fmodnm.flt\n" if ( $? );
176 }
177 # Output XML prologue
178 print
179 '<?xml version="1.0" encoding="UTF-8"?>
180 <WindowElement xmlns="http://windows.lbl.gov" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://windows.lbl.gov/BSDF-v1.4.xsd">
181 <WindowElementType>System</WindowElementType>
182 <Optical>
183 <Layer>
184 <Material>
185 <Name>Name</Name>
186 <Manufacturer>Manufacturer</Manufacturer>
187 ';
188 printf "\t\t\t<Thickness unit=\"Meter\">%.3f</Thickness>\n", $dim[5] - $dim[4];
189 printf "\t\t\t<Width unit=\"Meter\">%.3f</Width>\n", $dim[1] - $dim[0];
190 printf "\t\t\t<Height unit=\"Meter\">%.3f</Height>\n", $dim[3] - $dim[2];
191 print "\t\t\t<DeviceType>Integral</DeviceType>\n";
192 # Output MGF description if requested
193 if ( $geout ) {
194 print "\t\t\t<Geometry format=\"MGF\" unit=\"Meter\">\n";
195 printf "xf -t %.6f %.6f 0\n", -($dim[0]+$dim[1])/2, -($dim[2]+$dim[3])/2;
196 system "cat $mgfscn";
197 print "xf\n";
198 print "\t\t\t</Geometry>\n";
199 }
200 print ' </Material>
201 <DataDefinition>
202 <IncidentDataStructure>Columns</IncidentDataStructure>
203 <AngleBasis>
204 <AngleBasisName>LBNL/Klems Full</AngleBasisName>
205 <AngleBasisBlock>
206 <Theta>0</Theta>
207 <nPhis>1</nPhis>
208 <ThetaBounds>
209 <LowerTheta>0</LowerTheta>
210 <UpperTheta>5</UpperTheta>
211 </ThetaBounds>
212 </AngleBasisBlock>
213 <AngleBasisBlock>
214 <Theta>10</Theta>
215 <nPhis>8</nPhis>
216 <ThetaBounds>
217 <LowerTheta>5</LowerTheta>
218 <UpperTheta>15</UpperTheta>
219 </ThetaBounds>
220 </AngleBasisBlock>
221 <AngleBasisBlock>
222 <Theta>20</Theta>
223 <nPhis>16</nPhis>
224 <ThetaBounds>
225 <LowerTheta>15</LowerTheta>
226 <UpperTheta>25</UpperTheta>
227 </ThetaBounds>
228 </AngleBasisBlock>
229 <AngleBasisBlock>
230 <Theta>30</Theta>
231 <nPhis>20</nPhis>
232 <ThetaBounds>
233 <LowerTheta>25</LowerTheta>
234 <UpperTheta>35</UpperTheta>
235 </ThetaBounds>
236 </AngleBasisBlock>
237 <AngleBasisBlock>
238 <Theta>40</Theta>
239 <nPhis>24</nPhis>
240 <ThetaBounds>
241 <LowerTheta>35</LowerTheta>
242 <UpperTheta>45</UpperTheta>
243 </ThetaBounds>
244 </AngleBasisBlock>
245 <AngleBasisBlock>
246 <Theta>50</Theta>
247 <nPhis>24</nPhis>
248 <ThetaBounds>
249 <LowerTheta>45</LowerTheta>
250 <UpperTheta>55</UpperTheta>
251 </ThetaBounds>
252 </AngleBasisBlock>
253 <AngleBasisBlock>
254 <Theta>60</Theta>
255 <nPhis>24</nPhis>
256 <ThetaBounds>
257 <LowerTheta>55</LowerTheta>
258 <UpperTheta>65</UpperTheta>
259 </ThetaBounds>
260 </AngleBasisBlock>
261 <AngleBasisBlock>
262 <Theta>70</Theta>
263 <nPhis>16</nPhis>
264 <ThetaBounds>
265 <LowerTheta>65</LowerTheta>
266 <UpperTheta>75</UpperTheta>
267 </ThetaBounds>
268 </AngleBasisBlock>
269 <AngleBasisBlock>
270 <Theta>82.5</Theta>
271 <nPhis>12</nPhis>
272 <ThetaBounds>
273 <LowerTheta>75</LowerTheta>
274 <UpperTheta>90</UpperTheta>
275 </ThetaBounds>
276 </AngleBasisBlock>
277 </AngleBasis>
278 </DataDefinition>
279 ';
280 if ( $doforw ) {
281 print ' <WavelengthData>
282 <LayerNumber>System</LayerNumber>
283 <Wavelength unit="Integral">Visible</Wavelength>
284 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
285 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
286 <WavelengthDataBlock>
287 <WavelengthDataDirection>Transmission Front</WavelengthDataDirection>
288 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
289 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
290 <ScatteringDataType>BTDF</ScatteringDataType>
291 <ScatteringData>
292 ';
293 # Output front transmission (transposed order)
294 for (my $od = 0; $od < $ndiv; $od++) {
295 for (my $id = 0; $id < $ndiv; $id++) {
296 print $tfarr[$ndiv*$id + $od];
297 }
298 print "\n";
299 }
300 print
301 ' </ScatteringData>
302 </WavelengthDataBlock>
303 </WavelengthData>
304 <WavelengthData>
305 <LayerNumber>System</LayerNumber>
306 <Wavelength unit="Integral">Visible</Wavelength>
307 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
308 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
309 <WavelengthDataBlock>
310 <WavelengthDataDirection>Reflection Front</WavelengthDataDirection>
311 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
312 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
313 <ScatteringDataType>BRDF</ScatteringDataType>
314 <ScatteringData>
315 ';
316 # Output front reflection (transposed order)
317 for (my $od = 0; $od < $ndiv; $od++) {
318 for (my $id = 0; $id < $ndiv; $id++) {
319 print $rfarr[$ndiv*$id + $od];
320 }
321 print "\n";
322 }
323 print
324 ' </ScatteringData>
325 </WavelengthDataBlock>
326 </WavelengthData>
327 ';
328 }
329 if ( $doback ) {
330 print ' <WavelengthData>
331 <LayerNumber>System</LayerNumber>
332 <Wavelength unit="Integral">Visible</Wavelength>
333 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
334 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
335 <WavelengthDataBlock>
336 <WavelengthDataDirection>Transmission Back</WavelengthDataDirection>
337 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
338 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
339 <ScatteringDataType>BTDF</ScatteringDataType>
340 <ScatteringData>
341 ';
342 # Output back transmission (transposed order)
343 for (my $od = 0; $od < $ndiv; $od++) {
344 for (my $id = 0; $id < $ndiv; $id++) {
345 print $tbarr[$ndiv*$id + $od];
346 }
347 print "\n";
348 }
349 print
350 ' </ScatteringData>
351 </WavelengthDataBlock>
352 </WavelengthData>
353 <WavelengthData>
354 <LayerNumber>System</LayerNumber>
355 <Wavelength unit="Integral">Visible</Wavelength>
356 <SourceSpectrum>CIE Illuminant D65 1nm.ssp</SourceSpectrum>
357 <DetectorSpectrum>ASTM E308 1931 Y.dsp</DetectorSpectrum>
358 <WavelengthDataBlock>
359 <WavelengthDataDirection>Reflection Back</WavelengthDataDirection>
360 <ColumnAngleBasis>LBNL/Klems Full</ColumnAngleBasis>
361 <RowAngleBasis>LBNL/Klems Full</RowAngleBasis>
362 <ScatteringDataType>BRDF</ScatteringDataType>
363 <ScatteringData>
364 ';
365 # Output back reflection (transposed order)
366 for (my $od = 0; $od < $ndiv; $od++) {
367 for (my $id = 0; $id < $ndiv; $id++) {
368 print $rbarr[$ndiv*$id + $od];
369 }
370 print "\n";
371 }
372 print
373 ' </ScatteringData>
374 </WavelengthDataBlock>
375 </WavelengthData>
376 ';
377 }
378 # Output XML epilogue
379 print '</Layer>
380 </Optical>
381 </WindowElement>
382 ';
383 # Clean up temporary files
384 system "rm -rf $td";
